Tost release failure
Old August 24th 12, 07:57 PM posted to rec.aviation.soaring
BobW
Default Tost release failure
On 8/24/2012 11:25 AM, kirk.stant wrote:
Finally! I've been refusing to do release checks for years and get the
stink-eye everytime. I've tried explaining that if you can hook up, then
you have checked as much as you can, but still get people saying "but what
if it fails?".
Maybe one of you smart guys out there can explain the logic of a separate
release check?
Kirk 66
The only rationale I was ever able to generate was that functioning under
tension might somehow reveal a difference compared to "dry firing." (Yeah, I
thought the rationale weak!)
That said, when connecting someone I always offer to perform a release check
"because it's generally expected I do so"...and have no issue with pilots
declining the offer (there are a few!).
Happily, with first an HP-14 and then a Zuni, I had my own built-in
excuse to NOT perform a release check, since both types have Dick Schreder's
(dirt simple) retracting design which generally requires verbal hand-holding
from Joe Pilot in order simply to make the connection, even *after* I'd
pre-positioned the release from its retracted position. My rationale with the
Schreder release is it's safer simply to connect and launch then to increase
exposure time on an active runway fiddling *twice* with "a funky release."
Maybe release checks are like your mother's reminders to always wear clean
underwear in case you have a serious accident. What the heck difference does
it make?!? Can you prove it? :-)
Bob - has never contributed to thread creep! - W.
Old August 24th 12, 09:18 PM posted to rec.aviation.soaring
Ken Fixter[_2_]
why not use the wheel brake at start of launch to reduce the chance of
over running the tow rope, it has been my practice for many years as I had
an unable to releas on a winch launch not a nice experience.
KF
then
what
if it fails?".
separate
release check?
Kirk 66
(Yeah,
I
check
Schreder's
hand-holding
increase
release."
does
Old August 24th 12, 07:56 PM posted to rec.aviation.soaring
Bart[_4_]
On Aug 24, 10:25*am, "kirk.stant" wrote:
Finally! I've been refusing to do release checks for years and get the stink-eye everytime. *I've tried explaining that if you can hook up, then you have checked as much as you can, but still get people saying "but what if it fails?".
Maybe one of you smart guys out there can explain the logic of a separate release check?
I thought the reason was to verify that the release works under
tension.
Bart
Old August 24th 12, 08:22 PM posted to rec.aviation.soaring
Martin Gregorie[_5_]
On a CG hook you need to check that back-release works. On the hook types
that I understand mechanically (Tost, Ottfur), the back release has
separate springs and moving parts from the tension release.
Its normal in UK clubs to check back release, free drop (CG hooks) and
tension release (all hooks) before the first flight of the day on that
hook. For subsequent flights its assumed that the hook works since it was
tested by the last flight.
martin@ | Martin Gregorie
gregorie. | Essex, UK
org |
Old August 25th 12, 04:14 AM posted to rec.aviation.soaring
Andreas Maurer
On Fri, 24 Aug 2012 10:25:49 -0700 (PDT), "kirk.stant"
I can.
1. Three weeks ago we had an accident at an airfield close to us where
the pilot was very, very lucky.
He did a winch tow in an ASW-19. The small ring of the tow cable was
not put into the tow hook, but jammed between the Tost release and its
steel attachement structure, creating an extremely strong and
permanent connection. Mistake of the student pilot who did the hookup.
After the pilot had (thought he had) released at about 1200 ft, he
turned into left downwind. After passing the winch the tow cable went
tense and pulled the ASW-19 into a ballistic arc towards earth - the
emergency cutter on the winch didn't work either.
The pilot estimates that the remaining time till impact was about 5-10
seconds.
Only chance for the pilot was to apply aileron and turn towards the
winch (nose still being pulled into a dive), which fortunately worked.
He flew over the winch at an altitude of about 300 ft and then tried
an extremely tight turn in order to land next to the winch. Just as he
was on final, the tow cable got tangled in some bushes, the ASW-19 got
a nose-down impulse, impacted hard from about 25 ft and was damaged
very badly.
Fortunately, the pilot escaped unhurt - even those old Schleicher
gliders are built incredibly strong.
Time from first inkling of the problem till impact 37 seconds.
Time from noticing the problem (rapide nose-down impulse) till
possible bail-out, estimated by the pilot: None. Bailout not possible.
A release check would have prevented this accident (of course, the
next hookup might have resulted in the same mistake...).
