#101
PosterBoy wrote:
"Keith Willshaw" wrote in message ... snip The caliber of the FK16 was changed in fact, the FK16 n/A was built from 1934 with new barrels to replace the 77mm FK 16's which were left over from WW1 but in 1939 some 300 examples of the older gun were apparently still in service being largely phased out by 1942. I'll agree that few if any front line units would be so equipped and they seem mostly to have been used for training. Keith Robert Nelson of the US 3rd Division wrote that at Anzio (he was there) they used a captured "German 77" as an anti-tank weapon because they were more effective than "our 57s." http://tinyurl.com/pst6 I expect putting it in quotes was the correct thing to do. I imagine this is one of those cases where everyone calls them "77s" because that's what they've heard the Germans have (although late war, every german artillery piece tended to be an "88", at least if you believe the troops). Guy |
#102
Keith Willshaw wrote:
snip The caliber of the FK16 was changed in fact, the FK16 n/A was built from 1934 with new barrels to replace the 77mm FK 16's which were left over from WW1 but in 1939 some 300 examples of the older gun were apparently still in service being largely phased out by 1942. I'll agree that few if any front line units would be so equipped and they seem mostly to have been used for training. Okay, thanks for clearing that up. Guy |
#103
"PosterBoy" wrote in message news:PSZfb.25968$9l5.7473@pd7tw2no... "Keith Willshaw" wrote in message ... "Guy Alcala" wrote in message ... Keith Willshaw wrote: H'mm. the references I have all list the FK 16 n/A (neuer Art.) used in WW2 as 7.5 cm (75mm), but I suppose this could be one of those situations where the caliber was changed in name but not in fact. I wonder how many were still around and in use in WW2. It seems unlikely that any were issued to front-line divisions, as there seem to have been enough FH 18s (or even rechambered Russian 76.2mms) for them. Guy The caliber of the FK16 was changed in fact, the FK16 n/A was built from 1934 with new barrels to replace the 77mm FK 16's which were left over from WW1 but in 1939 some 300 examples of the older gun were apparently still in service being largely phased out by 1942. I'll agree that few if any front line units would be so equipped and they seem mostly to have been used for training. Keith Robert Nelson of the US 3rd Division wrote that at Anzio (he was there) they used a captured "German 77" as an anti-tank weapon because they were more effective than "our 57s." http://tinyurl.com/pst6 Which is probably an error, the 77mm FK-16 was an old fashioned field gun but the Germans did have some excellent 75mm AT guns Keith |
#104
"Keith Willshaw" writes: "Mike Marron" wrote in message ... So... Howzabout thru mach one straight up? Caveat: from brake release (e.g: relying on thrust/weight only) Who: ?? What: F-15?or -16? When: Early/mid-70's? Who: Roland Beamont What: English Electric Lightning When:1959/60 The Lightnings initial climb rate was 50,000 ft per minute which is slightly less than that of the F-15 and better than the F-16 I really don't think so. Mach 1 at sea level is 66,800 ft/min, and at 36,000'. it's 58080. The Lightning's best climb speed would be somewhere in the range of Mach 0.90 - 0.92, (Where the Drag Rise really gets cooking). At sea level, Mach 0.90 is 60192 '/min. The Lightning's 50,000'/minute climb rate would indicat an SEA of 0.83G (Thats (Thrust-Drag)/Weight) Which, while not supersonic, is no slouch whatsoever. I recall seeing one do its party trick at RAF Middleton St George in the 60's , take off on full reheat, unstick and then climb out at 80 degrees going supersonic while still over the field Impressive as hell and boy was it noisy. Of course you had to declare a fuel emergency pretty much straight away but still ![]() -- Pete Stickney A strong conviction that something must be done is the parent of many bad measures. -- Daniel Webster |
#105
The F104A would certainly exceed Mach 1 at zero feet. At Tyndall AFB
in the mid-fifties they did it about every day. All too soon the authorities clamped down on it. FWIW with the old 3-b engine I've seen 725 on the clock at about 100'AGL. Wonder what that Port St. Joe shrimp boat crew thought at 0600 when they got a 'wake-up' call? Honestly, I was just burning out fuel prior to landing and never saw thenm until too late. Walt BJ |
#106
#107
On Mon, 06 Oct 2003 14:25:14 GMT, "Gord Beaman" )
