BRS chutes. Why doesn't everyone use them?
Old January 20th 11, 05:35 AM
Sparkorama Sparkorama is offline
Junior Member
First recorded activity by AviationBanter: Nov 2010
Question BRS chutes. Why doesn't everyone use them?
I'm just getting back into the sport after a long hiatus. I've seen that a lot of glider pilots fly with parachutes (ones they wear) and I have seen Ballistic Recovery System parachutes in planes as well. From my layman's view, it appears that getting out of a plane using a traditional chute after a mid-air collision seems exceedingly difficult and time-consuming. On the other hand, BRS chutes seem to deploy very fast and can be deployed very close to the ground. They can lower the entire plane safely to the ground in almost any terrain, and a few bruises to your bird or your body seems a lot better than certain death if you can't get out of a plane after a mid-air. So if this is true, and I am happy to say I am no expert, then why isn't everyone using these things? I think they should be mandatory in every new glider built. Thoughts?
Spark
Old January 20th 11, 06:22 AM
shkdriver shkdriver is offline
Member
First recorded activity by AviationBanter: Aug 2008
Quote:
Spark
IMHO,
Sailplanes are the ultimate expression of aerodynamics, and as such, demand an almost fanatical devotion to efficiency. Nothing about a sailplanes' design or construction is superfluous. Indeed, a cockpit that is merely adequate in size is deemed a luxury. New gliders run from about $70,000 to over $300,000. I don't believe adding an explosive or pyrotechnic device with a very short life limit (read a few years) with an increase of an estimated $10,000 to $20,000 in cost is what the new glider buying public wants.
Also, while I don't have hard data, I think backpack worn parachutes have thousands of lives saved across all aviation, I think you would have a hard time finding even a hundred lives saved with BRS, I'll even give you any Fb-111 capsule deployments into the count.
IMHO, BRS belongs in LSA, new GA (read Cessna) and selected ultralite aviation as an owner/buyer option, even in gliders as optional equipment.
Never mandatory.
Scott.
Old January 20th 11, 12:45 PM posted to rec.aviation.soaring
Doug Greenwell
Default BRS chutes. Why doesn't everyone use them?
At 05:22 20 January 2011, shkdriver wrote:
that
difficult
death
and
Thoughts?
Spark
IMHO,
equipment.
Never mandatory.
Scott.
shkdriver
BRS claim 259 lives saved with their systems
http://www.brsaerospace.com/lives_saved.aspx
A glider sized internally mounted unit is around $6000, with a claimed 12
year lift for the rocket and a six year repack - so not unreasonable?
I'd be worried about accidental operation though.
There's always the ejector seat option
rocket powered :
http://www.youtube.com/watch?v=JAA4t...eature=related
or a strange sort of reverse airbag:
http://www.dg-flugzeugbau.de/noah-e.html
Old January 20th 11, 01:07 PM posted to rec.aviation.soaring
Big Wings
If you read the passenger's report of a glider incident at the following
URL
http://sites.google.com/site/thebig4...theskiesagain/
you will see from the photographs that the damage in the area behind the
cockpit, where a BRS system would probably have been installed, was so
badly damaged that its unlikely that it would have worked. The pilot and
passenger both wore parachutes and survived.
Yes I know there are other accidents where the opposite argument can be
made - but I'm not aware of any statistics that come down firmly on one
approach versus the other in the gliding world where (in the UK at least)
parachutes are worn for a very high proportion of flights. In the power
world, where parachutes are worn infrequently, the value of BRS is likely
to be less ambiguous.
that
and
Thoughts?
Spark
Sparkorama
Old January 20th 11, 01:35 PM posted to rec.aviation.soaring
Mike the Strike
URL
badly damaged that its unlikely that it would have worked. *The pilot and
parachutes are worn for a very high proportion of flights. *In the power
that
and
Thoughts?
