X-43A successful flight
Old April 8th 04, 02:56 AM
Doug \Woody\ and Erin Beal
On 4/7/04 12:05 PM, in article , "Tarver
Engineering" wrote:
SNIP
I did not comment on your ability to operate the F-18 wood man. You
insutled me in assuming that because you do not know something that I could
not know it.
What we have here is... Failure to communicate. I never made that
assumption... At least not publically.
I can assure you that I know more about the
electric/electronic systems in the F-18 than you ever possibly could. I
have the advantage over you, in having brought dead F-18s back to life and
having integrated F-18 aircraft hardware and software to a computer. When I
wrote simulator, it is not the kind you think of, but something to do
controls research on.
I understand more than you might think.
You see, once long ago some in NASA and USN were certain that GE was lying
about their F-18 flight control computer. Much anger was exchanged between
NASA Lewis and GE and Congress was ready to get involved. Using Gould's
software we were able to input GE's numbers and match the airplane at
Dryden. Martha Evans and a delegation went back to NASA Lewis where before
a couple of Congress critters Lewis demanded that Dryden adjust their
simulation results to match Lewis, Martha just laid the airplane strip chart
over our simulation results and showed they matched.
Are you talking about that hangar in Cleveland?
Next thing you know Congress is having a comittee meeting and Bob Myers is
going with Martha to testify. It was all quite a big deal and Dryden was
able to become a flight test center again on the achievement. I remember
Bob comming to my office every morning to see if I was still showing up, as
Martha was hanging on by a thread in those days.
Who are Bob and Martha? Just trying to get educated now.
--Woody
  #124
Old April 8th 04, 06:28 AM
Chad Irby
Clark stillnospam@me wrote:
Do the psychotic episodes of Tarver's always follow his public humiliations
or does he occasionally lead with one?
Follows.
Sure, you can have some posts that *seem* like random starts, but
there's always a "told you so!" in the last paragraph.
cirby at cfl.rr.com
Remember: Objects in rearview mirror may be hallucinations.
Slam on brakes accordingly.
  #126
Old April 8th 04, 07:17 AM
Mary Shafer
On Thu, 08 Apr 2004 00:49:00 GMT, "Doug \"Woody\" and Erin Beal"
On 4/7/04 10:52 AM, in article ,
"Mary Shafer" wrote:
This discussion is going round and round, but my point is... that the stick
forces do not change whether in CAS, MECH or DEL--i.e. any "break out" force
in the cockpit is incidental to what the pilot normally experiences when
pulling on the pole.
I thought the feel system changed in the spin recovery mode, with more
surface deflection per inch of stick displacement, but there's a good
chance that was either a non-standard F-18 or some other airplane. I
mean, I could have been thinking of the F-16 deep stall recovery mode,
you know.
Don't get me started on stick force shaping, as I spent some serious
flight time and money looking at a variety of schedules for pilot
cueing. I can probably tell you more than you want to know about how
pilots perceive the cues, although the most interesting part is how
they can fail to consciously notice a major cue, even when it affects
their technique.
I wouldn't dare even attempt to discuss it with you, Mary unless I were in
receive only mode. |:-)
Did you know, for example, that you have a different tolerance for
time delay in the feel system than you do for time delay in the flight
control system? If asked, you probably don't even know you can tell
the difference, but you can.
Keep it that way. The Plastic Bug flies miserably in MECH. It was a
big deal when they finally trapped in MECH, in fact. Before that, it
had meant diverting to land. When Tom McMurtry had to land one of
ours in MECH he cheerfully declared it to be one of the worse control
modes he'd ever flown, not counting those he'd flown for me when we
were doing the PIO work.
That's what I've heard. I had no idea that a trap in MECH had actually
occurred. It must have been MECH in one axis only. Eh? Sea story?
I honestly don't know if it was one axis or more. It's not a sea
story, because we got the notification from the class desk (or
whatever they call it). You know the thing I mean, the telex to all
F/A-18 squadrons and Dryden, with time-critical information.
I thought DEL was a reversionary mode for more than spin recovery,
though. Doesn't the Bug drop into DEL when the MC faults? It's the
spin recovery mode that overrides the surface limits for spin recovery
when the yaw rate goes over some limit (40 deg/sec, maybe?), isn't it?