wrote: (WaltBJ) wrote: The F104A would certainly exceed Mach 1 at zero feet. At Tyndall AFB in the mid-fifties they did it about every day. All too soon the authorities clamped down on it. FWIW with the old 3-b engine I've seen 725 on the clock at about 100'AGL. Wonder what that Port St. Joe shrimp boat crew thought at 0600 when they got a 'wake-up' call? Honestly, I was just burning out fuel prior to landing and never saw thenm until too late. Walt BJ Of course Walt...who wouldn't believe that?... It sounds believable to me. I did the same thing. Always had to burn out fuel prior to landing. Always tried to do it most efficiently. Jets burn more fuel at lower altitude, therefore burn down efficiency improves lower. And, since the "horizon" at 100 feet isn't very far, you could be upon the boat before you realized. Yeah, sounds right to me. Now, let's put to bed this idea of accelerating through the mach straight up. While modern jets with greater than 1-to-1 T/W ratios can accelerate through the vertical, I sincerely doubt the mach claim. Too much is going on with drag curves, deteriorating performance with altitude, losses in engine efficiency, etc. I think only heavy lift rockets accelerate through the mach in near vertical, but they transition out of vertical fairly early in the flight trajectory and may not be vertical either. |
#108
Ed Rasimus wrote:
snip Now, let's put to bed this idea of accelerating through the mach straight up. While modern jets with greater than 1-to-1 T/W ratios can accelerate through the vertical, I sincerely doubt the mach claim. Too much is going on with drag curves, deteriorating performance with altitude, losses in engine efficiency, etc. I think only heavy lift rockets accelerate through the mach in near vertical, but they transition out of vertical fairly early in the flight trajectory and may not be vertical either. Oh, I don't know. While not a stock production a/c, the Streak Eagle was certainly capable of doing so [From Jeff Ethell's book on the F-15]: "The 3,000m record flight was piloted by Maj Roger Smith. With a thrust-to-weight ratio at release of over 1.6 to 1 the 'Streak Eagle' lifted off the ground after a roll of only 400ft, approximately seven airplane lengths. Smith quickly raised the landing gear and maintained nearly level flight while accelerating to approximately Mach 0.6. The aircraft was then rotated by a 5g pullup to a near vertical climb attitude. The Eagle accelerated during this climb to Mach 1 and reached the specified 3,000m altitude in 27.57 seconds. The 6,000m, 9,000m, and 12,000m records, were set by Maj Willard 'Mac' MacFarlane in one flight of 16 January [1975]. The profile was similar to the 3,000m flight except that a maximum speed of Mach 0.7 was obtained before the pullup. MacFarlane and his Eagle were at sonic speed only 23 seconds after brake release." "The third flight on 16 January was made by Maj Dave Peterson for the 15,000m record. On this and subsequent flights pilots were wearing pressure suits. Upon liftoff Maj Peterson accelerated about 50ft over the runway to 0.65 Mach and pulled into a 55 degree flight path angle to reach the 15,000m target altitude (49,212 ft) in 77.05 seconds. This is approximately 10sec quicker to that altitude than the Saturn V rocket boosted the Apollo spacecraft on its way to the moon." "The 20,000m profile with Maj Smith again at the controls consisted of a giant Immelmann manoeuvre starting at Mach 0.65 on the deck and pulling 2.5g until the airplane was over the top at 32,000ft and acceperating in the opposite direction. While passing throuhg 20,000ft the Eagle was vertical with a 2.5g load factor and a rate of climb faster than the speed of sound. At Mach 1.5 Smith pulled 4g into a 55 degree climb and held it there to 66,617ft in 122.94 secs elapsed time. The margin over the 'Foxbat' record was 28%." "Maj Peterson then took over for the 25,000m record and flew a similar profile. Maximum speed achieved was Mach 1.8 just prior to the second pullup. The specified altitude of 82,021ft was achieved in 161.02 sec at a speed of Mach 0.6. The a/c eased over the top and descended without incident. This beat the 'Foxbat's' time by 17%." In 1973 the MiG-25 climbed to 30,000m in 4 min 3.86sec. when Maj Smith made the flight to break this record, he lifted off the runway at a weight of 32,000lb after 500ft of ground roll, accelerating to Mach 0.65 and then pulling into a 2.5g Immemann similar to the two previous record profiles. After rolling 180 deg. at the top of the climb Smith accelerated in a slight climb to build up total energy. The 'Streak Eagle' passed through Mach 2 approximately 21 miles downrange and two minutes from takeoff. At Mach 2.2 Smith pulled up to [Sic. 