"Pete" writes: "Ed Majden" wrote in message news 8tZb.579658$ts4.461106@pd7tw3no..."B2431" The U.S. built and flew a few disc aircraft during WW2. The Chance Vought V-173 first flew 23 November 1942, which had excellent STOL capabilities and was apparently impossible to stall. AVRO Canada experimented with a flying saucer type design in the 1950s. This was funded in part by the USAF. It was known as the Avrocar. It was abandoned as I guess technology had not been developed (i.e. computer flight control systems etc) for controlling successful flight. Do a search with 'google' for "AVRO Flying Saucer" if you want to read more about this project. Ed Majden One of those is on display at the Ft. Eustis, Virginia, Transportation Museum. http://www.avroarrow.org/Avrocar/Avrocar3.html http://www.davidpride.com/Army/us_ft_eustis_04.htm That's also the furthest that thing's ever been from the surface. -- Pete Stickney A strong conviction that something must be done is the parent of many bad measures. -- Daniel Webster |
"Ed Majden" wrote in message news:p8tZb.579658$ts4.461106@pd7tw3no...
"B2431" The U.S. built and flew a few disc aircraft during WW2. The Chance Vought V-173 first flew 23 November 1942, which had excellent STOL capabilities and was apparently impossible to stall. AVRO Canada experimented with a flying saucer type design in the 1950s. This was funded in part by the USAF. and US Army since it was really a GETOL (Ground Effect Takeoff and Landing) aircraft. It was known as the Avrocar. It was abandoned as I guess technology had not been developed (i.e. computer flight control systems etc) for controlling successful flight. Do a search with 'google' for "AVRO Flying Saucer" if you want to read more about this project. Ed Majden Ed, it was a farce. The mock-up and two prototypes were demonstrated as purpose failures to mislead the Soviets into believing this was the direction the US was going with disc technology. Despite the AVROCAR, the US had already aquired disc technology from Germany via AVRO Canada and the immense documentation from Wright Field. AVRO, Lockheed and Northrop all had disc projects way beyond the VZ-9V and some of those designs and photos are now coming to light: Silverbug, WS 606A, AVRO Ace/Spade, the LRV (Lenticular Reentry Vehicle), Northrop NS-97, etc... Meanwhile the Soviets dropped the disc plans and proceeded with the T-60S bomber which is based on the German Sanger spaceplane. That program and prototype(s) are still active in Russia. Rob |
"robert arndt" Ed, it was a farce. The mock-up and two prototypes were demonstrated as purpose failures to mislead the Soviets into believing this was the direction the US was going with disc technology. Despite the AVROCAR, the US had already aquired disc technology from Germany via AVRO Perhaps! With a little bit more imagination, they should have added a ground effect skirt and perhaps they would have had a proto type of a hovercraft, although a very small one. Does anyone know when the first hovercraft was designed? The UK is generally given credit for the first practical in use models I believe. Ed |
Ken Duffey wrote in message ...
robert arndt wrote: (B2431) wrote in message ... The U.S. built and flew a few disc aircraft during WW2. The Chance Vought V-173 first flew 23 November 1942, which had excellent STOL capabilities and was apparently impossible to stall. The Navy ordered two XF5U-1 which didn't get their propellers until 1947 and were not proceded with since the Navy decided jets were the way to go. Dan, U.S. Air Force, retired Actually, the idea was researched in the US since 1932 (Patent 2,108,093). It was based om the theories of physicist Charles H. Zimmermann, compiled in technical report NACA 431. In 1939, The US Navy provided the funding for the prototype which flew on 11/23/42 as the Chance-Vought V-173. Previous aerodynamic tests had already revealed the instability and low maneuverability of the plane, so the designers were forced to install big conventional empennages, spoiling the very concept of the circular wing aircraft (hint: not a true disc). Low speed performances were considered worse than in other models in service of the time. So, the next step was a proposal for a VTO recon plane with tilting rotors repacing the prop blades. Other protoypes were made (series XF5U-1) equipped with 1359 hp engines but their performance was also inadequate for the postwar needs of the US Navy and the project was cancelled in the spring of 1948. The Soviets also tested two circular gliders based on the German A.S.6- the Diskoplan I with a Kreisflugel J1253 wing (investigated by Dr. Alexander Lippisch in 1940-41 at the AVA Gottingen wind tunnel and Messerschmitt AG laboratories). It was presented at the Moscow Airport at Tushino in 1958. A Diskoplan II flew in 1962, but no data is available for a powered version. It is not known if a high-performance powered version was ever built. Rob Is that the one hanging from the ceiling in the hangar at Monino ??? Yes. Here's mo http://www.ufx.org/soviet/sukhanov.htm Rob |
| Homebuilt Aircraft Frequently Asked Questions List (FAQ) | Ron Wanttaja | Home Built | 40 | October 3rd 08 04:13 PM |
| Homebuilt Aircraft Frequently Asked Questions (FAQ) | Ron Wanttaja | Home Built | 0 | October 1st 04 03:31 PM |
| Homebuilt Aircraft Frequently Asked Questions List (FAQ) | Ron Wanttaja | Home Built | 0 | September 2nd 04 06:15 AM |
| Homebuilt Aircraft Frequently Asked Questions (FAQ) | Ron Wanttaja | Home Built | 2 | February 3rd 04 12:41 AM |
| Homebuilt Aircraft Frequently-Asked Questions (FAQ) | Ron Wanttaja | Home Built | 0 | July 4th 03 05:50 PM |