It is. You are correct that's DEL, but the only time *I'VE* ever
experienced flying in DEL is when I do Spin Recovery Mode (SRM) checks on
FCF's (only on the A profiles now).
The way I had it explained to me years ago (by some dude at China Lake) is
that SRM is a subset of the DEL mode (with the LEF's at 33-34 degrees and
the TEF's at 0 +/- 1 degree). The nose gets a bit "slicy" coming out of 30K
in with SRM engaged, and the AOA must be kept between 10-20 degrees
(although I know from personal experience that the jet won't explode if you
fall outside of that limit for transitory periods).
I think this is all exactly right, except that my crummy memory for
numbers means I can't say about them. I don't think you can get the
jet to explode on transient excursions outside the limit, although I
know that no one should ever underestimate the fleet pilots, but you
can get it to depart again if you botch the recovery (usually by being
a little too enthusiastic too soon). If you do it just right, you can
get it to depart into a worse mode, like oscillatory instead of flat.
I'll give you my standard stall-departure-spin warning, which I give
to every fighter pilot and test pilot I know. Be careful if you're
flying a two-seat version with a centerline tank. It will depart and
spin much more easily than a single-seat jet or a clean jet. You're
not guaranteed to depart and spin, of course, but you're at greater
risk. It also probably won't recover as well or as quickly and it may
have more spin modes.
I used to have a couple of plots that really made this point clear,
but I left them with one of the flying qualities engineers when I
retired. I wasn't sure if all the data was generally available.
It's kind of a squirrelly deal to fly in. Nauga, where are you?
They're all squirrelly in stall-departure-spin. Maybe it's because
it's all forebody flow so there's a lot of moment arm or something.
The F-16 deep stall procedure is odd, to say the least, because you
get out of the stall by pulling up the nose and increasing the stall
angle before you push over and "rock" the airplane out of the stall.
Yo, Nauga, over here!
Mary
Mary Shafer Retired aerospace research engineer
  #128
Old April 8th 04, 01:10 PM
On 4/8/04 12:17 AM, in article ,
you know.
It may, but I wouldn't know because I never move the stick more than about
1/2 an inch in that mode. I sort of doubt it though because pulling the
stick back or cycling it in a cold/dead airplane feels (force wise) exactly
the same as moving it around in a live running airplane.
I should explain here that the only time I've USED SRM is when I'm doing an
FCF A. The SRM check starts at 30K and 200 KCAS. Basically, turn the SRM
switch to RCVY, and hold the stick back. Then the aircraft hits the correct
numbers (which embarrassingly escape me right now... Circa 150 KCAS), SRM
actually engages. You basically hold 10-20 alpha for the rest of the
recovery while accelerating through 250 so that SRM will auto-disengage.
Basically, we're just diving in SRM in level flight and checking that it
engages and disengages when it's supposed to.
We used to do these checks on C and A FCF's. Now just on A's.
SNIP
Ow.
SNIP
The explode thing was a poor attempt at humor.
Concur with the two-seater/single C/L.
Departing I have done (single-seat)... Twice. Once was fairly eye-opening.
460KCAS (probably much slower 350 or less when it stopped flying) at 15000
feet with a full load of back stick and a full boot of top rudder--a real
ham-fist piece of work. The airplane recovered after disappearing into its
own cotton-ball and some real bang-me-up PSG's. I felt pretty sheepish.
Jet was just fine. The immediate action procedures (basically let go and
wait) worked like a champ.
Weird. Do those guys still do that with the 25 alpha limiter installed?
If he's lurking, this is usually the point where he shows up.
--Woody
Mary
Flight Simulator 2004 pro 4CDs, Eurowings 2004, Sea Plane Adventures, Concorde, HONG KONG 2004, World Airlines, other Addons, Sky Ranch, Jumbo 747, Greece 2000 [include El.Venizelos], Polynesia 2000, Real Airports, Private Wings, FLITESTAR V8.5 - JEP vvcd Home Built 0 September 22nd 04 08:16 PM
100 years of flight - Special coverage by The Cincinnati Enquirer Garrison Hilliard Military Aviation 1 March 14th 04 03:42 PM
us air force us air force academy us air force bases air force museum us us air force rank us air force reserve adfunk Jehad Internet Military Aviation 0 February 7th 04 05:24 AM
Sim time loggable? [email protected] Instrument Flight Rules 12 December 6th 03 08:47 AM
