ATC Handling of Low-Fuel American Flight
Old February 25th 07, 11:59 PM posted to rec.aviation.ifr
Sam Spade
Default ATC Handling of Low-Fuel American Flight
Jim Macklin wrote:
We all do the best we can, that includes pilots and ATC.
Not all the time.
These words are absolutely clear and not subject to any interpretation
whatsoever:
"An aircraft in distress has the right-of-way over all other air traffic."
Are you aware that AAL management wrote a letter to the local FAA
expressing strong dissatisfaction with the handling of the flight?
The evening that Avianca crashed near JFK in 1996, AAL came very, very
close to loosing an MD-80 at JFK due to fuel exhaustion. That event
shook the flight ops culture at the company, as it well should have.
Any action taken by a pilot in command after declaration of an emergency
is not subject to modification or second guessing by ATC or anyone else
until after the flight is terminated. After that, the conduct of the
PIC is fairly open to critique and review and, in some cases, sanctions.
But, while the flight is still on-going the PIC is supposed to be given
the priority he requests. If that does not work then the PIC should, if
necessary, rephrase it as a demand.
There is no omnipotence involved. If there was, then the PIC would not
be subject to review and possible sanction after the fact.
  #112
Old February 26th 07, 12:11 AM posted to rec.aviation.ifr
Matt Whiting
Jim Macklin wrote:
PIC does not mean you're God, god or have a green light for every
action. It does mean you're responsible, accountable, and will get all
possible assistance.
The tapes from a TV station do not interest me, I've wasted too much
time over the years seeing some talking head. Repeating rumors and TV
gossip or 91.3 does not help the god-like image either.
Was there a point to posting over 1,000 lines of text that is mostly not
relevant to the discussion?
Matt
  #113
Old February 26th 07, 12:13 AM posted to rec.aviation.ifr
Matt Whiting
Jim Macklin wrote:
Right of way DOES NOT mean carte blanche, see
2-1-1. ATC SERVICE
The primary purpose of the ATC system is to prevent a
collision between aircraft operating in the system and to
organize and expedite the flow of traffic. In addition to
its primary function, the ATC system has the capability to
provide (with certain limitations) additional services. The
ability to provide additional services is limited by many
factors, such as the volume of traffic, frequency
congestion, quality of radar, controller workload, higher
priority duties, and the pure physical inability to scan and
detect those situations that fall in this category. It is
recognized that these services cannot be provided in cases
in which the provision of services is precluded by the above
factors. Consistent with the aforementioned conditions,
controllers shall provide additional service procedures to
the extent permitted by higher priority duties and other
circumstances. The provision of additional services is not
optional on the part of the controller, but rather is
required when the work situation permits. Provide air
traffic control service in accordance with the procedures
and minima in this order except when:
No document I have found says that declaring EMERGENCY means
ATC shall grant any pilot request, those requests have
limitations due to traffic and other events. Right of way
and priority handling does not mean that every PIC request,
demand or wish can, will or should be granted.
Handling a flight with an emergency isn't an "additional service" as
defined here. This is talking about optional services like VFR
advisories, not dealing with an emergency.
Matt
  #114
Old February 26th 07, 12:50 AM posted to rec.aviation.ifr
Jim Macklin
I copied the whole thing previously. Yes, I have honor and
common sense.
I clearly stated that not every request can be granted, but
91.03 does say you can do what you want and not be violated
for breaking a FAR if that was required to handle the
emergency. It does not give blanket protection for any
action not needed.
If you'll notice I used 2-1-1 to show the FAAs use of the
limitations exception, not as a total argument.
see a dictionary for carte blanche...
"Steven P. McNicoll" wrote in
message
nk.net...
| "Jim Macklin" wrote
in message
| 2-1-1. ATC SERVICE
a
to
to
to
The
many
higher
and
is
cases
above
to
not
procedures
| Right of way is a statutory right granted an airplane to
proceed ahead of
| another. I see that you deleted subparagraph c. from your
copy and paste of
| FAAO 7110.65 paragraph 2-1-1. You have no honor.
means
way
request,
| What does it mean to you?
| Did ATC do the best they could in this case?
  #115
Old February 26th 07, 12:56 AM posted to rec.aviation.ifr
Jim Macklin
It has right of way, it does not say that ATC shall grant
every pilot request. It does mean that ATC can and will,
shall cut them into the line and not place other aircraft
[except one with a high degree of emergency] ahead of them.
It is not carte blanche.
Priority and right of way do not mean everything, it means
what is possible.
I'm glad that management at the FAA and AAL are talking,
maybe it will improve service on both sides.
All words are subject to interpretation and very few words
are absolutely clear.
Otherwise, why are there so many lawyers and why do lawyer
write the laws?
"Sam Spade" wrote in message
| Not all the time.
interpretation
| whatsoever:
other air traffic."
local FAA
flight?
came very, very
That event
should have.
of an emergency
or anyone else
conduct of the
cases, sanctions.
PIC should, if
PIC would not
  #116
Old February 26th 07, 12:57 AM posted to rec.aviation.ifr
Jim Macklin
yes
"Matt Whiting" wrote in message
for every
and will get all
wasted too much
rumors and TV
is mostly not
| Matt
  #117
Old February 26th 07, 01:03 AM posted to rec.aviation.ifr
Jim Macklin
The point is that declaring an emergency does not require
ATC to do the impossible or grant every deviation. 91.3
does allow the pilot to deviate without a clearance if
necessary.
Giving priority handling does not mean or require doing
everything the pilots asks. It does mean that ATC won't
vector you the normal 20 mile base leg and they will fit you
in ASAP. There are priorities...
| 2-1-1. ATC SERVICE
prevent a
to
to
to
The
many
higher
and
is
cases
above
to
not
procedures
means
way
request,
service" as
like VFR
| Matt
  #118
Old February 26th 07, 01:34 AM posted to rec.aviation.ifr
Steven P. McNicoll
"Jim Macklin" wrote in message
news
Why didn't you read it?
Yes, I have honor and common sense.
You have neither.
action not needed.
The request we're discussing could have been granted, and should have.
  #119
Old February 26th 07, 01:36 AM posted to rec.aviation.ifr
Sam Spade
write the laws?
Because few regulations are as clear as the 91.113 language I previously
cited. No competent lawyer would try to find wiggle room in that
language. If he did, a federal judge would throw him out of court.
  #120
Old February 26th 07, 01:37 AM posted to rec.aviation.ifr
Steven P. McNicoll
what is possible.
The request was possible but still refused.
The words in question are absolutely clear.
Handling Characteristics of the Flight Design CTSW John Piloting 9 March 14th 07 04:38 AM
American Flight 191 - Recovery Procedure Rick Umali Piloting 17 November 5th 06 04:35 AM
Angel Flight fuel discounts John Doe Piloting 4 January 20th 06 02:24 PM
Passenger attempts to hijack American Eagles flight C J Campbell Piloting 5 January 11th 04 05:04 PM
American Safety Flight Systems seat belts -- Help! Paul Millner Owning 1 July 7th 03 11:10 PM
