#111
On or about Mon, 10 Nov 2003 17:02:29 GMT, Chad Irby
allegedly uttered: In article , "Paul J. Adam" wrote: In message , Chad Irby writes In article , "Paul J. Adam" wrote: If that were true, then we'd have binned Eurofighter in 1994 and leased F-16s instead. Seriously examined and pushed quite hard. ...and bought for a small advantage, for (at least in part) political reasons. No, because it would be significantly less capable for not much less money. The F-16 is a provably superb aircraft but its design is thirty years old and it's running out of growth room. You should remember, though, that the Eurofighter's design is over twenty years old. As is the F-22. Thanks to extended gestations there aren't any "new" designs with less than a 10 year history, and at 20 the Typhoon's about average. But at that point, if the F-16 had offered a cost-effectiveness advantage, it would have been bought: there was significant pressure to walk away from Eurofighter. There still is, as evidenced by the reduced buys. Indeed, just like the reductions in buy of F-22, and the cuts in the required F-18E/F numbers and F-35 numbers. Welcome to the post cold war era. --- Peter Kemp Life is short - Drink Faster |
#112
writes In article , "Paul J. Adam" wrote: No, because it would be significantly less capable for not much less money. The F-16 is a provably superb aircraft but its design is thirty years old and it's running out of growth room. You should remember, though, that the Eurofighter's design is over twenty years old. As is the F-22 - is *that* obsolete? -- When you have to kill a man, it costs nothing to be polite. W S Churchill Paul J. Adam MainBoxatjrwlynch[dot]demon{dot}co(.)uk |
#113
"Paul J. Adam" wrote in message ... In message , Chad Irby writes In article , "Paul J. Adam" wrote: No, because it would be significantly less capable for not much less money. The F-16 is a provably superb aircraft but its design is thirty years old and it's running out of growth room. You should remember, though, that the Eurofighter's design is over twenty years old. As is the F-22 - is *that* obsolete? The difference being that the F-22's hopes rest on BAE Systems ability to **fix** the F-22's software post code creation, wheras the Eurofighter was there's to write from day one. ![]() |
#114
"Tarver Engineering" wrote in message ... "Paul J. Adam" wrote in message ... In message , Chad Irby writes In article , "Paul J. Adam" wrote: No, because it would be significantly less capable for not much less money. The F-16 is a provably superb aircraft but its design is thirty years old and it's running out of growth room. You should remember, though, that the Eurofighter's design is over twenty years old. As is the F-22 - is *that* obsolete? The difference being that the F-22's hopes rest on BAE Systems ability to **fix** the F-22's software post code creation, wheras the Eurofighter was there's to write from day one. ![]() Sorry - are you talking FCS software here? |
#115
"Ian Craig" wrote in message ... "Tarver Engineering" wrote in message ... "Paul J. Adam" wrote in message ... In message , Chad Irby writes In article , "Paul J. Adam" wrote: No, because it would be significantly less capable for not much less money. The F-16 is a provably superb aircraft but its design is thirty years old and it's running out of growth room. You should remember, though, that the Eurofighter's design is over twenty years old. As is the F-22 - is *that* obsolete? The difference being that the F-22's hopes rest on BAE Systems ability to **fix** the F-22's software post code creation, wheras the Eurofighter was there's to write from day one. ![]() Sorry - are you talking FCS software here? I misspelled their's, so sorry. |
#116
"Tarver Engineering" wrote: Read up on the RR F-35 engine offering and also see the test results for the F-22. One is short of expectations and the other looks like a trick. ....except for the needed "trump" of offering half the fuel economy o do what you claimed. -- cirby at cfl.rr.com Remember: Objects in rearview mirror may be hallucinations. Slam on brakes accordingly. |
#117
"Tarver Engineering" wrote: The UK could save a lot of money in a no F-22 world. They could also save a lot of money by using ultralights... -- cirby at cfl.rr.com Remember: Objects in rearview mirror may be hallucinations. Slam on brakes accordingly. |
#118
"Paul J. Adam" wrote: In message , Chad Irby writes You should remember, though, that the Eurofighter's design is over twenty years old. As is the F-22 - is *that* obsolete? The actual F-22 design we see now is really only about ten years old, due to fairly complete revamps of the program along the way. They took a long time getting to initial designs, but ti's those designs you have to compare. The Eurofighter is pretty much the same design (plus some avionics and materials changes) as the late-1970s initial requirement. -- cirby at cfl.rr.com Remember: Objects in rearview mirror may be hallucinations. Slam on brakes accordingly. |
#119
writes In article , "Paul J. Adam" wrote: In message , Chad Irby writes You should remember, though, that the Eurofighter's design is over twenty years old. As is the F-22 - is *that* obsolete? The actual F-22 design we see now is really only about ten years old, due to fairly complete revamps of the program along the way. One of the reasons the Eurofighter's late is... significant changes to the original design, as newer technologies came along (the RCS reduction program being one example). They took a long time getting to initial designs, but ti's those designs you have to compare. The Eurofighter is pretty much the same design (plus some avionics and materials changes) as the late-1970s initial requirement. Sorry, but that last is no more true than that the F-22 that enters service is just a productionised YF-22. -- When you have to kill a man, it costs nothing to be polite. W S Churchill Paul J. Adam MainBoxatjrwlynch[dot]demon{dot}co(.)uk |
#120
"Paul J. Adam" wrote: In message , Chad Irby writes The actual F-22 design we see now is really only about ten years old, due to fairly complete revamps of the program along the way. One of the reasons the Eurofighter's late is... significant changes to the original design, as newer technologies came along (the RCS reduction program being one example). But those involved fairly minor changes (the "low RCS program" mostly consisting of sticking some RAM in the intake), not major design issues. -- cirby at cfl.rr.com Remember: Objects in rearview mirror may be hallucinations. Slam on brakes accordingly. |
| Thread Tools | |
| Display Modes | |
| Stupid Americans! -- Stupid... Stupid... STUPID!!! __________-+__ ihuvpe | Chris | Instrument Flight Rules | 43 | December 19th 04 10:40 PM |
| About French cowards. | Michael Smith | Military Aviation | 45 | October 22nd 03 04:15 PM |
| Ungrateful Americans Unworthy of the French | The Black Monk | Military Aviation | 62 | October 16th 03 09:05 AM |
| American planes are crap! | Peter Mollror | Military Aviation | 20 | October 7th 03 07:33 PM |
| Conspiracy Theorists (amusing) | Grantland | Military Aviation | 1 | October 2nd 03 01:17 AM |
