#121
"Tarver Engineering" wrote in message
... "Ed Rasimus" wrote in message ... On Wed, 8 Oct 2003 08:00:01 -0700, "Tarver Engineering" wrote: "Ed Rasimus" wrote in message As I recall, the first integral of velocity is acceleration. Nope. Ahh, now I see. Thanks for that typically helpful addition to the thread. Enlightenment can come in such small and pithy comments. I hate to say it Ed but for once Tarver is right. The first *differential* of velocity is acceleration. The first integral would be distance covered. I understood perfectly what you meant though and envy you that experience. Integral A dt = V0 + At =V I've no idea what he means by this though! John |
#122
"John Mullen" wrote in message ... "Tarver Engineering" wrote in message ... "Ed Rasimus" wrote in message ... On Wed, 8 Oct 2003 08:00:01 -0700, "Tarver Engineering" wrote: "Ed Rasimus" wrote in message As I recall, the first integral of velocity is acceleration. Nope. Ahh, now I see. Thanks for that typically helpful addition to the thread. Enlightenment can come in such small and pithy comments. I hate to say it Ed but for once Tarver is right. The first *differential* of velocity is acceleration. The first integral would be distance covered. I understood perfectly what you meant though and envy you that experience. Integral A dt = V0 + At =V I've no idea what he means by this though! It is the integral form of one of Newton's laws. |
#123
Actually, the Streak Eagle didn't ever fly vertically for more than a
transition. The profile, as I remember (the x's are numbers I don't remember), was to takeoff, do an Immelman at IAS x, accelerate in level flight to Mach x, then pull to a zoom at x degrees (or maybe at an angle attack). This was indeed the profile for the higher records: 25K and 30K (35K too?) meters. IIRC, the intermediates (around 12-15K) were accomplished more or less straight up. Each profile (I think they started at 3K meters ... roughly 10,000 feet) was approached as a separate problem. Fuel required was calculated and the aircraft was held in position in full A/B with an pyro-release fitting. Hit the magic fuel number and away you go. Airborne and clean up with level accel to optimum airspeed and then do a programmed pull up to optimum climb angle. The higher altitudes required a target mach number before pulling up for the zoom to altitude (approximately 60 degrees nose up_). A/B's blow out in the 65K range. Engine shut-down is a function of minimum fuel flow (The J-79 overtemped in the low 70's ... don't have a clue for the F-101) but done shortly thereafter. It's dark up there. R / John |
#124
On Wed, 8 Oct 2003 18:58:04 +0100, "John Mullen" wrote:
"Tarver Engineering" wrote in message ... "Ed Rasimus" wrote in message As I recall, the first integral of velocity is acceleration. Nope. I hate to say it Ed but for once Tarver is right. The first *differential* of velocity is acceleration. The first integral would be distance covered. I understood perfectly what you meant though and envy you that experience. Well, the disclaimer at the beginning of my post should cover me. I knew that the relationship between velocity, acceleration and rate of change of acceleration went one way or the other. It was either the first and second integral or the first and second differential. It was differential equations at the end of my fourth semester as a chemistry major, coupled with semi-micro qualitative analysis and physical chemistry, that led me to see the futility of ever succeeding with the pocket protector crowd. I changed major to political science with the singular goal of gaining a degree in "anything" so that I could get on with entering the AF and flying jets. If we change the "integral" to "differential" I'm sure that John will recognize and acknowledge my point about aircraft accelerating through the mach vertically. |
#125
"Ed Rasimus" wrote in message ... On Wed, 8 Oct 2003 18:58:04 +0100, "John Mullen" wrote: "Tarver Engineering" wrote in message ... "Ed Rasimus" wrote in message As I recall, the first integral of velocity is acceleration. Nope. I hate to say it Ed but for once Tarver is right. The first *differential* of velocity is acceleration. The first integral would be distance covered. I understood perfectly what you meant though and envy you that experience. Well, the disclaimer at the beginning of my post should cover me. I knew that the relationship between velocity, acceleration and rate of change of acceleration went one way or the other. It goes both ways: Integral a dt = V + V0 dV/dt = a But of course, Ed knows his airplane operating. |
#126
SNIP:
Ed Rasimus wrote: Now, let's put to bed this idea of accelerating through the mach straight up. A couple reminders: 1) with a thrust to weight atio of 1.6:1 the Streak Eagle is distinctly higher powered than anything any of us flew in the service. 2) It's shedding weight in full afterburner during the takeoff and climb. I don't know what the fuel consumption of an F15 full-out is but it's certainly over a ton a minute, so the T/W is increasing. 3) The only comparision I have experience with is the F104B on an AB go-around at the end of a mission but with 1500 pounds of fuel reaming a B model with 2 AIM9s weight about 16300. With 18000 pounds of thrust it was very sprightly indeed. Thing was, that 18000 pounds of thrust is measured in static condions. I have seen the fuel flow gauge on both the F104s and the F4s rise from about 8500pph (per engine) on pre-takeoff run up to 12000pph at 600 KIAS on level acceleration after takeoff, obviously due to ram effect. Since jet thrust has a linear relation of fuel burn - the thrust to weight ratio in flight cannot be determined from thrust developed while sitting still on the ground. Note that I do not know what is happening in the afterburner; the only correlation I ever heard of was the AB fuel flow was about 4 times that of the fuel flow to the engine itself. Also, the J79 manual figure in AB for takeoff was 750 pounds per minute - per engine. FWIW the engine fuel flow is determined by the necessity of keeping the total air flow/fuel flow ratio right around 55 to 1. ( Lots more air than stoichiometric needs to keep the engine from melting.) 4) So what I'm saying is that there is no doubt in my mind that a lightened F15 with a minimum mission required fuel load could and did exceed Mach 1 climbing vertically. 5) BTW with Jeff Ethell's flying experience and the highly visible attitude direction indicator in an F15 why question his statement that they were indeed vertical? Checking a vertical climb on the gyro is no big deal - and one also looks out at the horizon. Walt BJ |
