Depression after Washing
Old June 28th 08, 03:39 AM posted to rec.aviation.piloting,rec.aviation.owning
Margy Natalie
Default Depression after Washing
Charles Talleyrand wrote:
On Jun 26, 10:45 pm, "Mike" wrote:
"Charles Talleyrand" wrote in message
My kid and I just washed the plane. Even after washing it, there are
still chips of paint missing, a bit of rust, a drip-stain of fuel, and
so on. The panel looks like it has been modified every once in a
while since 1966. My plane is relatively nice compared to the other
ones on the field, but it's still in worse cosmetic condition than my
car.
None of these problems is a safety issue, and none of them could be
fixed without spending significant time and/or money.
One of the reasons we own airplanes is pride of ownership.
This makes me sad. Makes me want to sell and rent.
It's possible to restore old paint. You'd be surprised what you can polish
out. Older planes were actually painted with very high quality paint that
can be restored. Chips can be polished and filled with paint. There's not
much you can do with rust spots other than remove it and have the paint
matched, but it should at least be tended to before it gets worse. You can
either have all that done professionally or you can do it yourself. The
following web site would be a great place to start:
It's not old paint. The paint is probably only six years old. My car
is also six years old, but I know I can replace my car when ever I get
sick of it. Planes are not so easy to exchange, and I would just get
another old plane anyway. At least this one has very few non-cosmetic
squawks (dang nose wheel shimmy).
I could rent and save money and still fly the same amount, but then I
would not have pride of ownership. I have a $20,000 Cessna 150. It
flies just fine but the cosmetics just don't touch a $20,000 car.
This reduces the pride of ownership and makes me more likely to sell
and rent. Of course renting is a pain in the butt here (there is one
plane; everyone must share it).
-still sad
Touch up paint works wonders, my old paint was a perfect match with Ford
Engine Blue, but we repainted. I should find a "match" for the "new"
paint as there are a few spots that could use a touch up. We either
have to stop wearing wedding rings or deal with the fact that the paint
will be chipped off the handle we use to get up on the wing.
Margy (spent the day polishing the spinner!)
Old June 28th 08, 08:54 PM posted to rec.aviation.piloting,rec.aviation.owning
Darrel Toepfer
At least this one has very few non-cosmetic squawks (dang nose wheel
shimmy).
Add shims, make sure the fork/hinge doesn't have cracks, make sure the
tire doesn't have excessive wear or a bump on it, is the strut leaking
oil too? If so replace the seals, usually the damper shock isn't the
fault, but it could be weak too...
Old June 27th 08, 06:20 AM posted to rec.aviation.piloting,rec.aviation.owning
Mxsmanic
Charles Talleyrand writes:
car.
It's a very expensive hobby.
Old June 27th 08, 07:18 AM posted to rec.aviation.piloting,rec.aviation.owning
Buster Hymen
Mxsmanic wrote in
car.
Only for life losers like you, Anthony.
Old June 27th 08, 03:06 PM posted to rec.aviation.piloting,rec.aviation.owning
Gene Seibel
On Jun 26, 5:22*pm, Charles Talleyrand wrote:
My kid and I just washed the plane. *Even after washing it, there are
so on. *The panel looks like it has been modified every once in a
while since 1966. *My plane is relatively nice compared to the other
car.
This makes me sad. *Makes me want to sell and rent.
Our '66 is cosmetically challenged. Sometimes it depresses me for a
moment or two, but the second we start that takeoff run, nothing but
flying is on my mind. My money is going into hours in the air. That's
why I bought it. I notice that most of the people who have commented
about the condition, age, or speed of my airplanes don't even have one
and fly far less than I do or not at all.
Gene Seibel
Tales of flight - http://pad39a.com/gene/tales.html
Because we fly, we envy no one.
Old June 28th 08, 04:08 PM posted to rec.aviation.piloting,rec.aviation.owning
Stealth Pilot[_2_]
On Fri, 27 Jun 2008 06:06:58 -0700 (PDT), Gene Seibel
car.
an old pilot's aphorism: The air has no eyes!
the bloody stuff also has no respect :-)
Stealth Pilot
Old July 5th 08, 07:25 AM posted to rec.aviation.piloting,rec.aviation.owning
Frank Olson
car.
We added this stuff to our Aerostar (inboard wing sections and
horizontal stabs not protected by the de-ice boots). Works wonders. No
stone chips. As for the rust... deal with it. Not only is it a sure
sign you need a paint job, it also tells me you're not spending enough
time with your baby. :-)
http://www.getwrapped.ca/leadingedge/
Dry Washing - Wing Waxers? Spitfire Owning 2 November 28th 06 02:28 AM
Washing a fiberglass airplane City Dweller Owning 5 May 22nd 06 03:13 AM
Depression and flying Flyingmonk Piloting 44 February 13th 06 03:28 PM
Washing - how often? Reid & Julie Baldwin Owning 15 May 7th 05 08:15 AM
US debt is higher now than during Depression WalterM140 Military Aviation 9 March 31st 04 06:30 PM
