people sure like to over think things. The same prop can be put on any
engine of any horse power and if it is turned 2300 rpm then the thrust is the same. -- Have a good day and stay out of the trees! See ya on Sport Aircraft group http://groups.yahoo.com/group/Sport_Aircraft/ Flying Gators annual Fly-in http://www.mitchellwing.com/flying_g...annual_fly.htm |
"Gilan" wrote ...
people sure like to over think things. The same prop can be put on any engine of any horse power and if it is turned 2300 rpm then the thrust is the same. Not necessarily. If one of the engines has a larger frontal area then part of the flow will be blocked and that engine/prop will produce less thrust. The extreme example is the engine that's larger than the prop diameter. Rich |
there you go thinking again.
you just added something into the question that wasn't there Just stick to the original question and the answer is still the same. -- Have a good day and stay out of the trees! See ya on Sport Aircraft group http://groups.yahoo.com/group/Sport_Aircraft/ |
He got a point!
"Gilan" wrote in message nk.net... there you go thinking again. you just added something into the question that wasn't there Just stick to the original question and the answer is still the same. -- Have a good day and stay out of the trees! See ya on Sport Aircraft group http://groups.yahoo.com/group/Sport_Aircraft/ |
In article , Mark says...
Does a prop turning at 2300 rpm on a 150hp motor produce more thrust than a prop spinning 2300 rpm on a 100 hp motor ? If it's the same prop and it turns 2300 on a 150 hp engine the 100hp engine won't have the power to turn it 2300. If it turns 2300 on the 100 hp engine then the 150 hp engine will over rev it and run away the prop. At 2300 rpm the prop will produce the same thrust regardless of engine but the 150 hp engine would really like a bigger prop to use the remaining 50 hp. see ya Chuck (ain't no free ride in airplanes) S |
In article , ChuckSlusarczyk
writes: Does a prop turning at 2300 rpm on a 150hp motor produce more thrust than a prop spinning 2300 rpm on a 100 hp motor ? If it's the same prop and it turns 2300 on a 150 hp engine the 100hp engine won't have the power to turn it 2300. If it turns 2300 on the 100 hp engine then the 150 hp engine will over rev it and run away the prop. At 2300 rpm the prop will produce the same thrust regardless of engine but the 150 hp engine would really like a bigger prop to use the remaining 50 hp. see ya Chuck (ain't no free ride in airplanes) S Ah Hell Chuck, you missed the point of the question here. The thrust produced will remain the same in both instances regardless of the engine horsepower. If indeed the 100hp engine is turning the prop at 2300 rpm and requires the full 100 hp to do so, the 150 hp engine is not producing full power to turn the prop. A 1000 hp engine turning the same prop at the same rpm will still produce the exact same thrust. Bob Reed www.kisbuild.r-a-reed-assoc.com (KIS Builders Site) KIS Cruiser in progress...Slow but steady progress.... "Ladies and Gentlemen, take my advice, pull down your pants and Slide on the Ice!" (M.A.S.H. Sidney Freedman) |
"RobertR237" wrote Ah Hell Chuck, you missed the point of the question here. Bob Reed I don't think the OP was asking a trick question. While you and I understand the relation between thrust and HP, I do not think the OP has a grasp on it. What was not said, was, "if I use the correct prop to get 2300 RPM at full power, will the 100 HP and 150 HP engine have the same thrust?" On the other hand, I could be reading too much between the lines, and could be completely wrong. If so, "never mind" :-) -- Jim in NC |
In article , "Morgans"
writes: Ah Hell Chuck, you missed the point of the question here. Bob Reed I don't think the OP was asking a trick question. While you and I understand the relation between thrust and HP, I do not think the OP has a grasp on it. What was not said, was, "if I use the correct prop to get 2300 RPM at full power, will the 100 HP and 150 HP engine have the same thrust?" On the other hand, I could be reading too much between the lines, and could be completely wrong. If so, "never mind" :-) -- Jim in NC Now that is an entirely different question and the answer is likewise entirely different. I was not reading anything extra into the original question (for a change) and the answer would be no difference. Bob Reed www.kisbuild.r-a-reed-assoc.com (KIS Builders Site) KIS Cruiser in progress...Slow but steady progress.... "Ladies and Gentlemen, take my advice, pull down your pants and Slide on the Ice!" (M.A.S.H. Sidney Freedman) |
In article , RobertR237 says...
Ah Hell Chuck, you missed the point of the question here. The thrust produced will remain the same in both instances regardless of the engine horsepower. If indeed the 100hp engine is turning the prop at 2300 rpm and requires the full 100 hp to do so, the 150 hp engine is not producing full power to turn the prop. A 1000 hp engine turning the same prop at the same rpm will still produce the exact same thrust. Ah hell Bob,I guess I don't see what point I missed :-) Seems we're both saying the same thing. Given it's the same prop on both engines and the prop is turning 2300 rpm it will always produce the same thrust at that rpm regardless .However if you start to open the throttle the 1000 hp engine it will turn faster and produce more thrust because it has the power to do so...But the prop will be spinning faster than 2300 . Maybe I'm not understanding the question. See ya Chuck (time for Beany) S |
writes: Ah hell Bob,I guess I don't see what point I missed :-) Seems we're both saying the same thing. Given it's the same prop on both engines and the prop is turning 2300 rpm it will always produce the same thrust at that rpm regardless .However if you start to open the throttle the 1000 hp engine it will turn faster and produce more thrust because it has the power to do so...But the prop will be spinning faster than 2300 . Maybe I'm not understanding the question. See ya Chuck (time for Beany) S Depends on rather you answer the question as written or read more into it. Answering the question directly as written the answer is both would produce exactly the same thrust. If the question however asked which was capable of producing more thrust, the answer changes. Bob Reed www.kisbuild.r-a-reed-assoc.com (KIS Builders Site) KIS Cruiser in progress...Slow but steady progress.... "Ladies and Gentlemen, take my advice, pull down your pants and Slide on the Ice!" (M.A.S.H. Sidney Freedman) |
| Stupid super cub question | Robert Loer | Home Built | 9 | November 22nd 03 06:28 PM |
| Tecumseh Engine Mounting Question | jlauer | Home Built | 7 | November 16th 03 02:51 AM |
| question about EZRocket | David O | Home Built | 6 | October 1st 03 07:03 PM |
| Question on Pulsejets/Ramjets??? | DarylG1532 | Home Built | 3 | August 16th 03 04:20 AM |
| Question - Regarding Canard Pushers... | Tilt | Home Built | 33 | August 10th 03 12:07 PM |
