"Bjørnar Bolsøy" wrote in message ... Alan Minyard wrote in Looking at the video of the south tower impact, doesn't the huge fireball outside the building seem to suggest that much, if not most, of the fuel burned up on the outside? The fuel on the aircraft perhaps but the trouble is there was large fuel load in the building in the form of furniture, carpets, paper computers etc. The fireball ignited all of that fuel simultaneously and the impact destroyed fireproof partitions and knocked the fireprrofing off the floor struts. It was the heat from the subsequent fire that cause those struts to fail. Once they had done so the bracing between the outer wall and inner core that was essential to the strength of the building was lost and outer skin failed in buckling. The damager inner core was unable to tale the extra stress and also failed. This sequence can be clearly seen in the video footage. Keith |
On Mon, 12 Jan 2004 03:27:11 GMT, "Bjørnar Bolsøy" wrote:
Alan Minyard wrote in : On Sat, 10 Jan 2004 21:17:22 GMT, "Bjørnar Bolsøy" wrote: Mark and Kim Smith wrote in : Well sure there were explosives. It's called jet fuel and oxygen. These folks really need to learn how those building were built before they start coming up with these dumb theories. Is it likely to assume that the fuel burned up in the explosion when the airplane impacted? Regards... No, there would be a great deal of fuel remaining. Remember that the "explosion" would rob itself of Oxygen. Looking at the video of the south tower impact, doesn't the huge fireball outside the building seem to suggest that much, if not most, of the fuel burned up on the outside? Regards... No, the "huge fireball" would have consumed a large amount of jet fuel, but not all of it. It is nearly impossible to get "complete" combustion under those circumstances. Al Minyard |
On Mon, 12 Jan 2004 03:27:11 GMT, Bjørnar Bolsøy wrote:
Alan Minyard wrote in : On Sat, 10 Jan 2004 21:17:22 GMT, "Bjørnar Bolsøy" wrote: Mark and Kim Smith wrote in : Well sure there were explosives. It's called jet fuel and oxygen. These folks really need to learn how those building were built before they start coming up with these dumb theories. Is it likely to assume that the fuel burned up in the explosion when the airplane impacted? No, there would be a great deal of fuel remaining. Remember that the "explosion" would rob itself of Oxygen. Looking at the video of the south tower impact, doesn't the huge fireball outside the building seem to suggest that much, if not most, of the fuel burned up on the outside? No. It suggests that enough fuel to create a fireball several hundred feet in diameter burned up outside the south tower. FEMA's World Trade Center Building Performance Study [1] estimates that the amount of fuel consumed in the fireball was between 1,000 and 3,000 gallons. The 767 that hit the south tower was carrying about 10,000 gallons of fuel, so that leaves between 7,000 and 9,000 gallons of fuel to help start the fires in the building. The FEMA report assumes the fireballs generated by the impact of AA 11 on the north tower were similar in size, and that a similar amount of fuel remained after the impact. No estimate was made because there is no detailed video footage of the fireballs from the first impact. The bottom line is that a lot of fuel was consumed in the post-impact fireballs, but there was a whole lot more left over. The FEMA study estimates that most of the fuel that remained on the impact floors of the towers was consumed in the first five minutes or so after impact, fully involving almost the entire contents of several floors of each tower in the fires. ljd [1] The FEMA study is available in PDF form at http://www.fema.gov/library/wtcstudy.shtm The discussion of the initial impact and development of the fires is in chapter 2, pp 2-21 and 2-22. |
| turbo video | Peter Holm | Aerobatics | 13 | September 30th 04 12:31 AM |
| Aviation Video: Another F-16 bites the dust | Iwan Bogels | Instrument Flight Rules | 0 | September 21st 04 08:02 AM |
| In-Flight Video | Ron Wanttaja | Home Built | 11 | May 16th 04 07:11 AM |
| twin tail questions | Kevin Horton | Home Built | 12 | January 2nd 04 04:21 PM |
| SR-71 Video | Dave Jones | Military Aviation | 0 | November 10th 03 09:00 PM |
