F-22 Comparison
Old December 1st 03, 12:06 AM
Paul F Austin
"Kyle Boatright" wrote in message
"Yama" wrote in message
"Scott Ferrin" wrote in message
He also seems to have left out the ESM system which is quite elaborate
in the F-22. It can take an AMRAAM shot with it without even using
it's main radar. Also he was incorrect on the F-22's speed. The mach
1.7 he lists in in dry thrust and it wasn't even max military power.
Paul Metz stated on a Discovery special that the maximum speed of the
F-22 is classified but that it will go Mach 2.5. To quote him ". .
.it's fast, I mean it's REALLY fast. It's top speed is classifed but
it will do Mach 2.5" This suggests that the top speed in afterburner
is over Mach 2.5. Paul Metz is the chief test pilot of the F-22
program.
I am sceptical. Doesn't F-22 have fixed intakes? Speeds over mach 2.0
are
pretty much impossible to attain with fixed intakes. Besides, such
speeds
require some special materials in radome, canopy etc. which tend to be
more
expensive, may not be compatible with stealth requirements etc.
What I've seen for F-22 speeds as in combat configuration are mach
1.4-1.5
with supercruise, and 1.8 to 2.0 with afterburner. YF-23 was said to be
faster, especially with F120 engines.
The F-104 was a 50's design with fixed intakes, and was able to achieve
well
over M 2.0, so Mach 2+ is doable with fixed intakes. With 40+ more years
of
intake design development, even more *should* be possible.
The intakes on an F104 had a (fixed) centerbody to generate shock within the
inlet. A plain inlet seems to be limited to right at M2.0 (F16-land).
There's a boundary-layer splitter on the F-22 inlet but that appears to be
that. The point is largely moot because those other airplanes can only hit
high Mach numbers clean and in AB (ie, for a few minutes).
There've been a lot of religious arguments here about what "true
supercruise" is and what airplanes can do it and it plainly has to mean
"with ordnance aboard" or it means nothing at all. The F-22 is certainly the
fastest airplane in the world with anything more than a tank full of cannon
ammunition and possibly a pair of wing-tip missiles.
Old November 30th 03, 06:42 PM
Scott Ferrin
On Sun, 30 Nov 2003 17:44:46 +0200, "Yama"
program.
I am sceptical.
Maybe you missed that last line. Paul Metz is the chief test pilot, I
think he'd know.
oesn't F-22 have fixed intakes? Speeds over mach 2.0 are
Despite what much of the media would have you believe fixed inlets
mean zippo. The XF8-U Crusader III's inlet was fixed and it was good
up to Mach three. The highest it got was 2.3 because of the plasic
windshield and they planned to replace it with a glass one shortly
there after but the program ended up getting cancelled. The test
pilots were confident it would have reached 2.9 as it was still
rapidly accelerating at 2.3. It all depends on what speed the inlets
are optimized for. IIRC the Bomarc had fixed inlets too and the B
model was good for well over Mach 3. Come to think of it I'm pretty
sure ASALM had a fixed inlet too and it went well over Mach 5.
esides, such speeds
The YF-12 of the sixties had a radome that was good for at least Mach
3.2
canopy etc.
The F-15 was originally going to be designed to reach Mach 2.7 but
when they decided to go with the acrilyc canopy they had to back it
off to 2.5. I find it difficult to believe that haven't figure out
how to make one a tad better at high speeds in the past 30 years.
hich tend to be more
The canopy has a metallic coating for just this reason which is why it
has the gold look to it.
What I've seen for F-22 speeds as in combat configuration are mach 1.4-1.5
with supercruise,
It's hit 1.7 that they've released.
The top speed for the YF-23 is still classified ironically. GE has
estimated that it's non afterburner speed would have likely been over
1.8
Old November 30th 03, 07:01 PM
Tex Houston
March AFB used to have an LGM-30B mounted outside 15th Air Force
Headquarters Operations Center and the plaque displayed under speed...Mach
16+.
Tex
Old December 1st 03, 12:22 AM
Paul F Austin
program.
I am sceptical.
think he'd know.
The F-104, XF8U-3 and for that matter the Mirage III all had centerbodies in
their inlets to generate a second shock located near the inlet lip. In the
case of the F8U-3, the centerbody was the radome. While I'm with you that
Metz is in the best position to know, I will be fascinated to learn how a
M2.5 inlet with decent pressure recovery works without some sort of second
shock generator in the inlet. The inner wall of the inlet (with the boundary
layer splitter) may form a fixed shock generator since the inlet lip of the
F22 is "swept" back WRT the splitter.
Old December 1st 03, 01:25 PM
Yama
I am sceptical.
think he'd know.
I'd also think that he is not allowed to distribute still unreleased flight
performance data.
mean zippo.
No, they mean very much. It is certainly POSSIBLE to make a mach2+ plane
with fixed intake, but this will do very bad things to inlet performance in
other speeds (which are considerably more important). All your cited
examples are such cases.
esides, such speeds
3.2
canopy etc.
