Hercules Engines
Old January 17th 04, 04:41 AM
Tarver Engineering
"Rick" wrote in message
ink.net...
Tarver Engineering wrote:
Yep, the individually wired theromcouples are sent to a Totalizer, when
they
are not wired in series. That is why the datum is a total.
Yeah, OK, so in Tarverworld the temperature of the gas
entering the turbine is around 18,000 degrees C.
What is you post supposed to mean, Rick?
Did you just want to make something up and look stupid?
Old January 17th 04, 06:47 AM
George Ruch
Yep, the individually wired theromcouples are sent to a Totalizer, when they
Roughly the surface temperature of a Class B star. Considering titanium
boils at 3,278C, could this be ... magic metallurgy? g, d & r
|George
| George Ruch |
| "Is there life in Clovis after Clovis Man?" |
Old January 17th 04, 05:25 PM
running with scissors
Rick wrote in message link.net...
The irony of it all.
Indeed.
Rick
much the way that in tarverworld a spoiler is a flap and a flight
director is an autopilot.
Old January 17th 04, 05:21 PM
"Tarver Engineering" wrote in message ...
"Phil Miller" wrote in message
news
Hey Splappy,
Do you remember this series of pronouncements;
Newsgroups: rec.aviation.military
Subject: Do Hercules military aircraft use the same fuel as
civilian aircraft?
Date: Fri, 8 Nov 2002 19:19:37 -0800
snip
Not really. On the T56 engine TIT = (T)urbine (I)nlet (T)empreture.
Yes really, on every jet engine TIT is Total Inlet Temperature.
Yep.
Nope.
One has to wonder if the trolls of ram will ever catch a clue.
do you know what "series" and "parallel" means ??
the irony of it all indeed !
Tarver Engineering
"running with scissors" wrote in
message om...
news
Hey Splappy,
civilian aircraft?
snip
(T)empreture.
Yep.
Nope.
they
Sure. I am an engineer with a masters degree.
So funny and so stupid.
Old January 21st 04, 05:51 PM
Tom Mosher
news
Hey Splappy,
Subject: Do Hercules military aircraft use the same fuel as civilian
aircraft?
snip
Yep.
Have you considered yet, Miller, that your zero knowledge of aircraft makes
for a pretty rediculess archive troll?
Wrong numnuts.
CFM56's don't have TIT (turbine inlet temperature), they use EGT
(exhaust gas temperature).
RR Speys don't have TIT - they use ITT (interstage turbine
temperature).
Proves you don't know **** about aircraft engines or engine indicating
systems.
Tom Mosher
Senior Logistics Analyst for a MAJOR defense contractor.
Old January 21st 04, 06:40 PM
Tarver Engineering
"Tom Mosher" wrote in message
om...
temperature).
My idiot, jet engines use T0 thru T8, with some stations skipped.
Besides that sub-idiot tommy, have you considered this?
"Gord Beaman" wrote in message
"Jim Knoyle" wrote:
Hang on here a second now Jim, you still need two samples. As Dan
says you need 'static pressure' to read the altitude from and you
need 'pitot pressure' (ram air pressure) as well as the static
pressure to derive the airspeed reading from. Sounds like you're
saying that you can read 'both' from just the 'ram air pressure'
alone. Or did I misunderstand you?
Jim has finally figued out what a pitot tube is, but somehow he still wants
to be correct in his archive troll. It is a great paradox.
I know...ain't life a bitch John
-Gord.
You don't know what a pitot tube is either, do you, sub-idiot Mosher?
Old January 17th 04, 06:14 AM
Tarver Engineering
news
Do you feel better now, Phil?
Having proven once again that you are a clueless git?
Book Review: Converting Auto Engines for Experimental Aircraft , Finch Paul Home Built 0 October 18th 04 11:14 PM
Homebuilt Aircraft Frequently Asked Questions (FAQ) Ron Wanttaja Home Built 0 April 5th 04 04:04 PM
Hercules Engines Tarver Engineering Home Built 0 January 20th 04 12:05 AM
Accident Statistics: Certified vs. Non-Certified Engines Ron Wanttaja Home Built 23 January 18th 04 06:36 PM
Homebuilt Aircraft Frequently-Asked Questions (FAQ) Ron Wanttaja Home Built 0 July 4th 03 05:50 PM
