Auto-Towing - why is this not more popular?
Old October 5th 15, 05:56 PM posted to rec.aviation.soaring
Dan Marotta
Default Auto-Towing - why is this not more popular?
At the Las Vegas tow weekend, they have a release mounted to the
receiver of the vehicle and the release rope routed to the observer.
On 10/5/2015 8:11 AM, wrote:
On Monday, October 5, 2015 at 7:40:06 AM UTC-5, Papa3 wrote:
On Monday, October 5, 2015 at 8:30:06 AM UTC-4, Tango Eight wrote:
When I was a student pilot, we did 2-33 "cat shots" off Harris Hill with two old tow ropes spliced together, later with a proper 400' cable, into gentle late afternoon ridge lift, all powered by an old 307 Chevelle with questionable brakes (thanks Dave!). A total gas, never to be forgotten. Driving the car (which I did a lot) was even more exciting than flying the glider. The brow of the hill slopes off in a fashion that makes the nerves a little uneasy... especially with those rusty four wheel drum brakes.
-Evan Ludeman / T8
That reminded me. The far end of our runway had a steep dropoff into a corn field. On one tow, as I eased off the gas and got on the brakes... there weren't any. Or not much. Went all Dukes of Hazard and luckily landed safely on the downslope, ending up with the hood in the corn. Funny now, but actually a pretty dicey situation. So driver/observer safety in the tow vehicle is definitely another consideration depending on the field conditions/configuration.
All the winches I flew on in Europe had guillotines to cut the cable in an emergency (mandated in Germany). How do you do that with cars? I witnessed a near fatal accident with hanglider being towed by a car where the pilot flew a neat arc that ended with an impact. When I asked the person on the bed of the towing pickup how he had planned to sever the rope in such an event, he showed me his pocket knife!
Dan, 5J
Old October 5th 15, 07:27 PM posted to rec.aviation.soaring
Sean Fidler
Wow! Great posts. I'll need time to read it all. Thanks.
We have an auto-tow rig in Ionia that has been used on rare occasion. Recently, a clinic was done in Cadillac and it was quite successful from what I understand. A number of people got sign offs, etc. But then it died again.
Old October 5th 15, 07:41 PM posted to rec.aviation.soaring
IIRC, in the old days a ground launch signoff was required before the commercial glider test. We would do it once a year at the Soaring Society of Dayton (now Caesar Creek Soaring Club) at our Richmond, IN airport, which had 3 paved runways, including two with paved taxiways that we operated off of. 5000-5500'. This was the late 1960s and the age of the big block V-8 horsepower wars so someone always seemed eager to volunteer their vehicle to show it off (probably not a second time, though). We got high enough to do a full pattern in a 2-22. Because it conflicted with our normal ops, we tended to pick an overcast day, fairly calm. A Schweizer tow hook was mounted on the hitch ball and someone sat in the back to pull the cord if necessary. I don't think it was hinged to track the wire direction so I suspect it would have been difficult to release under load. The only drama was how fast the glider climbed compared with aerotow. The biggest problem was the old wire breaking every few tows. It was a big deal to lay everything out and splice the wire a few times so we never did it more than was necessary to get the ground launch sign off for whomever was going up for their test.
I've had a couple of auto pulley tows. Wild! Aileron control before the wing runner even takes a step. These were just to get high enough from a grass strip to turn out over the ridge so I don't know what it's like for a full tow.
Chip Bearden
ASW 24 "JB"
U.S.A.
Old October 5th 15, 04:22 PM posted to rec.aviation.soaring
Steve Leonard[_2_]
We do some auto towing at Sunflower in Kansas. Ex Military base, 7000 foot long runway. Surface is roughly the equivalent of The Great Barrier Reef as far as the rope is concerned. The majority of the wear seems to happen when dragging the rope back after the launch, as it does not take too long for all 2000 or so feet to be off the ground. We have cracks in the pavement that has some grass growing up through them, so you can reduce the wear some by pulling the rope back with it in/on that grass. We do not put a chute on the rope, but just let it fall. The fun comes in turning the car around, and trying to be within 50 feet of the end of the rope when it hits the ground. Yep, I have done it. With a full size Chevy G-20 van!