2. I know of a number of incidents where it was possible to hook up
the tow cable, but release failed when it was attempted to release the
cable under tension (on of these cases happened to me in a Ka-8 when I
was a student pilot, fortunately the back release worked). Usual cause
was wrong ring on the tow cable and mechanical prblem in the glider
concerning the control cable to the Tost release.
Lections learned:
If you are the one who's doing the hookup:
- LOOK at the tow release when you put the ring in
- Check the ring if it fits perfectly (it should have just a little
play)
- Check the release mechanism under tension
- Check the emergency release of the winch. Often. We checked ours
imediately after we heard about the accident, and only one of two
emergency cutters worked (the other was stopped by very little dirt
that had collected in the mechanism during the last 6 months). We were
quite surprised how little dirt it takes to block the cutter (ours has
got a force of about one ton to cut our steel cable).
And, of course
- Never, never use rings that are not approved by Tost
- Never, never mess with a Tost release
Cheers
Andreas
Old August 25th 12, 04:51 AM posted to rec.aviation.soaring
Tom Claffey
No amount of release checking will avoid a wrongly hooked on rope.
Standard reply is:
"My release was checked yesterday"
wrote:At 02:14 25 August 2012, Andreas Maurer wrote:
On Fri, 24 Aug 2012
separate
release check?
I can.
seconds.
very badly.
Lections learned:
play)
And, of course
Cheers
Andreas
Old August 20th 13, 11:49 AM posted to rec.aviation.soaring
Surge
Snip
Snip
play)
Snip
Cheers
Andreas
The club I fly at do the three checks for the CG hook for winch launching and a single tension release check for aero tows on the nose hook.
What I'd like to highlight is that you're the only person in this thread who has mentioned checking for play once the ring is inserted.
We have a standard "rattle check" on hookup.
If the ring does not rattle from side to side once hooked up it is assumed to be jammed from being inserted wrongly and is thus released and reinserted.
Paul
Old August 26th 12, 11:49 PM posted to rec.aviation.soaring
Andy[_1_]
On Friday, August 24, 2012 10:25:49 AM UTC-7, kirk.stant wrote:
Finally! I've been refusing to do release checks for years and get the stink-eye everytime. I've tried explaining that if you can hook up, then you have checked as much as you can, but still get people saying "but what if it fails?".
Kirk
66
Old August 27th 12, 02:00 AM posted to rec.aviation.soaring
Chris Nicholas[_2_]
‘No amount of release checking will avoid a wrongly hooked on rope.
Standard reply is: "My release was checked yesterday" .’
It can do. If the ring is wrongly inserted, then all three checks are likely to expose it, which ever us done first: free drop, back release, and under tension.
These will also catch other things that may not have applied “yesterday” – different (and now wrong) ring, or damaged ring, or damage to part of the release or the cable mechanism that still allows hook up to some extent but precludes release when needed. There have been examples of all these over the years, hence the development of the three checks. Not doing them is volunteering to have some holes in the Swiss cheese.
Chris N.
Old August 31st 12, 04:39 PM posted to rec.aviation.soaring
On Friday, August 24, 2012 1:25:49 PM UTC-4, kirk.stant wrote:
Finally! I've been refusing to do release checks for years and get the stink-eye everytime. I've tried explaining that if you can hook up, then you have checked as much as you can, but still get people saying "but what if it fails?". Maybe one of you smart guys out there can explain the logic of a separate release check? Kirk 66
Your logic seems fine if you are flying a glider with a Tost hook that you must open in order to connect the tow rope.
But- you may be teaching the line crew not to doa check which may appy to other gliders.
Examples:
1)Tost Hook with back release can be connected by someone who knows how without the pilot pulling the knob. What if the release cable is broken or jammed?
2) Schweizer hooks are easily hooked up without pulling the knob. Same question about cable.
3) Some hooks are externally operated to hook up. 1-35, HP series, others I don't know about. Verifying functionality would seem to be wise.
I happen to tow out to the line on a rope. Releasing acts as my functional test and I don't do another at launch. I encourage our pilots to do the same to save a bit of time at launch, but ask them to tell the line person that the release check has been done.
FWIW
UH
Anyone have a Tost release? noel.wade Soaring 5 June 10th 10 05:36 AM
Tost E85 release on Birddog Doug[_4_] Soaring 0 February 18th 10 07:08 PM
FS Tost E85 Release scooter Soaring 0 March 7th 06 03:31 AM
FS Tost E85 Release scooter Soaring 0 November 22nd 05 02:11 AM
Tost release on L-19? Roy Bourgeois Soaring 2 November 29th 04 11:24 PM
