Why not use the F-22 to replace the F/A-18 and F-14?
Old February 25th 04, 12:25 PM
Frijoles
Sure doesn't take too long for any discussion of F-35B to turn into a debate
about ships eh??
"John Keeney" wrote in message
"puttster" wrote in message
om...
"John Carrier" wrote in message
Now if you want to argue that the F-35B is an aircraft designed as a
Carrier
Aircraft, I know some Marines that would like to chat with you. The
B
will
be replacing AV-8B's and land based F-18's. Sure, it can land on a
carrier
but it is not being built to trap aboard CV/N's using arresting gear
or
Cat
launches.
True in a sense, but as a VSTOL and STOVL design, it's fully carrier
suitable w/o the need for catapult gear (I suspect it does have a
tailhook).
I'd also be much surprised if its CNI suite didn't include ACLS and
SPN-41
in their latest incarnations.
R / John
With an excellent V/STOL capability in the F-35B, why does the Navy
still demand those giant carriers? Seems like something can be done
there to make the whole system more efficient. Why design a plane
(the F-35C) to fit their ships?
Because the F-35C flies farther with a bigger load than the F-35B.
Because the ships aren't going away since they need the deck for
the E-2 and C-2 anyway.
  #116
Old February 25th 04, 02:23 PM
Keith Willshaw
"Doug "Woody" and Erin Beal" wrote in message
On 2/25/04 3:32 AM, in article , "Keith
Willshaw" wrote:
Nope, and admittedly I'm telling tales out of school because I haven't
flown
one nor studied up on it, but it does have some funky engine failure
throttle automation (which I don't understand).
So you are criticising a system without knowing anything about it.
Autothrottles are scarcely a rarity and the installation on the A-300
can be turned off so the crew has full authority, just as on Boeing
aircraft.
It's Airbus' approach to automation that I object to... perhaps slightly
out
of ignorance.
Indeed
Keith
  #119
Old February 25th 04, 08:56 PM
Doug \Woody\ and Erin Beal
On 2/25/04 7:23 AM, in article , "Keith
flown
aircraft.
I've got time in lots of jets with autothrottles, so spare me the preaching
to the choir. I bring up the autothrottle issue on the Airbus because of
their famous mishap with a jet that turned out to be the "world's most
expensive chainsaw" a few years back. That same throttle automation was
responsible for a Russian Airbus doing a wingover about 10 years ago too.
To me, the no-greater-than-60-degrees-AOB feature on the A320 is disturbing.
The pre-supposition by the folks at Airbus seems to be that the pilot needs
to be kept in a box because he's incapable of staying there on his own.
As I said before, my opinions are based on ready room chat with a few pilots
I know who fly the Airbus. The knowledge I have is on a macro level (i.e.
not from a standpoint of having been formally schooled on it), but it's
certainly enough to allow me to form a rational and reasonable opinion.
I've also taken the honest road and admitted my short-comings on the issue.
out
of ignorance.
Indeed
So add some intellectual meat to the discussion. If you have time in an
Airbus or knowledge to the contrary and you'd like to lend an opposing view,
feel free. All things being equal, I like Boeing's approach to the issue
better.
--Woody
  #120
Old February 25th 04, 09:21 PM
Michael Zaharis
--Woody
The autothrottle was not the issue on the Airbus "tree harvesting"
accident at Mulhouse. High-bypass engines take a finite amount of time
to spool up, autothrottle or not. If you get too low, too slow, then
decide to goose the throttle too late, you won't get the thrust you need
in time, regardless of the throttle mapping.
http://aviation-safety.net/database/1988/880626-0.htm
"C-175 SoCal Beware" Original Poster Replies Bill Berle Aviation Marketplace 8 July 8th 04 08:01 AM
More LED's Veeduber Home Built 19 June 9th 04 11:07 PM
Replace fabric with glass Ernest Christley Home Built 38 April 17th 04 12:37 PM
RAN to get new LSD class vessel to replace 5 logistic vessels ... Aerophotos Military Aviation 10 November 4th 03 12:49 AM
Air Force to replace enlisted historians with civilians Otis Willie Military Aviation 1 October 22nd 03 10:41 AM
