*********A DEFENCE FOR MXMORAN***********
Old March 3rd 09, 10:17 PM posted to rec.aviation.piloting
BeechSundowner
Default *********A DEFENCE FOR MXMORAN***********
On Mar 3, 5:15*am, Ibby wrote:
First priority is NOT talking to ATC but retaining control of the
aircraft. *If it is decending rapidly the FIRST button I would engage
is Altitude Hold which will start the aircraft to level out. *This can
be easily reached without moving the Pilot or FO. *The pilots can be
moved in a moment and ATC can be contacted once you have 'control'.
Again, don't forget that human part. I have no clue where the
altitude hold is. You may know from the hours and hours of sim
experiences, but in the real world, you expect me to find a button
that will automatically level the plane. There are billions of
buttons to look at.
The radios are more than likely already tuned to the nearest
controller. *The major part of the FMC will now be 'unimportant' as
you will no longer be required to continue on your planned route. *The
Mode Control Panel (the buttons and dials on the glareshield) take
precedence over the FMC. *For the FMC to control the flight director
two buttons require engaging - LNAV (Lateral Navigation) which
I drive a single engine land airplane. You think I have any clue what
you are talking about? You are in a jetliner plane about to buy the
farm. No common Joe, or even a pilot like myself will be there to
"save the day" All the simulation in the world won't take away the
vast array of gauges and dials, and buttons for me to find the
altitude hold button in a reasonable time. Imagine yourself over the
radio talking to someone and saying find the altitude hold button and
guiding them to the right place? Oh yeah we talk in a walkie talkie
world, which slows down communications. Only one person talks at one
time. You think John Q public knows this? IF THEY EVEN find the PTT
button!
I agree and stated before the majority of us would literally be
crapping ourselves. *The sim DOES help however in understanding the
'digitised' controls and knobs. *When I took my first flying lesson in
a Cessna 152 (yes basic in comparision) but it was exactly the same as
the payware aircraft I bought for the sim. *
It doesn't for me when I am in an emergency situation trying to save
my skin in a plane I never sat in the front seat.. Too many buttons,
remember for me to find that right button you want me to push, pull or
twist? I fly a Sundowner, which has a vast array of buttons to a non
pilot. Could / would they know where my autopilot is by description.
I seriously doubt it!
As stated before the majority of the FMC is obsolete and the aircraft
can be controlled via the MCP and the autopilot. *ATC will quite often
vector a pilot with differing headings, speed restrictions and
altitude constraints to that on the FMC flightplan but in most cases
the PIC will use the MCP to make these temporary changes. *
Uhh, I am in a plane totally unfamiliar. You will instruct me to use
the MCP. I have no clue what that is. I have fear for my life, you
think you would be able to walk me through which panel is the MCP? I
doubt it. Remember, the audience you are talking to is a non pilot in
the emergency situation we are talking about. You wouldn't say push a
button on the MCP. You would say it in plain English and describe it
in plain English.
When APP is pressed all 3 autopilots are engaged and thus the autoland
is armed. ATC can instruct you to reduce your airspeed via the control
knob and extend the flaps, landing gear can be lowered and landing
lights and strobes switched on prior to Flaps 20 with continual
slowing using the autothrottle system and further extension of the
flaps.
ATC seperates traffic. Remember, I am descending through 10000 feet,
time is not on my side. I don't think they will know what control
knob for me to push, pull or push, and even if they did, they just
can't point to it, they would need to be able to describe it precisely
within the 1000's of other knobs that sit in front of me.
That's how the simulator can help. *They have 'big' knobs and 'little'
knobs as per the real aircraft
But remember the vast array of buttons and knobs. You have to find
the component first! I never been in a 747.
Let me give you a real deal example of how something electronic can
draw a brain fart, and I posted my experiences. I was in a plane with
a Garmin 330 transponder. Transponder was not sending the right
altitude. I did not know how to stop Mode C. Something very simple
became a major traffic hazard around me.
On my transponder, I have a on setting where it will transmit Mode A,
not C. Easy enough for me to do. Now, I tell you stop my mode C by
twisting the knob from alt to on. Would you be able to figure that
out in the vast array of gauges, buttons and knobs? You have never
been in my plane and all your vast knowlege of a 747 is now tossed out
the window. I would suspect, eventually you will find it from your
simulation knowlege, but the average non pilot will have no clue what
or where the transponder is much less turn a knob from alt to on.
As I have posted many, many times, and I have used MSFS X. *
Did you use payware aircraft or the default as there can be a world of
difference depending on the vendor
You are missing my point. All the simulation in the world doesn't
help me when the rubber meets the road. Simulation is great for
learning procedures. It will not save my skin in a 747. As stated
earlier, the plane in the approach phase probably has not been
configured for autoland. I doubt anybody would be able to tell John Q
public which panel to look at to set it up for autoland in the short
time before the farm is bought..
*I'm
NOT a qualified pilot and have never flown yet in IMC conditions. *I
agree hand flying an aircraft in the simulator in IMC can be difficult
as you have zero sensation of movement.
You have it backwards..... It's the sensation of movement that will
make you a lawn dart and learning to ignore that sensation of movement
is the key.
MSFS makes simulated IMC a walk in the park on my computer. I have
never gotten the leans from MSFS.
Again, talk to a pilot that is instrument rated. Until you do so, you
have no clue what flying is all about just on what you say above..
Old March 4th 09, 10:06 AM posted to rec.aviation.piloting
Mxsmanic
BeechSundowner writes:
buttons to look at.
No, there are only a dozen or so, and they are clearly marked, and all you
need is someone to tell you where to look.
In this case, it's pretty easy: Look along the top of the glare shield until
you find the word ALT, then look down until you find the word HOLD, and press
that button.
