Removing tape residue from canopy
Old March 22nd 09, 05:55 PM posted to rec.aviation.soaring
BravoNiner
Default Removing tape residue from canopy
Time to replace some yaw strings. Can anyone recommend a good way to
remove old tape residue without doing violence to the canopies?
Thanks,
Mark -- B9
Old March 22nd 09, 06:24 PM posted to rec.aviation.soaring
On Mar 22, 11:55*am, BravoNiner wrote:
Time to replace some yaw strings. *Can anyone recommend a good way to
Thanks,
Mark -- B9
Try 3M's "General Purpose Adhesive Remover" Part Number: 08984
It's excellent on a number of surface types. I can't recall using it
on Plexiglas--but get a can and try it on a scrap piece. I've found
the product online and at Ace Hardware. It's great on my painted
surface for removing gap seal tape residue--and it doesn't affect the
acrylic finish.
What I do now with my string: drill a very small hole at the point
where you want the string on the canopy. Insert the yarn string and
secure with a small "keeper" from the inside. This totally eliminates
the tape. The keeper I use is a hobby-store RC accessory used for push
rod connections. Made of nylon, I super glue it to the string and it
works well. Doesn't mar the canopy.
Old March 22nd 09, 06:36 PM posted to rec.aviation.soaring
bumper
"BravoNiner" wrote in message
Thanks,
Mark -- B9
Mark,
I've used denatured alcohol with a clean microfiber cloth. Saturate a small
section of cloth and gently rub over the old adhesive. Depending on the type
of tape use, this can be an arduous process. You can use your fingernail to
help, though this can sometimes result in scratches.
My MKIII "high tech" yaw string avoids the tape residue problem. After a two
year outdoor exposure test (in California sun), the outer clear plastic
layer of the MKIII base lifts off leaving the clear adhesive behind. Then
the clear adhesive easily and cleanly "rolls off" the canopy with finger
pressure. Besides, the MKIII looks nicer than tape.
bumper
Quiet Vent and MKIII yaw string
bum per m at att dot net
Old March 22nd 09, 08:58 PM posted to rec.aviation.soaring
We're updating our entire fleet with the MKIII yaw string. No excuse
not to -- it's not expensive and it looks so much better than yarn and
tape. It changes the appearance from that of an afterthought to a
proper flight instrument. Besides that, if we can keep Bumper busy
making them he won't come mooch lunch off us all the time. Fred
Old March 22nd 09, 09:00 PM posted to rec.aviation.soaring
vontresc
Thanks,
Mark -- B9
Mark,
bumper
So Bumper Being a relative newbie, what is a Mk III yaw string????
Pete
Old March 22nd 09, 10:09 PM posted to rec.aviation.soaring
Newbie, schnewbie. The problem is, he's too cheap to advertise. So
you only learn about them from first-hand experience. And once you
see one ya gotta git one yourself! The thing is, good enough seems
good enough for most of us until someone comes along and improves on
it, then you think "why didn't I think of that?" Bumper makes a habit
of thinking of those fixes that we all would have thought of if we
were not satisfied with the status quo. Maybe he'll toot his own horn
on RAS, but I kinda doubt it. Shy, don't you know. There's just one
thing -- when you order your MKIII, ask him how he came up with the
brilliant idea for the installation tool! It's genius!
Fred
Old March 22nd 09, 10:17 PM posted to rec.aviation.soaring
Mike Schumann
So what is it and where do you get it??????
Mike Schumann
Fred
Old March 22nd 09, 10:34 PM posted to rec.aviation.soaring
He's on his way to the mall right this minute, but he'll answer later
today. My description wouldn't do it justice! Fred
Old March 22nd 09, 10:38 PM posted to rec.aviation.soaring
BT
also try "goo gone" on a scrap piece first
Thanks,
Mark -- B9
Old March 22nd 09, 10:39 PM posted to rec.aviation.soaring
BT
Pictures.. we need pictures
Residue under fuselage from breather? Sweendawg Owning 3 March 14th 07 12:48 AM
removing old, dried, masking tape Michael Horowitz Home Built 9 January 4th 07 06:54 PM
Removing RTV John Home Built 6 October 31st 06 11:07 PM
Auto Fuel Residue Stu Gotts Restoration 4 May 12th 04 09:52 PM
Removing paint from canopy Jason Restoration 4 November 12th 03 10:22 PM
