Germany invented it. We shot it down
Old February 23rd 04, 05:28 AM
William Donzelli
"eunometic" wrote in message ...
An Integrated air defense system makes sense for the British on their
island. For the landlocked Germans, who had no channel, a philosophy of
avoiding a war of attrition and winning the frist battles so as to avoid
fighting on German soil prevailed. Very little was devoted to defense it
was thought best to devote it to attack and support of the Army and this
probably starved the development of such systems eg IFF.
The German IFF systems (FuG 25 and FuG 25a were the aircraft
transponders) were actually pretty good. Their coding system was
extremely flexible, and it did not use a wide swept-band system like
the Allied Mk III IFF kludge. So technically, they were on the ball,
as far as IFF systems are concerned.
William Donzelli
Old February 21st 04, 11:19 AM
M. H. Greaves
Another factor in the Me 262 was hitlers intervention; he wanted it to be a
bomber, NOT a fighter! which caused many aproblem, and even willy
Messerschmitt had to be summoned.
Hitler did that to many projects, he did it to the Fi103 (the doodlebug,
V1), he also had reservations about the A4 (the V2) and it was only in the
later stages of the war that he let it go into production because he knew he
was losing the war and wanted revenge weapons (vergeltungswaffe), as a form
of payback to the allies.
"Peter Stickney" wrote in message
(Eunometic) writes:
(ArtKramr) wrote in message
Nuff said.
Arthur Kramer
344th BG 494th BS
England, France, Belgium, Holland, Germany
Visit my WW II B-26 website at:
http://www.coastcomp.com/artkramer
The Me 262 seems to have shot down 150 aircraft for the loss of 100 of
their own. Mostly shot up on landing or takeoff when they were even
more vulnerable to this problem than piston enginer aircraft due to
their slow throttle response. (A problem partially solved by the
better control systems on latter engines like the Jumo 004D as opposed
to jumo 004B4.)
It has little to do with throttle responce, and a lot to do with the
Thrust/Power relationship. It's a bit too late for me to type it all
in again tonight - but please do some googling in r.a.m. on the
subject.
This loss rate is a dismal record; it wasn't that the 262 wasn't a
good weapons system: it was simply outnumbered and heavily targeted by
the allies and also and quite a few losses were experienced on the
first missions due to the tactic of slowing down to take aim. It
wasn't untill tactics were worked out to solve this that effectiveness
improved.
And placed into service long before it should have been. Some
problems, like poor asymmetric handling at low speeds (One Engine out)
were endemic to the design. But there were other problems - high
speed snaking, and some rather ugly transonic behavior that should
have been resolved before service pilots were turned loose in it.
The Me 262 Pilot's Handbook has about 3 pages of handling
limitations. The F-80A Pilot's handbook has 2 flight limit entries.
You know, it's rather interesting that for all the work on high-speed
aerodynamics that the Germans actually did perform, they never seemed
to be able to translate it into the aircraft they built. The German
Aviation Military/Industrial Complex's solution to
compressibility/controllability problems in their airplanes was to put
a Big Red "Thou Shalt Not..." notice in the Pilot's Handbook. Compare
this to the work done in the U.S and Britain to sort out the
transonic problems that were occurring - the developmetn of the DIve
Recovery Flap (Which isn't a Speed Brake), improved control surface
geometries, and, for that matter, the inclusion of Speed
Brakes.
In technolgy the Germans and allies were closely matched. Both sides
produced major breakthroughs and both sides had areas where they fell
embarrasingly far behined.
The Germans were perhaps forced to focus on Break throughs because
resources were massively against them after 42 but in the end the odds
were against them. I do suspect that the breakthroughs would have
broken up the superiority of the allies in some areas. Jet aircraft
gave them a fresh start that would have equalised them where the
allies ahd piston engined superiority in quantity and quality. Sure
the allies would also have had jets but their existing technolgy would
have had its value wiped out and would have made useless almost all
piston engined aircraft: B26,A26,P47, B17,B24,B25 etc but they never
got enough of their jets going in time.
