Gluing rubber pieces
Old May 25th 09, 06:55 PM posted to rec.aviation.homebuilt
RogerN
Default Gluing rubber pieces
"Ed" wrote in message
On Sun, 24 May 2009 10:15:02 -0700 (PDT), "
In the dark ages, I'd reach for the Pliobond. Is there a better
solution these days? Crazy glue of some kind?
Bill Hale Loveland CO
I'd still reach for pliobond!
I work in maintenance at a tire plant and they keep pliobond in their
storeroom. We used it to glue an airplane tire to a rim for a tire
balancer. I'm not sure what their original purpose for pliobond is at our
plant but I figure it's pretty good for rubber adhesive.
RogerN
Old May 25th 09, 10:20 AM posted to rec.aviation.homebuilt
kfvorwerk
On May 24, 7:15*am, "
Trying to repair the foot on the extension laddder I use
in the hangar.
It needs a new rubber foot.
I'm riviting a 1/4" piece or rubber to the aluminum foot.
Then I want to glue a 1/8" piece to the that to cover the
rivet heads.
So the glue joint would mostly be in compression and would
have to have decent shear strength. *It wouldn't have to have
more peel strength than what's required to reliably keep the
1/8" piece from falling off.
In the dark ages, I'd reach for the Pliobond. *Is there a better
solution these days? *Crazy glue of some kind?
I'd use contact cement.
Karl
Old May 25th 09, 12:10 PM posted to rec.aviation.homebuilt
routund
in the hangar.
rivet heads.
have to have decent shear strength. It wouldn't have to have
3M Weatherstrip Trim Adhesive. Get it at any auto parts store. Comes in yellow
or black, although sometimes black is hard to find.
Old May 27th 09, 11:58 AM posted to rec.aviation.homebuilt
Dana M. Hague[_2_]
in the hangar.
rivet heads.
... Crazy glue of some kind?
Loctite makes a product called "Black Max", which is a modified
cyanoacrylate adhesive made just for this purpose. It's the best
thing I've ever found for gluing rubber to metal.
-Dana
When you get it right
mighty beasts float up into the sky
When you get it wrong
people die
-Roger Bacon (c1384)
Gluing on Fabric ......... :-\)\) Home Built 13 August 24th 05 10:05 PM
gluing plastic on fiberglass Borislav Deianov Home Built 6 June 3rd 05 08:47 PM
WTB: Cessna pieces Marty from Sunny Florida Aviation Marketplace 1 April 6th 05 05:02 AM
Gluing phenolic B2431 Home Built 4 June 12th 04 11:44 PM
Spar gluing Lou Parker Home Built 26 November 21st 03 08:29 PM