I suppose it might seem complex to the pilot of a tiny plane, but it's not
really that difficult.
No, I don't. And it's really hard to comment on things that one doesn't have
a clue about, isn't it?
You are in a jetliner plane about to buy the farm.
No. Incapacitation of the pilots does not cause the plane to crash. This
isn't a Piper Cub.
You may wish to review the accident report for Helios Airways Flight 522,
which illustrates what happens when the pilots are both incapacitated in a
modern airliner.
Anyone of reasonable intelligence can find it within seconds when told where
to look (and eventually even if not told).
Very easy.
Oh yeah we talk in a walkie talkie world, which slows down communications.
How?
Only one person talks at one time.
In a normal conversation, only one person talks at one time.
I don't. But perhaps we move in different circles.
doubt it.
Well, if you happen to be the one who replaces the pilots, I suppose the
flight is doomed, based on what you are saying. But a lot of other people
could handle it. Do not assume that everyone shares your handicaps.
in plain English.
Find ALT along the top edge of the instrument panel, near the middle. Just
below that is a button marked HOLD. Press that.
Elapsed time: 2 seconds.
Once you press ALT HOLD, you are not descending any more.
I don't think they will know what control knob for me to push, pull
or push, and even if they did, they just can't point to it, they would
need to be able to describe it precisely within the 1000's of other
Do you panic easily? I could explain to a ten-year-old where to find the
button, and he'd find it and press it without any difficulty. (In fact, I've
seen ten-year-olds following instructions quite well in full-motion sims.)
The array is not vast, and everything is clearly marked, precisely to make it
all easy to figure out.
So I've surmised.
Not knowing how to operate the equipment in your aircraft sounds like a FAR
violation to me.
Sure.
You have never been in my plane and all your vast knowlege of a 747
is now tossed out the window.
All I need is someone who knows the inside of your plane.
That's why someone else has to tell him this.
You're not answering the question, which I assume means that you haven't used
any payware aircraft. So you've never been in a real 747, you've never used a
decent simulator of a 747, and you apparently have not read anything on the
747. And yet you're arguing about whether or not someone can land it.
Why is it okay for you to comment on such things with so little knowledge
thereof, if it isn't okay for me to comment on them with a much better
knowledge base?
All the simulation in the world doesn't help me when the rubber meets
the road.
Simulation helps a great deal. Simulation saves lives, in fact, by allowing
pilots to practice things that would be too rare or expensive or dangerous to
practice in real life.
Simulation is great for learning procedures. It will not save my skin
in a 747.
It would probably save mine.
As stated
It's not hard to configure for autoland.
is the key.
When you are in a sim that doesn't move, you learn very quickly to depend on
instruments alone.
I'm talking to a pilot who largely admits having no clue about 747s, but that
doesn't stop him from talking about them.
Old March 4th 09, 05:15 PM posted to rec.aviation.piloting
buttons to look at.
Wrong, try again.
http://www.airliners.net/photo/Virgi...4Q8/0314046/L/
Not shown are the dozens of switches and buttons on the overhead
panel.
Jim Pennino
Remove .spam.sux to reply.
Old March 4th 09, 08:16 PM posted to rec.aviation.piloting
Mxsmanic
writes:
Wrong, try again.
Looks just like the sim.
panel.
That's okay, I know what they are and what they do already.
Old March 4th 09, 09:15 PM posted to rec.aviation.piloting
Mxsmanic wrote:
writes:
Wrong, try again.
panel.
Yeah, so what?
I noticed you snipped the part where you were wrong, i.e. where you stated
there were only a dozen of so switches and buttons.
Jim Pennino
Old March 4th 09, 10:19 PM posted to rec.aviation.piloting
BeechSundowner
On Mar 4, 2:15*pm, wrote:
Mxsmanic wrote:
writes:
Wrong, try again.
http://www.airliners.net/photo/Virgi...Boeing-747-4Q8....
panel.
Yeah, so what?
Jim Pennino
It's been two hours staring at that screen (NOT) and I am still
looking for the altitude hold button LOL I'za along with the 100's of
passengers would have been dead 118 minutes ago looking for that durn
thing.
Is it a button, toggle switch, twist knob or what? Gee, imagine ATC
describing to me where to look as gravity's unyielding force is
applied against the airplane current course.
MAY DAY, MAY DAY!!! Oh dang it, ATC hung up the phone because John
Q pilot like myself didn't know where the altitude hold button was.
Old March 5th 09, 06:20 AM posted to rec.aviation.piloting
-b-
says...
writes:
Wrong, try again.
http://www.airliners.net/photo/Virgi...-4Q8/0314046/L
panel.
Fortunately, safe pilots are not so brazen. Instead of testosterone to assert
knowledge, they rely on documentation and they cross-check.
Old March 4th 09, 10:26 PM posted to rec.aviation.piloting
Mxsmanic
-b- writes:
They can do that with simulation alone.
Old March 5th 09, 01:11 AM posted to rec.aviation.piloting
Ibby
panel.
Jim Pennino
Apart from lighting controls the overhead panel isn't required much
during flight and only necessary for pre-flight and engine start. It
of course requires monitoring with fuel systems being configured for
tank/engine when required but apart from that no real input from the
pilot. Most of the work is via the MCP on the glareshield and the FMC
Ibby
[email protected] Glenn Alderton[_2_] Aviation Photos 14 January 5th 07 03:35 AM
UK Defence Shakeup Ian MacLure Military Aviation 0 July 22nd 04 04:40 AM
U.S. pilot has new defence Otis Willie Military Aviation 0 June 30th 04 11:50 PM
Bulldozing US Homeland Defence. Tamas Feher Military Aviation 44 June 13th 04 11:12 PM
USA Defence Budget Realities Stop SPAM! Military Aviation 17 July 9th 03 03:11 AM