It's not that simple. There were a lot of factors - the most telling
of which were evident in 1936, when the Luftwaffe, and the other
German Armed Forces, cut back on armament production because they
didn't have enough raw materiels to use the factory capacity they
already had.
One of the other things they should have done was build up a better
training organization. A big limit was the lack of properly skilled
pilots. By late 1944, there weren't enough fully capable pilots to
make a differece, even if they were flying Mr. Arndt's Disks and
herding around Reptilicus. There's no point in making jet airplanes
if you have nobody who can fly them.
I don't like the "Allies Invented Everyting" nor do I like the
"Germans Invented Everyting" attitude. Anyone who knows how
technology advances should realise what one man can do another will
replicate almost immediatly. One of the mistakes of the Germans in
the Radar war was to put so much secrecy on their radar vulnerability
that they failed to develop effective countermeasurews to windows
jamming becuase the requise people weren't involved.
It should have been obvious that the British, who were behined in
Radar at the time would soon catch up.
That is a rather good example of the German's arrogance about their
own technology, and their "Mirror-Imaging" of how a particular
technology would be used. In 1939, and 1940 the Germans had the best
high-frequency radar around. Their main thrust for it, however, was
to use it to bulwark existing systems, specifically Antiaircraft and
Naval Fire Control. And they did this well.Once they'd figured out
that the long-wave pulsed signals that they were receiving was some
sort of radar, they absolutely knew that they were far ahead of teh
British, and didn't need to worry about it. What they missed,
however, was that those primitive, inaccurate long-wave radars were
part of an integrated Cammand and Control system that allowed RAF
Fighter Command to concentrate their forces with an efficency not seen
in aerial warfare before that time.
That same blindness - that belief that the German stuff was superior
because it was German, effected them in all areas.
Alexander the Great however with 50,000 men once defeated Darius's
army of 2-3 million with boldness and clever tactics.
Uhm, I don't think that ther were 2-3 million people in the entire
Persian Empire. Subsistance farming doesn't give you that sort of a
reserve.
Pete Stickney
A strong conviction that something must be done is the parent of many
bad measures. -- Daniel Webster
Old February 21st 04, 01:30 PM
Keith Willshaw
"M. H. Greaves" wrote in message
a
This is an urban legend. The fact is that the Me-262 was delayed because
of aerodynamic problems and engine production issues. Hanging
a bomb rack and release mechanism on a fighter is just not
that big a problem.
he
form
No sir he did not, the Fi-103 and V-2 were delayed from entering into
production by technical problems. Neither were ready for mass production
until Summer 1943 and production was authorised immediately but in
August 1943 the RAF destroyed the planned production facility at
Peenemunde with a massive air raid
Both projects had a priority close to that enjoyed by the Manhattan
Project in the USA. Vast amounts of slave labour and resources
were poured into their production in the underground Nordhausen
concentration camp.
Keith
Old February 21st 04, 08:14 PM
M. H. Greaves
"Keith Willshaw" wrote in message
be
a
that big a problem.
knew
he
form
No sir he did not,
YES HE DID! I have read the book by General Walter Dornberger, and although
technical issues did have a major part to play in it, Hitlaer did not
initially back it!
ONLY because hitler gave them that status and only later in the war after
peenemunde had been bombed!
concentration camp.
Keith
Old February 22nd 04, 12:34 AM
Peter Stickney
"M. H. Greaves" writes:
A common legend, but there's no truth to it. The only difference
between a Fighter Me 262, and a Bomber 262 (Actually, a Jagdbomber -
Fighter-Bomber) was the addition of the removable pylons. Withoug the
bombs on board, there was no difference in the performance of the
airplane. Since that was the case, it made plenty of sense to add the
pylons & the release wiring on the production line. It didn't
actually delay the service introduction of the jet one bit. What did
delay its introduction was the poor reliability and low production
numbers for the engines. The 262 was suppoed to go into service in
very early 1944. The powerplant problems delayed that by a half a
year. Note that in early 1944, everybody in the German command loop
knew that the Western Allies were going to be invading, and invading
as soon as it was practicable. They also knew that theere would be a
massive blanket of air cover, and that they stood no realistic chance
of successfully attacking the invasion beaches, and more importantly,
the ships supplying them, with the airplane types they had in 1943.