Spark
Sparkorama
Destruction of gliders by lightning is so rare this is hardly
something to worry about. The event in question occurred when the
glider intercepted a rare and very energetic positive lightning ground
flash. Most glider lightning incidents are much less exciting,
although some damage is likely to occur.
Most parachutes are deployed after a mid-air AFAIK.
Mike
Old January 20th 11, 01:47 PM posted to rec.aviation.soaring
On Jan 19, 11:35*pm, Sparkorama Sparkorama.
Thoughts?
Spark
Sparkorama
Here we go with this mandatorys stuff again!!
First of all you have at least one misconception......the aircraft is
not "lowered to the ground with only a few bruises". The opening of
the chute is a major event, the shock can cause considerable damage by
itself. The descent rates are high, so considerable damage upon
striking the ground. The device is "life saving" but not "aircraft
saving".
I has strongly considered a BRS when building my homebuilt
plane......I ruled it out for a number of reasons. The greatest
reason was that the design and structure of the aircraft wuld have had
too have been highly modified.....strengthened....coping with strong
force loads in the oposite direction......to with stand the opening
shock of the chute............this required the doubling of the
cockpit side walls, installation of metal cross members, etc. This
alone would have added too much weight to the aircraft, not to mention
the complications and weight of the mounting of the BRS unit
itself.........
Yeah, and then the cost...........
Now on the other hand, there are many factory built aircraft with
BRS....Like Cirrus.....a few gliders too..........these companies feel
that the BRS is a good selling point....enhanced safety and all
that....
In the world of ultralights, BRS type chutes are the "norm" fairly
common in Light Sport aircraft too......I believe that just about ALL
hanglider guys have a ballistic chute of some type.
Cookie
Old January 20th 11, 02:40 PM posted to rec.aviation.soaring
T8
On Jan 20, 7:47*am, "
Here we go with this mandatory stuff again!!
I think it's a January thing. My daughter's 4th grade class was
assigned to write up a proposed new state law, due this morning. My
suggestion was that she propose a law keeping government noses out of
private business :-). She came up with the idea of limiting internet
tracking all on her own, so perhaps there's hope for the youngsters,
yet!
-Evan Ludeman / T8
Old January 20th 11, 03:19 PM posted to rec.aviation.soaring
JJ Sinclair[_2_]
On Jan 19, 8:35*pm, Sparkorama
Thoughts?
Spark
Sparkorama
I tried to get info from BRS last fall and received no reply to two e-
mails and a phone call. Have the fallen on hard times (economy
issues)? I was ready to buy one, but before plunking down $4500 bucks
I need to know they will support the product.
JJ
Old January 20th 11, 07:29 PM posted to rec.aviation.soaring
Andy[_1_]
On Jan 19, 9:35*pm, Sparkorama
Thoughts?
Spark
Sparkorama
You say you are no expert yet you think they should be mandatory in
every new glider built. I find that to be a paradox.
Would it not make more sense to familiarize yourself with the subject
before deciding what should be mandatory?
Previously cited factors have included increased weight, increased
cost, lack of adequate test data, insufficient space and probably a
few more.
I was interested in BRS when it was offered as an option for the
ASW-28. It seems the brochure writer was ahead of the designer and
the option was never made available.
Andy
Old January 20th 11, 07:33 PM posted to rec.aviation.soaring
Eric Greenwell[_4_]
It would be interesting to know the numbers. I can think of a few
deployments resulting from in-flight breakup, jammed controls, and
unrecoverable spins, in addition to mid-airs.
email me)
- "Transponders in Sailplanes - Feb/2010" also ADS-B, PCAS, Flarm
http://tinyurl.com/yb3xywl
F-104 Chutes out Glen in Orlando Aviation Photos 0 October 9th 09 08:01 PM
Square chutes - ExtreemSports.wmv (0/1) Tech Support Soaring 4 December 15th 08 08:40 PM
Square Chutes... sisu1a Soaring 4 December 9th 08 07:04 PM
Puchaz spin - now wearing 'chutes Bill Daniels Soaring 60 February 14th 04 09:08 PM
