"Jukka O. Kauppinen" wrote in message ...
So RAF stopped using ball ammo during 1942. And there was no true AP ammo in use before SAPI? Interesting. I wonder, they had Hurricane II with 4x20 mm. I presume this plane was used in ground attack missions with the bombload. Those cannons were still loaded with HE/HEI/BALL ammo for strafing missions? I presume they weren't much effective against German armour? Several different AP rounds were developed and tested in the UK, but as far as I can tell they were all unsatisfactory. The Mk 1 and Mk 2 were traditional solid shot and proved ineffective when tested against tanks, so weren't generally issued. The Mk 3 was the APCR. There was a more traditional Mk 4, which came out in 1944, but I don't know if that saw any use; I have no record that it did. The RAF seemed to find that the ball and SAPI rounds were more than adequate against aircraft, and the 20mm was too small to do much damage to tanks. So they concentrated on the 40mm for anti-tank use until they decided that wasn't good enough either, and went to RPs instead. Tony Williams Military gun and ammunition website: http://www.quarry.nildram.co.uk Discussion forum at: http://forums.delphiforums.com/autogun/messages/ |
Don't know, but I just found this site; might be helpful.
http://www.quarry.nildram.co.uk/ "Jukka O. Kauppinen" wrote in message ... What was the timetable for British development for their 20 mm cannon ammuniation during WW2? I'm aware that RAF tried to install first cannons to Spit Is but this was initially a failure. Early Spit V models were introduced with 60 round supply to the Hispanos, later with 120 rounds per gun. Some of the documents I've seen showed, that RAF had severe problems in 1941 maybe even during 1942 with HE ammo, which had tendency to explode in the barrel. Until HE was perfected (42?) I presume the cannons primarily used the Ball ammuniation? What is the actual timetable for introduction of various British cannon ammuniation types for squadron service? Ball from the start, AP, HE, API etc later? jok |
| 50% of NAZI oil was supplied from US | Grantland | Military Aviation | 106 | January 18th 14 08:58 PM |
| russia vs. japan in 1941 [WAS: 50% of NAZI oil..] | Military Aviation | 136 | December 6th 03 11:40 PM | |
| French block airlift of British troops to Basra | Michael Petukhov | Military Aviation | 202 | October 24th 03 07:48 PM |
| AF unveils force development plan | Otis Willie | Military Aviation | 0 | October 11th 03 05:55 AM |
