Cirrus down, Chapel Hill NC
Old July 13th 10, 01:47 PM posted to rec.aviation.piloting
a[_3_]
Default Cirrus down, Chapel Hill NC
It may be selective memory on my part, but it seems these airplanes
have been over represented among GA accidents lately.
The story of this crash can be found here (and elsewhere)
http://www.heraldsun.com/view/full_s...=homefirstleft
Old July 14th 10, 04:33 PM posted to rec.aviation.piloting
Agent Gibbs
http://www.heraldsun.com/view/full_s...e-Plane-crashe...
In times past the Beech Bonanza, especially the V tail
variant was deemed the "Doctor Killer". It has now
been replaced by the Cirrus SR series.
And there's not a thing wrong with either. It's just
$ + high performance + low experience = incident.
Also, I read or heard somewhere that the BRS parachutes
don't work if your speed is excessive at deployment. The
lines can snap.
Mark
Old July 14th 10, 06:12 PM posted to rec.aviation.piloting
Mxsmanic
a writes:
They are indeed over-represented.
There's nothing wrong with the airplanes, but there's a lot wrong with the
manufacturer's marketing strategy, which encourages low-time, inexperienced,
naïve pilots to buy Cirrus aircraft, with an emphasis on luxury and prestige
and gadgets, and the subtle suggestion that a parachute can fix any problem
and prevent any accident.
I guess the parachute didn't help in this case, which isn't the least bit
surprising.
Old July 15th 10, 06:28 AM posted to rec.aviation.piloting
Ron Wanttaja[_2_]
Mxsmanic wrote:
a writes:
No. Their accident rate is less than that of Cessna 172s manufactured
over the same time period.
In 2009, there were 23 Cirrus accidents, vs. 3699 aircraft registered as
of January 2010. There were 3003 Cessna 172s on the registry that had
been manufactured since production restarted in the '90s. The NTSB
accident listing for 2009 shows 23 Cessna 172S models and four 172R models.
Cirrus: 23/3699 = 0.62%
New-Production 172s: 27/3003 = 0.89%
Old July 15th 10, 09:05 AM posted to rec.aviation.piloting
a[_3_]
On Jul 15, 12:28*am, Ron Wanttaja wrote:
Mxsmanic wrote:
a writes:
No. *Their accident rate is less than that of Cessna 172s manufactured
of January 2010. *There were 3003 Cessna 172s on the registry that had
been manufactured since production restarted in the '90s. *The NTSB
Cirrus: *23/3699 = *0.62%
New-Production 172s: *27/3003 = 0.89%
Thanks Ron. I would expect too the C172s are more in the rental fleet,
probably get at least as many hours as the Cirrus. That is a guess of
course, it may normalize the distribution a bit.
I appreciate the factual input as opposed to opinion or my selective
memory.
Old July 15th 10, 01:24 PM posted to rec.aviation.piloting
Mxsmanic
Ron Wanttaja writes:
But there are far more Cessna 172s actually flying. About 43,000 of them have
been built, and more than 26,000 are still registered.
Why are you counting only new-production Cessna 172s? What about the other
26,000 Cessna 172s that are still flying?
If all Cessna 172s in service are compared to all Cirrus aircraft in service,
then the accident rate for Cirrus aircraft is about ten times greater than
that of Cessna 172s.
Old July 15th 10, 04:23 PM posted to rec.aviation.piloting
Ron Wanttaja[_2_]
Just because they're registered doesn't mean they're still flying. You
come up with a good way to tell how many are still flying, and we'll
have an apples-to-apples comparison.
Keep in mind that the FAA does not cancel an aircraft's registration
after a crash. Being on the registry doesn't mean the airplane even exists.
As a point of interest, there are more 50+ year-old Cessna 172s on the
rolls than there are new-production models. A third of them haven't
changed ownership in the past 20 years. Satisfied owners...or inactive
aircraft?
In 2009, there were 26,228 Cessnas of all vintages on the FAA rolls, and
115 accidents. This is a rate of about 0.43%...the Cirrus was about 50%
higher, but the new-production 172s had TWICE the accident rate of the
overall fleet.
Should we conclude that there's something wrong with the new-production
172s? Or is just in the way Cessna markets them?
Comparing new-production 172s avoids the active/inactive issues. The
172 came back into production within a few years of the Cirrus, thus the
two types should be evenly affected by the active/inactive aircraft.
The FAA has started an initiative to clean up the registry. We will
probably be seeing the total number of GA aircraft drop over the next
several years.
Old July 15th 10, 08:10 PM posted to rec.aviation.piloting
Mxsmanic
So how do you know that all those Cirrus aircraft are flying?
aircraft?
My guess is the former. Just because an airplane has had the same owner for 20
years hardly means that it isn't being used.
overall fleet.
So?
Why not just look at the way they are marketed? The problems with Cirrus'
marketing are obvious.
And helps massage the numbers to make Cirrus look better.
Old July 15th 10, 05:25 PM posted to rec.aviation.piloting
In order to get a somewhat valid comparison.
The numbers of both built are in the same ballpark and the ages are comparable
so the same percentage of both are likely still flying.
Because no one knows how many of them are still flying.
If you had ever visited any real airports you would know there are lots of
airplanes that exist on the records but don't fly, or even exist anymore.
Jim Pennino
Remove .spam.sux to reply.
Tex Hill Big John Piloting 8 October 17th 07 12:57 AM
2007 Hill Top Fly-In, Cleveland Oklahoma Maxwell Rotorcraft 6 October 4th 07 03:13 AM
Kamikaze - CV-17, USS Bunker Hill struck on 11 May '45 Dave Kearton Aviation Photos 0 May 16th 07 09:30 AM
CV-17 Bunker Hill retirement? DDAY Naval Aviation 29 May 27th 06 06:19 PM
18th Battalion, Chapel Hill Pre-Flight School BOB'S YOUR UNCLE Naval Aviation 0 January 28th 05 04:54 PM