GIven that set of conditions, having an airplane that could make
strikes that couldn't be easily countered on the invasion beaches and
the invasion fleet would have the effect of drawing a significant
amount of those resources into protecting the beaches, rather than
interdicting the Heer as is moved to counter the invasion. In fact,
it really didn't matter if they were able to bomb accurately or not -
the threat itself would have been sufficient. The delays in being
able to supply adequate engines, however, made the whole concept
irrelevant.
So, what we have is what was actually a rather sound decision that was
negated by the technical problems causing the in-service date to slip.
The A4 had problems with Guidance and Control, and, as was dicovered
fairly late into the program, with the airframe of teh rocket breaking
up on descent. These problems, and the need to set up the proper
infrastructure to produce and transport massive quantities of Liquid
Oxygen had much more to do with delaying its use.
The F1 103 (V-1) also had problems with launching and inflight
stability. Those had to be sorted out, and the launching sites in
France had to be prepared. Germany, for reasons unkown, took a rather
luxurious path with the launching sites, with large amounts of
permanent construction and massive fixed facilities.
Pete Stickney
Old February 21st 04, 02:59 AM
Ron
550,000 of the 11 million slaves brought across the Atlantic came to the
US. Indians are 3% of the US population, so they were not wiped out. And
Indian reservations account for 4% of the US land mass so they have more
land per person than most Americans. If you think that all this adds up
to anything like what Europe has done you are insane. The Belgians alone
have done worse.
The Dutch West Indies got the same amount. Brazil got 4 million. Yes
according to the reparations movement and those like Jesse Jackson, you would
think everyone of them was sent to the US. They decline to mention that the
slaves were often sold by other African tribes, and that slavery still exists
in Africa today.
Ron
Tanker 65, C-54E (DC-4)
Old March 8th 04, 12:17 AM
Jan
(ArtKramr) wrote in message ...
Nuff said.
Arthur Kramer
344th BG 494th BS
Talk it over with your caregiver.
Perhaps you take a look he
http://www.alz.uci.edu
There's always hope....even for you. So if you try hard you might
consolidate your mental state. It's breaking my heart to see a man of
your age making a fool of himself.
Best wishes for your recovery from Germany!
Jan Fuhrmann
Old March 8th 04, 01:36 AM
Mike Marron
(Jan) wrote:
(ArtKramr) wrote:
Nuff said.
Arthur Kramer
344th BG 494th BS
I'm no shrink, but in addition to the URL you referred him to above
maybe he should also seek professional help for his Narcissistic
Personality Disorder (NPD)...
* An inflated valuation of oneself (exaggeration of talents and
achievements, demonstration of presumptuous self-confidence);
* Interpersonal exploitation (uses others to satisfy his needs and
desires, expects preferential treatment without undertaking mutual
commitments);
* Possesses expansive imagination (externalises immature and
non-regimented fantasies, "prevaricates to redeem self-illusions");
*Displays supercilious imperturbability (except when the narcissistic
confidence is shaken), nonchalant, unimpressed and cold-blooded;
*Defective social conscience (rebels against the conventions of common
social existence, does not value personal integrity and the rights of
other people).
Jan Fuhrmann
Hey, Germany Invented It... Face It Erich Adler Military Aviation 51 February 20th 04 06:39 PM
China in space. Harley W. Daugherty Military Aviation 74 November 1st 03 07:26 PM
Israeli Air Force to lose Middle East Air Superiority Capability to the Saudis in the near future Jack White Military Aviation 71 September 21st 03 03:58 PM
Russia joins France and Germany captain! Military Aviation 12 September 9th 03 10:56 AM
Chirac lost JD Military Aviation 7 July 26th 03 07:38 PM
