The Melting Deck Plates Muddle - V-22 on LHD deck....
Old December 10th 09, 02:55 PM posted to rec.aviation.military,sci.military.naval,rec.aviation.military.naval
vaughn[_2_]
Default The Melting Deck Plates Muddle - V-22 on LHD deck....
"David E. Powell" wrote in message
Make a designated VTOL area and add shuttle style tiles there.
Try simple things first! I really doubt that the problem is severe enough to
require a high-tech approach. First, a simple change in procedures to reduce
time with the engines in the vertical position will greatly reduce the problem.
A designated landing pad made of metal that will stand the heat with an
underlayment to prevent heat transfer to the underlying deck will solve the
problem. Yes, the resulting uneven deck would be a PITA for the deck crew, but
the pad would not need to be more than an inch or two thick with tapering edges
for the transition. After the plane departs, a quick hosedown would likely be a
good idea for crew safety & to prevent melted tires.
This issue could hardly be a "surprise" or even a "muddle". The potential
problem of deck heating from VTOL aircraft has been well known for decades.
When I first reported aboard the Guam (LPH-9) the crew were talking about the
deck tests they had done with the (then new & revolutionary) Harrier just weeks
before.
Vaughn
Old December 10th 09, 08:24 AM posted to rec.aviation.military,sci.military.naval,rec.aviation.military.naval
guy
On 10 Dec, 04:22, Mike wrote:
StrategyPage.com
December 2, 2009
by James Dunnigan
Earlier this year, the U.S. Navy discovered that the heat from the
MV-22's gas turbine engines, which blow their exhaust right on to the
deck of the LHD while waiting to take off, caused high enough
temperatures to the steel under the deck plates, to possibly warp the
understructure. This was already a known potential problem with the
new F-35B vertical takeoff jet fighter.
So now the Navy has two hot new aircraft that require an innovative
solution to the melting deck problem. The Navy also discovered that
the exhaust heat problem varied in intensity between different classes
of helicopter carriers (each with a different deck design.)
The Navy is looking for a solution that will not require extensive
modification of current carrier decks. This includes a lot of decks,
both the eleven large carriers, and the ten smaller LHAs and LHDs.
This is shaping up as another multi-billion dollar "oops" moment, as
the melting deck problem was never brought up during the long
development of either aircraft.
Previously, the Harrier was the only aircraft to put serious amounts
of heat on the carrier deck, but not enough to do damage. But when you
compare the Harrier engine with those on the V-22 and F-35B, you can
easily see that there is a lot more heat coming out of the two more
recent aircraft. Someone should have done the math before it became a
real problem.
How did they manage with the AV8/Harrier then?
Guy
Old December 10th 09, 08:52 AM posted to rec.aviation.military,sci.military.naval,rec.aviation.military.naval
dott.Piergiorgio
real problem.
I second the question and point that V-22 & F-35B's heat discharge is
from exhaust gas discharge and/or propeller (IF I grokked well, the 35B
has a sort of vertical propeller contraption) when the harrier's heat
discharge are from jet vanes so at least on paper, Harrier's vertical
exhaust is more hot than V-22...
Best regards from Italy.
Dott. Piergiorgio.
Old December 10th 09, 10:50 AM posted to rec.aviation.military,sci.military.naval,rec.aviation.military.naval
BlackBeard
On Dec 9, 11:52*pm, "dott.Piergiorgio"
real problem.
How did *they manage with the AV8/Harrier then?
discharge are *from jet vanes so at least on paper, Harrier's vertical
Dott. Piergiorgio.
As for the 35B, yes it uses a central fan device for vertical TO/L,
but it also has an exhaust tail that rotates to 90 degrees down. So
there are two forces working to lift it. I spent a week or so shooting
both.
As for the V-22, the solution, like the Harrier might be to limit TO/
L to rolling approach/landing. With both platforms direct impingement
is enough to cause damage.
BB
Old December 10th 09, 11:57 AM posted to rec.aviation.military,sci.military.naval,rec.aviation.military.naval
Jack Linthicum
real problem.
Dott. Piergiorgio.
both.
*As for the V-22, the solution, like the Harrier might be to limit TO/
L to rolling approach/landing. *With both platforms direct impingement
BB
Or use the rocket launch technique and spray water across the take-off
area.
Old December 10th 09, 12:15 PM posted to rec.aviation.military,sci.military.naval,rec.aviation.military.naval
guy
real problem.
Dott. Piergiorgio.
both.
BB
area.- Hide quoted text -
- Show quoted text -
Can the V-22 not do at least a partial rolling(STOL) take off?
Guy
Old December 10th 09, 02:10 PM posted to rec.aviation.military,sci.military.naval,rec.aviation.military.naval
Bill Kambic[_2_]
On Thu, 10 Dec 2009 02:57:36 -0800 (PST), Jack Linthicum
snipped for brevity
area.
Probably less than optimal. Large clouds of hot, salt water steam
would be an annoyance (at a minimum) to the deck crew. It would also
be a highly corrosive material that could serious complicate
maintenance of both ship and aircraft.
Use of fresh water would likely be an excessive demand on the
evaporators.
The piping of cooling water suggested earlier would be a better idea.
It would likely be cheaper that major modifications such as a "ski
jump" and permit the continued use of the vertical capability of the
aircraft.
Old December 10th 09, 12:26 PM posted to rec.aviation.military,sci.military.naval,rec.aviation.military.naval
William Black[_1_]
StrategyPage.com
December 2, 2009
by James Dunnigan
real problem.
Ski jump off, slow rolling landing on.
William Black
"Any number under six"
The answer given by Englishman Richard Peeke when asked by the Duke of
Medina Sidonia how many Spanish sword and buckler men he could beat
single handed with a quarterstaff.
Old December 10th 09, 02:49 PM posted to rec.aviation.military,sci.military.naval,rec.aviation.military.naval
Jack Linthicum
On Dec 10, 6:26*am, William Black wrote:
StrategyPage.com
December 2, 2009
by James Dunnigan
real problem.
Ski jump off, *slow rolling landing on.
William Black
Here's a V-22 landing and taking off from HMS Illustrious. Any damage
done or a different deck?
http://www.skycontrol.net/helicopter...or-first-time/
Old December 10th 09, 02:30 PM posted to rec.aviation.military,sci.military.naval,rec.aviation.military.naval
Timur
http://china-arsenal.blogspot.com/
Flight deck queens Michael Huber[_2_] Aviation Photos 2 January 19th 08 07:38 AM
Kiev's deck - with Yak-36s and Ka-25s Dave Kearton Aviation Photos 0 March 2nd 07 07:12 AM
Ka-25s on Kiev's deck Dave Kearton Aviation Photos 0 March 2nd 07 07:09 AM
Straight deck ops Greasy Rider Naval Aviation 18 January 10th 07 02:35 AM
Deck height Sean Trost Home Built 5 July 16th 04 04:46 AM
