French planes are crap
Old November 9th 03, 01:24 AM
Chad Irby
"Paul J. Adam" wrote:
In message , Chad Irby
writes
Note that those old "antiquated deathtraps" are competitive with the
current offerings from Europe, and much better than anything else in the
world.
If that were true, then we'd have binned Eurofighter in 1994 and leased
F-16s instead.
Seriously examined and pushed quite hard.
....and bought for a small advantage, for (at least in part) political
reasons.
cirby at cfl.rr.com
Remember: Objects in rearview mirror may be hallucinations.
Slam on brakes accordingly.
  #102
Old November 9th 03, 01:33 AM
Tarver Engineering
"Chad Irby" wrote in message
m...
"Tarver Engineering" wrote:
An F-22 is not a fast airplane, by historical perspectives
Mach 2. About the same as everyone else out there, and faster than some
of the current-generation European planes.
and will have
less range than some F-35 versions.
Name one. All of the current F-35 variants top out at about half the
range.
We shall see.
  #103
Old November 9th 03, 11:57 AM
killfile
m...
"killfile" wrote:
I was reffering to air-to-air engagements. Despite the ingenious
'name change' approach, the F/A-22 really has very little in the way
of AtG capability thus far.
Except for dropping a few thousand pounds of precision-guided bombs...
cirby at cfl.rr.com
The F/A-22 won't have any PGM capability for a while yet. JDAM integration
will be relatively easy, but it won't have laser designation capability
unless some kind of external pod is integrated - and external stores means
your radar signature goes waaaay up. On the same subject, the F/A-22 isn't
going to be able to carry more than two 1000lb JDAM's without going to
external stores, until the Small Diameter Bomb enters service.
The F/A-22 was designed to be the ultimate interceptor, a Cold War
requirement that no longer exists. It might be a first-rate fighter, but
it's not a bomber yet.
The proposed F/A-22E looks pretty interesting, though.
Matt
  #104
Old November 9th 03, 06:08 PM
Chad Irby
and will have less range than some F-35 versions.
We shall see.
No, we shan't.
cirby at cfl.rr.com
  #105
Old November 9th 03, 06:17 PM
Paul J. Adam
writes
F-16s instead.
reasons.
No, because it would be significantly less capable for not much less
money. The F-16 is a provably superb aircraft but its design is thirty
years old and it's running out of growth room.
But at that point, if the F-16 had offered a cost-effectiveness
advantage, it would have been bought: there was significant pressure to
walk away from Eurofighter.
When you have to kill a man, it costs nothing to be polite.
W S Churchill
Paul J. Adam MainBoxatjrwlynch[dot]demon{dot}co(.)uk
  #106
Old November 9th 03, 07:02 PM
Tarver Engineering
m...
We shall see.
No, we shan't.
The only way we won't see is if the F-22 examples are beer cans, when the
F-35 reaches service.
  #107
Old November 10th 03, 06:02 PM
Chad Irby
writes
F-16s instead.
reasons.
You should remember, though, that the Eurofighter's design is over
twenty years old.
There still is, as evidenced by the reduced buys.
cirby at cfl.rr.com
  #108
Old November 10th 03, 06:04 PM
Chad Irby
the F-35 reaches service.
The only way you could get the sort of performance increse you're
talking about is to completely redesign the F-35 and add a few tons to
the airframe. None of the proposed variants have the sort of range
increase you're claiming.
cirby at cfl.rr.com
  #109
Old November 10th 03, 07:29 PM
Tarver Engineering
om...
Read up on the RR F-35 engine offering and also see the test results for the
F-22. One is short of expectations and the other looks like a trick.
  #110
Tarver Engineering
om...
writes
leased
F-16s instead.
reasons.
twenty years old.
The UK could save a lot of money in a no F-22 world.
Stupid Americans! -- Stupid... Stupid... STUPID!!! __________-+__ ihuvpe Chris Instrument Flight Rules 43 December 19th 04 10:40 PM
About French cowards. Michael Smith Military Aviation 45 October 22nd 03 04:15 PM
Ungrateful Americans Unworthy of the French The Black Monk Military Aviation 62 October 16th 03 09:05 AM
American planes are crap! Peter Mollror Military Aviation 20 October 7th 03 07:33 PM
Conspiracy Theorists (amusing) Grantland Military Aviation 1 October 2nd 03 01:17 AM
