To quote Bill Clinton, "It depends on what your definition of what thrust
is"? ![]() Damn, I've never read so much BS for a simple question. ![]() |
Hi All, thanks for the responses, was not meant to be a trick question but
definately a newbie question. I was curious after reading about people using mazda 13b engines for various homebuilts, and porting them, adding on various components to boost the hp from 200 to 260+. Seems at a point that it's overkill if the 200 hp engine is going to provide you with the needed ponies and rpms to accomplish the same as the 260 hp engine. What would the advantge be of having the extra horsepower ? Thanks, Mark "Mark" wrote in message ... Does a prop turning at 2300 rpm on a 150hp motor produce more thrust than a prop spinning 2300 rpm on a 100 hp motor ? |
In article , "Mark" writes:
Hi All, thanks for the responses, was not meant to be a trick question but definately a newbie question. I was curious after reading about people using mazda 13b engines for various homebuilts, and porting them, adding on various components to boost the hp from 200 to 260+. Seems at a point that it's overkill if the 200 hp engine is going to provide you with the needed ponies and rpms to accomplish the same as the 260 hp engine. What would the advantge be of having the extra horsepower ? Thanks, Mark NOW you have asked the question the right way and will see some good answers. The advantage of more horsepower is the capability of increased thrust, which is not a factor of just the RPM but of the ability to convert the horsepower to usable thrust using a prop geared to the output of the engine. Thrust is created by the prop and is determined by the RPM of the prop, the length of the blades, the number of blades and the pitch of the blades along with a host of other factors. Assuming for one example the same number of blades, the same RPM, the same length of blades, and other conditions for two engines and two props, the higher horsepower engine will be able to turn a larger pitch prop than will the lower horsepower engine and will produce more thrust. Think of it the same way as a race care. The higher the horsepower available from the engine, the higher the gear ratio that can be used and the faster the top end speed. PS: This is a simple answer to your question but many factors are involved. The effort to increase a 200 hp engine to 260 hp may or may not be worth the effort and the 30% increase in hp wil not produce an equilivent increase in thrust or speed. I don't remember the formula for calculating the increase but it is far less than anticipated. Bob Reed www.kisbuild.r-a-reed-assoc.com (KIS Builders Site) KIS Cruiser in progress...Slow but steady progress.... "Ladies and Gentlemen, take my advice, pull down your pants and Slide on the Ice!" (M.A.S.H. Sidney Freedman) |
"RobertR237" wrote in message
... PS: This is a simple answer to your question but many factors are involved. The effort to increase a 200 hp engine to 260 hp may or may not be worth the effort and the 30% increase in hp wil not produce an equilivent increase in thrust or speed. I don't remember the formula for calculating the increase but it is far less than anticipated. Speed increases at about the cube root of the HP increase, so: (260 / 200) ^ (1 / 3) = 1.091 or about 9% faster with 30% more HP But other factors to consider are the increased weight of a larger engine, the increased fuel burn, and the weight of that fuel. Eric |
"Eric Miller" wrote: "RobertR237" wrote in message ... PS: This is a simple answer to your question but many factors are involved. The effort to increase a 200 hp engine to 260 hp may or may not be worth the effort and the 30% increase in hp wil not produce an equilivent increase in thrust or speed. I don't remember the formula for calculating the increase but it is far less than anticipated. Speed increases at about the cube root of the HP increase, so: (260 / 200) ^ (1 / 3) = 1.091 or about 9% faster with 30% more HP But other factors to consider are the increased weight of a larger engine, the increased fuel burn, and the weight of that fuel. Eric Extra horsepower converts directly into rate of climb, assuming the same weight and airspeed. Fuel consumption rises approximately in proportion to horsepower; stability decreases. Other factors in boosting phenomenal horsepower out of small packages: Increased thermal load Increased stress on all parts of the engine Some high RPM ranges may not yield usable thrust because the prop tips are in the transonic range, where prop efficiency decreases greatly. |
"Orval Fairbairn" wrote in message news ![]() In article , "Eric Miller" wrote: "RobertR237" wrote in message ... PS: This is a simple answer to your question but many factors are involved. The effort to increase a 200 hp engine to 260 hp may or may not be worth the effort and the 30% increase in hp wil not produce an equilivent increase in thrust or speed. I don't remember the formula for calculating the increase but it is far less than anticipated. Speed increases at about the cube root of the HP increase, so: (260 / 200) ^ (1 / 3) = 1.091 or about 9% faster with 30% more HP But other factors to consider are the increased weight of a larger engine, the increased fuel burn, and the weight of that fuel. Eric Extra horsepower converts directly into rate of climb, assuming the same weight and airspeed. Fuel consumption rises approximately in proportion to horsepower; stability decreases. Other factors in boosting phenomenal horsepower out of small packages: Increased thermal load Increased stress on all parts of the engine Some high RPM ranges may not yield usable thrust because the prop tips are in the transonic range, where prop efficiency decreases greatly. And in the case of a rotary, you WILL be spinning the engine around 6000 or so RPM. This means you must also use a PSRU to drop the RPM down to something usable for the prop. The nice thing is, 6000 shaft RPM is only 2000 rotor RPM. The 13b can handle 6-8 grand with no problems. Phillip |
"Mark" wrote in message ... Hi All, thanks for the responses, was not meant to be a trick question but definately a newbie question. I was curious after reading about people using mazda 13b engines for various homebuilts, and porting them, adding on various components to boost the hp from 200 to 260+. Seems at a point that it's overkill if the 200 hp engine is going to provide you with the needed ponies and rpms to accomplish the same as the 260 hp engine. What would the advantge be of having the extra horsepower ? Thanks, Mark "Mark" wrote in message ... Does a prop turning at 2300 rpm on a 150hp motor produce more thrust than a prop spinning 2300 rpm on a 100 hp motor ? Mark, A "typical" 13b (non-turbocharged) for aircraft is closer to 180-200 Hp. A turbo will get you to that 250 hp mark, if you need it. Without the right prop, the power is not usable. Phillip |
| Stupid super cub question | Robert Loer | Home Built | 9 | November 22nd 03 06:28 PM |
| Tecumseh Engine Mounting Question | jlauer | Home Built | 7 | November 16th 03 02:51 AM |
| question about EZRocket | David O | Home Built | 6 | October 1st 03 07:03 PM |
| Question on Pulsejets/Ramjets??? | DarylG1532 | Home Built | 3 | August 16th 03 04:20 AM |
| Question - Regarding Canard Pushers... | Tilt | Home Built | 33 | August 10th 03 12:07 PM |
