Butterfly external display questions
Old September 14th 12, 02:47 AM posted to rec.aviation.soaring
kirk.stant
Default Butterfly external display questions
On Thursday, September 13, 2012 4:49:06 AM UTC-7, Marc - Butterfly Avionics wrote:
Sure this is possible, I'll add this to our wishlist for the next release.
Marc, we appreciate your responses. Looking forward to the maturation of the software.
If I may, here are a couple more items for your wishlist:
1. Add ability to change the time display from UTC to UTC+/-n, where n allows the pilot to adjust for the local time. A really nice touch would be the ability to specify 12 or 24 hour display, and to make the clock font about 3 times bigger (yeah, the cute butterfly would have to be smaller...
2. The font for the PCAS altitude needs to be bigger. And it would be nice if the closest PCAS target range would be shown in digits, centered on the right side/bottom of the display. If PCAS targets/info were always shown in color - blue above, red +/- 500', green below, it would be easy to associate the range with the PCAS target, when there was also FLARM or ADS-B target info displayed (in black).
3. The PCAS range ring needs to be 2x thicker, and in color.
4. The option to have one short beep anytime a new threat is displayed, regardless of type.
In the US, PCAS threats are a significant concern, ergo the emphasis on their display characteristics.
Thanks,
Kirk
66
Old September 14th 12, 03:46 AM posted to rec.aviation.soaring
Brian[_1_]
One more wish list for the PCAS display but may require an upgrade from the Powerflarm as I don't know if it sends the Transponder code.
Would be nice on the PCAS Target it showed distance (as already requested) but would also be nice if it showed the the Transponder code. would be nice to know if the transponder is transmitting 1200, 1202, or an ATC assigned code.
Brian
Where are you Butterfly vario? [email protected] Soaring 17 May 25th 14 06:49 AM
Butterfly iGlide Reed von Gal Soaring 4 May 2nd 12 07:00 PM
New Butterfly Vario Paul Remde Soaring 238 February 20th 12 05:05 AM
This Just In- Butterfly [email protected] Soaring 6 February 17th 12 10:00 PM
Ipad compatible bluetooth GPS which has an external antennasocket and external pwr input? macpacheco Instrument Flight Rules 1 November 12th 11 04:32 PM