Another option that has been used is a wind up winch on the tow vehicle. Once the vehicle is stopped, the crew goes to the back, operates the wind up winch (have seen both gas and electric version), then drive back, and lay out the rope again.
Pay Out winch probably works better for hang gliders than for our sailplanes, as the car has to go faster than the glider in order to pay out any line.. And in light winds, the glider may need the car to run 60 MPH or more for straight towing, so even faster for pay-out towing. Faster yet for higher elevations (Sunflower is 1500 feet MSL). Gary Boggs has used a pay-out system quite successfully, so it is not impossible to do. Just maybe not so good for the planes that need a bit more speed, unless operating from a drive lakebed.
Fixed pulley at the upwind end opens up lots of possibilities. Especially since the glider can no longer pick up the tow car! Bring on the Z06 Corvettes if you have got pavement! You wanted winch acceleration, now you have got it!
As to wear and tear on the vehicle and its drive train, do an auto tow with a vehicle with an auto transmission that also has a tachometer. Then, drive in the same gear (count shifts from start) at the same speed without the load of the glider. You will probably discover that the torque converter is not locked up when launching the glider (much higher RPM during the glider tow). So, you are generating a lot of extra heat in the transmission on each tow. Best bet for auto tow would be a big block with a manual transmission, and ability to start out in second gear, so you don't have to shift..
It is fun. Get a new car. Get the extended drive train warranty. When the tranny goes out, don't mention you have been launching gliders. :-)
Steve Leonard
Old October 5th 15, 04:51 PM posted to rec.aviation.soaring
On Sunday, October 4, 2015 at 10:57:33 PM UTC-6, Sean Fidler wrote:
I had an interesting conversation with a pal about auto-tow glider launching method recently. It seems academic really.
When cost is considered, auto-towing has to be far more affordable than even winching. Maybe $1.50 per tow, max? In aviation, the cost is always critical. Especially in gliding club environments. Aerotows are $30-50 per tow. Winches are extremely expensive to purchase, to maintain, and insure and require skilled operators.
Auto-tow procedure seems fairly simple. 1) Steady strong acceleration until the glider comes airborne, then 2) add 5mph and 3) hold that speed until you hear differently from the pilot. Of course, 4) stop at the end of the runway :-).
Why is auto-towing not a mainstream method of getting gliders airborne?
I saw auto-towing happen regularly at Hobbs this year (my first visit). It was quite graceful and almost exotic. To be honest, it looks even more fun than winching.
I am very interested in learning what you know, your thoughts and your opinions.
Sean
7T
Sean, I've done a lot of both auto tows and winch launches. The low cost of auto tow is illusionary because people tend to ignore the costs associated with the tow car. Auto towing is really, really hard on a car. Modern gliders need 60 - 65 knots to safely rotate into the climb phase so the tow car is doing full throttle 0 - 75 mph on every tow followed by maximum effort braking to stop. It's basically drag racing so maintenance and tire replacement become a huge cost. Auto tow operations typically use a noob's car - until the owner figures out the wear and tear his vehicle is subject to..
As other poster pointed out, it also takes a LOT of room. To get decent height you need a long rope which takes up a large chunk of runway before anything gets rolling. Then, you need the acceleration distance for the car before the glider can start the climb. Finally, the tow must end so as to leave enough distance for the tow car to stop before running off the end of the runway.
If unlimited space is available as on Mojave dry lakes, then auto tow sorta makes sense but with any runway less than 5500 feet long, winches will get you higher and cost you less money doing it.
Old October 5th 15, 05:10 PM posted to rec.aviation.soaring
Dan Marotta
Not quite as exciting as winching since the power to weight ratio is
less but as effective if you have the room. Still, it's a heck of a lot
of fun! Definitely cheaper than a winch since somebody always has a
capable vehicle.
