New Butterfly Display Software 3.2.1 released
Old August 13th 13, 06:26 PM posted to rec.aviation.soaring
Ramy
Default New Butterfly Display Software 3.2.1 released
I am aware of orhers who have the same issue. I have the in panel display and havent noticed this issue so maybe iy affects only the rectangular displays. Perhaps the most important enhancement in this version and the main reason to upgrade once the reboot issue is resolved is the short beep to alert whenever Powerflarm detects new traffic (screen switches from butterfly to radar). This significantly improves situational awarness.
Ramy
Old August 13th 13, 09:18 PM posted to rec.aviation.soaring
Andy[_1_]
What oriemtation is your display?
What target type was displayed when the reset loop was active?
Andy
Old August 13th 13, 10:33 PM posted to rec.aviation.soaring
Dan Daly[_2_]
Vertical. Displaying one FLARM target, one transponder, no ADS-B.
Old August 14th 13, 11:14 AM posted to rec.aviation.soaring
Marc - Butterfly Avionics
Dear All,
thanks a lot for your feedback. Sorry for the kind-of-late response, partly our team is on vacation and I also have been away for 3 days (eMail support is always available and Joachim and the team will answer all questions of course).
As a first workaround, please downgrade to version 3.2, download he
- update softwa http://www.butterfly-avionics.com/support/BD32.zip
- PF update file: http://www.butterfly-avionics.com/support/bfd_3_2.bfw
We guess that the issue only occurs in portrait mode in the external version of the display. We will release a bug-fix as soon as we have found the problem.
Sorry fore the trouble, best regards
Marc
Old August 15th 13, 05:27 PM posted to rec.aviation.soaring
Hi Guys,
we found the bug and it is resolved in the latest version. The bug appears in portrait mode and only with "feet" set up as units for relative altitude.
We are going to release the new version as soon as we hear positive results from our testers. If you wish to test this not released BETA version, please download it he
- update softwa http://www.butterfly-avionics.com/su...3_2_2_2332.exe
- PF update file: http://www.butterfly.aero/support/bfd_3_2_2_2332.bfw
I look forward to receiving your feedback!
Best regards and thanks for the quick feedback and help in finding this
Marc
Disclaimer: The version posted is BETA (that is unfinished and untested software) and may not work as expected. Only test it if very familiar with your aircraft and in low traffic situations. If you experience an increase in workload due to testing, switch your collision warning unit off.
Old August 15th 13, 11:21 PM posted to rec.aviation.soaring
Hi Marc
Thanks for the quick follow-up.
I will test this weekend and report back.
ThreeUniform.
Old August 16th 13, 07:40 AM posted to rec.aviation.soaring
Andy[_1_]
Loaded beta. Observed FLARM, PCAS, and ADS-B targets in various combinations while in knob at bottom orientation. No resets seen.
Thanks,
Andy
Old August 16th 13, 06:55 PM posted to rec.aviation.soaring
Andy[_1_]
On Thursday, August 15, 2013 10:40:28 PM UTC-7, Andy wrote:
Loaded beta. Observed FLARM, PCAS, and ADS-B targets in various combinations while in knob at bottom orientation. No resets seen. Thanks, Andy
p.s.
Why is plus sign blue (cyan?) but minus sign is black? Why would the sign be a different colour from the number it is associated with?
Andy
Old August 17th 13, 04:57 AM posted to rec.aviation.soaring
Luke Szczepaniak
Marc, I flew with 3.2.2 today, seems to work fine.
Luke
Old August 19th 13, 06:58 PM posted to rec.aviation.soaring
Same here.
3.2.2 seems to work fine (2 flights this weekend)
Thank Marc for the quick resolve.
With respect to the sign:
In my opinion, the plus sign is redundant.
It would be clearest if there was only a minus sign in case of negative altitude difference and no sign in case of positive altitude difference.
New Butterfly Display Software 3.2 Marc - Butterfly Avionics Soaring 36 March 8th 15 09:16 PM
Flarm Butterfly display [email protected] Soaring 10 May 6th 13 06:40 PM
Updating Software on Butterfly 57 mm version 2.1 display w/o Cable? 3Y Soaring 7 December 31st 12 01:50 PM
Butterfly external display questions Andy[_1_] Soaring 30 October 15th 12 08:20 AM
Free Software GPLIGC 1.5 released Hannes Soaring 2 June 14th 05 02:45 PM