See above. It comes down to what is possible and what is sensible. If
solving problems of Mach2+ flight regarding *serviceable combat aircraft*
was so trivial as you make it sound, each and every modern fighter plane
would go Mach3 or more. Engine thrust has not been a limiting factor in
fighter top speed in like 40 years. In addition to that, F-22 also has
considerable stealth requirements. Radar-absorbing paints for example may
not be very tolerant to high speeds.
1.4-1.5
with supercruise,
In what load configuration?
Old December 1st 03, 04:04 PM
Dweezil Dwarftosser
program.
I am sceptical. Doesn't F-22 have fixed intakes? Speeds over mach 2.0 are
pretty much impossible to attain with fixed intakes. Besides, such speeds
require some special materials in radome, canopy etc. which tend to be more
The radomes of many mach 2+ aircraft are exactly the
same sort of construction (materials, etc.) as that
on aircraft from the 1950s. The fiberglass form is
essentially transparent to RF - but nothing which a
special coating (to replace the normal rubber) can't
make stealthy and concealing.
Besides - the F-22 is reputed to be using a large
number of small active arrays (part of the skin)
- in place of a conventional mechanical or
electronically-steered antenna. It's liable to be
a mess of cabling (or waveguide and ferrites) beneath
the skin - but an amazing advance.
Old December 4th 03, 03:17 AM
EB Jet
Yeah,someone ought to ask Paul Metz how fast the F-120 powered YF-23 would go
:-) M1.8 dry ain't too shabby..
Old November 29th 03, 09:32 AM
Ian Craig
"Paul F Austin" wrote in message
"robert arndt" wrote in message
om...
Data: F-22 Eurofighter Su-35
Raptor Typhoon Superflanker
Crew: 1 1 1
Engine: 2 P&W 2 Eurojet 2 Saturn
F-119 EJ200 AL-35F
35,000 20,250 28,218
lb each lb each lb each
Max Speed: Mach 1.70 Mach 2.0 Mach 2.35
Gun: 20mm GE 27mm Mauser 30mm GSh-30
M61A1 BK 27 linkless ----
Internal: 3 bays: N/A N/A
4 Sidewinder ---- ----
4 AIM-120A/ ---- ----
6 AIM-120C/ ---- ----
GBU-32 JDAM ---- ----
External: 4 hardpoints 13 hardpoints 12 hardpoints
5000 lb ord. ARM,ASRAAM,IRIS-T * 6 different
AAMs
or fuel METEOR,STORM SHADOW, * 6 different
ASMs
Features: Stealth (RAM KEPD350,ALARM,GBU-10/12 * various
IR/LG/TVG
+ serrated 80% CF construction bombs
edges) * future anti-radar pod * anti-radiation
Supercruise: Yes Yes No
Radar: APG-77 CAPTOR Doppler Zhuk-PH+ rear
NO12
Systems: HUD+ 4 LCDs Wide angle HUD HUD+ 3 LCDs
sidestick VTAS (Voice, Throttle, IRST
triplex FBW Stick) Helmet-mounted
sight
Helmet-mounted sight quadraplex FBW
IRST ECM pods
DASS
ESM Pods
quadraplex FBW
*future FBL
Initial Order: 295 Units 148 Units None placed
That's a nice summary. You missed the Intraflight Datalinks (IDL) for the
F-22. That plays a big role in the F-22 CONOPS. Does Typhoon have that
facility? I know Grypen does.
Typhoon does have a datalink capability.
There are also a lot more than 148 ordered (if the original orders go
through its over 600)
Comparison of tankage would be helpful both internal and with external
tanks.
Old November 29th 03, 12:42 PM
Paul F Austin
"Ian Craig" wrote in message
om...
Crew: 1 1 1
F-119 EJ200 AL-35F
AAMs
ASMs
IR/LG/TVG
anti-radiation
NO12
sight
IRST ECM pods
DASS
ESM Pods
quadraplex FBW
*future FBL
There's datalinks and datalinks. Saying Typhoon has one is like saying it
has wheels. IDL manages beam direction and radiated power and uses a covert
waveform to minimize probability of detection outside the local group. At
the same time, there's sensor fusion within the local group with sensor data
passed from AC to AC so that everyone sees what anyone sees.
If you want (more than you would believe) data links, go he
http://www.afceaeriecanal.org/AFRL.Minges.ppt for an overview of the web of
USAF links.
Old November 30th 03, 04:05 PM
Alan Minyard
om...
Crew: 1 1 1
F-119 EJ200 AL-35F
AAMs
ASMs
IR/LG/TVG
anti-radiation
NO12
sight
IRST ECM pods
DASS
ESM Pods
quadraplex FBW
*future FBL
USAF links.
Not to mention that the F-22 is generations ahead of the other aircraft when it
comes to LO technology and implementation. The Typhoon and the SU-35
are giant reflectors by comparison.
Al Minyard
Performance Comparison Sheet Ed Baker Home Built 6 December 2nd 04 03:14 AM
Aerobatic engine IO-360 AEIO-360 comparison Jay Moreland Aerobatics 5 October 6th 04 02:52 AM
spaceship one Pianome Home Built 169 June 30th 04 06:47 AM
EMW A6 Comparison to X-15 robert arndt Military Aviation 8 October 2nd 03 03:26 AM
Best Fighter For It's Time Tom Cooper Military Aviation 63 July 29th 03 04:22 AM