'at'] 4g and attained a 55 deg. flight path whereupon the stick was relaxed to maintain a constant climb attitutde. The 30,000m mark (98,425ft) was achieved in 207.08sec, bettering the 'Foxbat' time by 36 sec. The a/c maintained a nearly ballistic freefall path as it went over the top at 102,400ft." [Later in the book, describing his own flight in a stock F-15B with Lt. Col. Dick Stamm, CO of the 22nd TFS, 36th TFW, from Alconbury, for an ACM hop with the 527th; 36th TFW CO Col. Perry Smith was the wingman]: "When Dick released the brakes and lit the afterburners, I was slammed back in my seat with a force very similar to launches I had made from an aircraft carrier catapult. Before I could catch my breath, the F-15 had traveled 900ft and rotated. The nose came up . . . and up . . . and up! From rotation Dick pulled the nose up into a 90*degree climb a scant few hundred feet off the runway. And the aircraft was accelerating while going straight up*." "I watched the earth recede rapidly -- this must be what a moon shot was like -- and glanced up at a cloud deck at 15,000ft. We slammed through it in a flash; no gradual ascent through. By the time I looked back it was far below." "Due to airspace and speed restrictions, Dick had to pull the burners back, but there was no question a clean, lightly fueled Eagle will go supersonic straight up from a standing start." *Given that the F-15 seat is reclined at an angle of 13 degrees IIRC, the a/c probably wasn't straight up as they'd be hanging by their heads if it was, but at some angle around 77 degrees, unless Ethell was referencing the HUD climb ladder at the time. Guy |
#109
The 105 and the Vark were reputed to be frightfully fast down low ... 800+
KIAS with ease. Daryl Greenameyer's suped up 104 was doing 812-815 at 70' AGL (and approximately 5000 MSL) when he did his record attempt. F-14B's are good for 800+ as well. I understand that the Streak Eagle (stripped airframe, tweaked engines) would actually bust mach in the vertical. Hold it down to around 450, smooth pull to just past vertical and then an unload to maximize thrust/drag. This would have been the preferred profile for the intermediate altitudes ... each one was tailored to reflect fuel load, target altitude, etc. R / John "Gord Beaman" wrote in message ... (WaltBJ) wrote: The F104A would certainly exceed Mach 1 at zero feet. At Tyndall AFB in the mid-fifties they did it about every day. All too soon the authorities clamped down on it. FWIW with the old 3-b engine I've seen 725 on the clock at about 100'AGL. Wonder what that Port St. Joe shrimp boat crew thought at 0600 when they got a 'wake-up' call? Honestly, I was just burning out fuel prior to landing and never saw thenm until too late. Walt BJ Of course Walt...who wouldn't believe that?... -- -Gord. |
#110
On Mon, 06 Oct 2003 19:03:36 GMT, Guy Alcala
wrote: Ed Rasimus wrote: snip Now, let's put to bed this idea of accelerating through the mach straight up. While modern jets with greater than 1-to-1 T/W ratios can accelerate through the vertical, I sincerely doubt the mach claim. Too much is going on with drag curves, deteriorating performance with altitude, losses in engine efficiency, etc. I think only heavy lift rockets accelerate through the mach in near vertical, but they transition out of vertical fairly early in the flight trajectory and may not be vertical either. Oh, I don't know. While not a stock production a/c, the Streak Eagle was certainly capable of doing so [From Jeff Ethell's book on the F-15]: --rest of very detailed and impressive data snipped, but should be referred to for context.--- Guy All well and good, but the issue is could an airplane accelerate through the mach vertically. I contend the answer is no. While the Streak Eagle stuff is arguably the best documented and most impressive, it involves accelerating transition into the vertical. To truly be an acceleration through the mach vertically, it would require establishing the vertical, then choosing max power and performing the acceleration. IOW, pick a subsonic speed, such as 600 KIAS for the pullup to vertical, and even allow for throttle modulation to maintain constant airspeed through the transition to stabilized vertical at 600 KIAS, NOW accelerate from that point through the mach. I'm still a skeptic. |
| Thread Tools | |
| Display Modes | |
| bell xp-77-info? | J. Paaso | Home Built | 0 | March 25th 04 01:19 PM |
| It broke! Need help please! | Gerrie | Home Built | 0 | August 11th 03 11:24 PM |