I've been on two ground launch safaris with my partner and our LS-6a.
We used his Jeep Grand Cherokee once and my Ford F-150 the other time.
We would take turns flying and driving (pulling the trailer) and every
flight was a straight out adventure. Everywhere we went we were well
received by airport management and never had problems with departing any
airport. Over 6-8 days we would fly a large circuit around the
southwest USA.
I'll be ground launching off of Roach Dry Lake south of Las Vegas, NV in
a couple of weeks during the LVVSA's twice annually ground launch
weekend. What a hoot!
Dan, 5J
Sean
7T
Dan, 5J
Old October 5th 15, 05:14 PM posted to rec.aviation.soaring
The Douglas County Composite Squadron (Minden) of CAP has one or two auto-tow clinics every year. We find them a good way to introduce ground launch operations to the CAP members, but also find them pretty labor intensive, hard on tow vehicle and rope, and more of a novelty than a good way to launch gliders.
By labor intensive, I mean we have at least three people in the tow vehicle (a 4WD pickup truck with auto transmission in tow mode so it doesn't try to shift into 4th gear). The three people are driver, person beside driver who communicates with glider and launch crew, and person in the back who can release the rope in an emergency or at the end of the run. Then we have a wing runner, a signal person beside the wing runner to communicate between the truck and the glider, and a driver for a retrieve vehicle that hooks onto the glider end of the rope to pull it back to the launch position. That's a lot of people, and we could ideally operate with one or two less, but in CAP we want to involve everyone.
We use a 2000' long rope on a 6000' long runway (we actually use a hard dirt area beside the runway because there are lights on the runway that would suffer if we tried to auto tow there). We generally get 900-1100' altitude on launch, depending on wind and the pilot's skill. We have a specially fabricated tow hook that fits into the truck's receiver hitch. It has a swivel so the hook is always aligned with the rope and a Tost release at the end.
Having the pilot drop the rope where it will fall over the tow area is essential for us, as we have obstacles to each side (runway lights to the north and a chain link fence to the south). I remember one retrieve when the pilot dropped the rope in such a place that the wind carried it over the chain link fence. That one lasted one and a half hours.
Despite the fact that most flights are 5-10 minutes long (we are, after all, practicing launch, not soaring) we generally don't get more than 15 launches out of an 8 hour day. I think the most we've ever gotten was 25 launches. That gives you an idea of how long staging, launching, retrieving and re-staging takes. Not as efficient as we might be, but we've been doing it for 3 years so we aren't neophytes at it.
Bottom line for me: it is a good way to introduce CAP members to a different method of launch, and it adds a lot of flights to the glider (CAP wants us to get 200 flights a year in order to keep the glider), but it has its own limitations and is not quite as easy as it might sound.
Fred
Old April 16th 16, 03:07 PM posted to rec.aviation.soaring
Candid Sky Productions
Fred why not go to or get permission for the dry lake down the road in stagecoach? Years ago they ran auto tow at that spot. And I'd think you can do better at SS airport that what your saying. If you us a diesel truck and have someone that knows how to drive, stick would be better but no matter you negate most of the wear issues. Or just someone that isn't afraid to put there foot in it after the initial roll out.
