My friend is gone
Old November 23rd 03, 06:25 PM
Yosimite Sam
Default My friend is gone
Today, while cutting my panel for the intercom, my little pal, Mr. Dremel
coughed a puff of smoke and the RPM's quickly bled off and the cutting blade
came to a final stop. 8 years old and nearly two Kitfoxes complete. By far,
the most valuable and most used tool. I can just hope that my life will be
as productive as Mr. Dremels' has been.
Yosimite Sam
Old November 23rd 03, 06:57 PM
Jerry Springer
Yosimite Sam
Geez, did you sleep with it also?
Old November 23rd 03, 07:17 PM
RobH
"Yosimite Sam" wrote in message
news:a46wb.286512$Fm2.295412@attbi_s04...
blade
far,
Yosimite Sam
A sad day indeed. Mine was resurrected twice with new brushes.
Old November 24th 03, 12:03 AM
Eric Miller
"Jerry Springer" wrote in message
link.net...
Dremel
blade
far,
be
Yosimite Sam
Dremels come with ALL sorts of attachments =D
Old November 24th 03, 05:31 AM
Jerry Wass
!doctype html public "-//w3c//dtd html 4.0 transitional//en"
html
pRobH wrote:
blockquote TYPE=CITE"Yosimite Sam" wrote in message
bra href="news:a46wb.286512$Fm2.295412@attbi_s04"news :a46wb.286512$Fm2.295412@attbi_s04/a...
br Today, while cutting my panel for the intercom, my little pal, Mr.
Dremel
br coughed a puff of smoke and the RPM's quickly bled off and the cutting
brblade
br came to a final stop. 8 years old and nearly two Kitfoxes complete.
By
brfar,
br the most valuable and most used tool. I can just hope that my life
will be
br as productive as Mr. Dremels' has been.
br
br
br --
br Yosimite Sam
br
pA sad day indeed. Mine was resurrected twice with new brushes./blockquote
pbrThat was my first thought...Did you perform an autopsy???? was it
cooked
brcoils--or burned brushes---possibly  boogered bearings???---could
be a
brcrapped out cord..
br /html
Old November 24th 03, 11:23 AM
Yosimite Sam
That was my first thought...Did you perform an autopsy???? was it cooked
coils--or burned brushes---possibly boogered bearings???---could be a
crapped out cord..
Cooked coils....
Yosimite Sam
Old November 24th 03, 02:12 PM
Model Flyer
"Eric Miller" wrote in message
t...
link.net...
Mr.
Lol, that's really funny.:-)
Jonathan
Old November 24th 03, 02:13 PM
Model Flyer
news:1%kwb.290813$Tr4.922372@attbi_s03...
cooked
be a
crapped out cord..
Cooked coils....
If nothing else is damaged, why not rewind it?
Cheers,
Jonathan Lowe.
don't bother me with insignificiant nonsence such as spelling,
I don't care if it spelt properly
Sometimes I fly and sometimes I just dream about it.
Yosimite Sam
Old November 24th 03, 07:13 PM
RobertR237
In article 1%kwb.290813$Tr4.922372@attbi_s03, "Yosimite Sam"
writes:
crapped out cord..
Cooked coils....
I have gone through three of the little buggars and all three failed in the
switch, not the brushes or bearings.
Bob Reed
www.kisbuild.r-a-reed-assoc.com (KIS Builders Site)
KIS Cruiser in progress...Slow but steady progress....
"Ladies and Gentlemen, take my advice,
pull down your pants and Slide on the Ice!"
(M.A.S.H. Sidney Freedman)
Old November 24th 03, 09:17 PM
Del Rawlins
On 24 Nov 2003 09:13 AM, RobertR237 posted the following:
in the switch, not the brushes or bearings.
I had a brand new one which ran for about 10 seconds out of the box, and
then died due to a faulty switch.
Not counting defective part failures, I have a tough time seeing how I
could possibly wear mine out, as little use as it sees. For the things
I use it for, nothing else will really do but otherwise it often doesn't
come out of the toolbox for months at a time. I believe that if you
find yourself using a dremel tool that much you need to consider buying
some real tools (i.e. bigger grinders) since the dremel isn't really
suited for continuous use. Not to mention the extra time spent since
using the dremel is slow compared to a larger grinder or cut off tool.
I have a pair of 1/4" electric die grinders (one I bought, then got
another for christmas) each with a different bit, a couple of angle
grinders, a 3" cut off tool in addition to my normal bandsaw, hacksaw,
and bench grinder/sander. If none of those will do the job, only then
does the Dremel come out.
Del Rawlins-
Remove _kills_spammers_ to reply via email.
Unofficial Bearhawk FAQ website:
http://www.rawlinsbrothers.org/bhfaq/
Proposed new flightseeing rule C J Campbell Home Built 56 November 10th 03 06:40 PM