#127
I hate to say it Ed but for once Tarver is right. The first *differential* of velocity is acceleration. The first integral would be distance covered. I understood perfectly what you meant though and envy you that experience. Integral A dt = V0 + At =V I've no idea what he means by this though! John It's basic calculus. Try this one in English units: if you drop an object the function for determining how far it has fallen is X=16T^2, where X is the distance travelled in feet and T is the time in seconds. The first derivative is V = 32T where V is instantaneous velocity expressed in feet per second. The first derivative of V, and the second of X, is A = 32 feet/second/second which is the acceleration due to gravity. Integration is the reverse process. This function doesn't take into account drag, but if you drop a bowling ball from the top of a 10 story building drag is negligible. Dan, U. S. Air Force, retired |
#128
WaltBJ wrote:
SNIP: Ed Rasimus wrote: Now, let's put to bed this idea of accelerating through the mach straight up. A couple reminders: 1) with a thrust to weight atio of 1.6:1 the Streak Eagle is distinctly higher powered than anything any of us flew in the service. 2) It's shedding weight in full afterburner during the takeoff and climb. I don't know what the fuel consumption of an F15 full-out is but it's certainly over a ton a minute, so the T/W is increasing. 3) The only comparision I have experience with is the F104B on an AB go-around at the end of a mission but with 1500 pounds of fuel reaming a B model with 2 AIM9s weight about 16300. With 18000 pounds of thrust it was very sprightly indeed. Thing was, that 18000 pounds of thrust is measured in static condions. I have seen the fuel flow gauge on both the F104s and the F4s rise from about 8500pph (per engine) on pre-takeoff run up to 12000pph at 600 KIAS on level acceleration after takeoff, obviously due to ram effect. Since jet thrust has a linear relation of fuel burn - the thrust to weight ratio in flight cannot be determined from thrust developed while sitting still on the ground. Note that I do not know what is happening in the afterburner; the only correlation I ever heard of was the AB fuel flow was about 4 times that of the fuel flow to the engine itself. Also, the J79 manual figure in AB for takeoff was 750 pounds per minute - per engine. FWIW the engine fuel flow is determined by the necessity of keeping the total air flow/fuel flow ratio right around 55 to 1. ( Lots more air than stoichiometric needs to keep the engine from melting.) 4) So what I'm saying is that there is no doubt in my mind that a lightened F15 with a minimum mission required fuel load could and did exceed Mach 1 climbing vertically. 5) BTW with Jeff Ethell's flying experience and the highly visible attitude direction indicator in an F15 why question his statement that they were indeed vertical? Checking a vertical climb on the gyro is no big deal - and one also looks out at the horizon. Walt BJ I can't compete with all you knowledgeable guys with the maths or actual flying experince, but I thought I'd just contribute this.......... The Sukhoi P-42 - a modified Su-27 Flanker which took all the time-to-climb records from the Streak Eagle - was similarly modified with tweaked engines and lightened airframe. It had thrust-to-weight ratio was almost 2:1 at takeoff. The following is an extract from Andrei Fomin's book on the Su-27 :- "The fighters engines were augmented, with the thrust of each engine increasing by more than 1,000 kgf (in FAI reports a thrust of 2x13,600 kgf was mentioned and the engines were presented under the designation of R-32). The steps taken gave the P-42 a unique thrust-to-weight ratio equalling almost 2 at takeoff. As a result, the P-42 was able to gather speed and break through the sonic barrier when climbing". It doesn't actually say 'climbing vertically' - but it does say supersonic whilst climbing. My page on the P-42 is at :- http://www.duffeyk.fsnet.co.uk/p-42.htm and the list of some of the P-42's 27 world records is at :- http://www.duffeyk.fsnet.co.uk/p42_records.htm ++++++++++++++++++++++++++++++++++++++++++++++++++ ++++++++++++++++ Ken Duffey - Flanker Freak & Russian Aviation Enthusiast Flankers Website - http://www.flankers.co.uk/ ++++++++++++++++++++++++++++++++++++++++++++++++++ ++++++++++++++++ |
#129
What the McAir guy said was true. The profile was a published one that
kept FCF and acceptance flights out of the airport traffic pattern. They weren't supersonic, however. Jim Thomas Harry Andreas wrote: I watched F-15s do this at St Louis airport back in the 80's. What did they call it? A "Trojan takeoff"? The Macair guy claimed they used this profile because it kept the aircraft noise over the airport and didn't disturb the neighbors as much. He kept a straight face while he said it, too. I admired him for that. |
#130
In article , B2431
writes It's basic calculus. I'm not too sure if 'basic' and 'calculus' sit too well together ![]() Try this one in English units: if you drop an object the function for determining how far it has fallen is X=16T^2, where X is the distance travelled in feet and T is the time in seconds. The first derivative is V = 32T where V is instantaneous velocity expressed in feet per second. The first derivative of V, and the second of X, is A = 32 feet/second/second which is the acceleration due to gravity. Integration is the reverse process. This function doesn't take into account drag, but if you drop a bowling ball from the top of a 10 story building drag is negligible. The best bit I liked was deriving the equations of motion from the three basic dimensions 'L', 'M' & 'T' (distance, mass, time). -- John |
| Thread Tools | |
| Display Modes | |
| bell xp-77-info? | J. Paaso | Home Built | 0 | March 25th 04 01:19 PM |
| It broke! Need help please! | Gerrie | Home Built | 0 | August 11th 03 11:24 PM |