A g20 van is really a pos when not towing going down the road. :-)
Old October 5th 15, 11:14 PM posted to rec.aviation.soaring
WB
Auto launching can be an economical, if laborious, way to get gliders in the air. My club used to do a lot of auto and winch launching. We did hundreds of auto launches and thousands of winch launches. For auto launch, we used the "pulley in the middle" system with the pulley on the to car, pulling from the middle of the rope. We used about 4000 feet of dacron line. 2:1 mechanical advantage of this system meant that the tow car never had to exceed 28 mph. With 10 mph headwind, our Ka-8 sometimes achieved launches of 2000' agl. We usually got 1400-1600' with the Ka-7 and ASK-21. The tow car was an old Ford Crown Vic that came from a junk yard. We had around 300-400 lbs of bricks in the trunk to keep the wheels from spinning in the later stages of a launch. I think it only ran on 5 cylinders, but it produced about the perfect amount of power for launching the 2 seaters. Put it in low gear and just push the accelerator smoothly to the floor. The glider would be airborne in about the same distance as a winch launch. The car would get to about 28 mph and by then the glider was beginning to pitch up. With the pedal all the way to the floor, a 2-seater glider in a steep climb would begin to slowly decelerate the car. This resulted in launches with very close to the perfect speed in the climb. We would be down below 25 mph with the glider at the top of the launch. Letting off the gas made for a very short stop.. The rope usually back released at that point. Made it easy peasy to launch two seaters. With the single place birds, we'd have to go a little easier on the throttle to keep speed below 30 at the car. Still, it was very easy to drive the launch as long as the pilot pitched up correctly.
Recovery of the rope was a bit fiddly and was the time consuming part of it all. We were at the end of the runway at the end of the launch, so we could not continue on to pull the rope down to the car. The rope just fell wherever. We had no chute on it anyway. We'd recover and straighten the line by putting it back on the pulley then having the anchor vehicle tow the other end of the rope to the launch point. We could do a launch every 10 minutes if we hustled. Usually it was more like 15 minutes per launch.
We always had two people in the car. A driver and an observer. The observers job was to keep an eye on the glider and relay info to the driver. The observer also had a very sharp machete with which to cut the rope should the glider be unable to release.
Our pulley system was just a truck wheel mounted on a steel arm that fit into an hitch receiver.
Old October 5th 15, 11:53 PM posted to rec.aviation.soaring
Ramy[_2_]
Auto launching can be an economical, if laborious, way to get gliders in the air. My club used to do a lot of auto and winch launching. We did hundreds of auto launches and thousands of winch launches. For auto launch, we used the "pulley in the middle" system with the pulley on the to car, pulling from the middle of the rope. We used about 4000 feet of dacron line. 2:1 mechanical advantage of this system meant that the tow car never had to exceed 28 mph. With 10 mph headwind, our Ka-8 sometimes achieved launches of 2000' agl. We usually got 1400-1600' with the Ka-7 and ASK-21. The tow car was an old Ford Crown Vic that came from a junk yard. We had around 300-400 lbs of bricks in the trunk to keep the wheels from spinning in the later stages of a launch. I think it only ran on 5 cylinders, but it produced about the perfect amount of power for launching the 2 seaters. Put it in low gear and just push the accelerator smoothly to the floor. The glider would be airborne in about the same distance as a winch launch. The car would get to about 28 mph and by then the glider was beginning to pitch up. With the pedal all the way to the floor, a 2-seater glider in a steep climb would begin to slowly decelerate the car. This resulted in launches with very close to the perfect speed in the climb. We would be down below 25 mph with the glider at the top of the launch. Letting off the gas made for a very short stop. The rope usually back released at that point. Made it easy peasy to launch two seaters. With the single place birds, we'd have to go a little easier on the throttle to keep speed below 30 at the car. Still, it was very easy to drive the launch as long as the pilot pitched up correctly.
At least in most soaring sites in California, auto towing (as well as winch) will provide affordable sled rides at best. The lift is typically in the mountains 5-30 miles away. The only exceptions I can think of is Avenal and maybe Crazy Creek.
Ramy
Auto-towing? Cost...about $1.50 per tow? Why is this launchingtechnique not more popular? Sean Fidler Soaring 7 October 6th 15 12:24 AM
(OT) Popular Mechanics, 1935 Mark IV[_6_] Piloting 0 November 18th 12 05:40 PM
Auto Towing the LVVSA G103 (YouTube video) jim wynhoff Soaring 0 May 26th 12 04:25 AM
Auto Towing 2 Place Gliders [email protected] Soaring 11 April 21st 06 06:10 AM
Flying IS popular Jay Honeck Piloting 22 February 19th 04 05:06 PM
