Who does flight plans?
Old July 3rd 05, 05:19 AM
George Patterson
Matt Whiting wrote:
True, it is just the wing that is stalling.
No, it's not. You can't get the angle of attack required to stall the wing
without hitting the tail.
You somehow seem to think that you can let the airplane down more
gradually using elevator while at a higher speed than what occurs when
the wing stalls. This simply isn't the case in most airplanes.
Bull**** -- that's *exactly* what you are doing.
It is obvious that you weren't taught full-stall landings
No, I was taught by instructors who were educated enough to know what they were
actually doing.
George Patterson
Why do men's hearts beat faster, knees get weak, throats become dry,
and they think irrationally when a woman wears leather clothing?
Because she smells like a new truck.
  #152
Old July 3rd 05, 08:07 PM
Matt Whiting
Peter Duniho wrote:
"Matt Whiting" wrote in message
[...] you can get the yoke all the way back and the stall horn on just a
second before touchdown.
If the stall horn is on only a second before touchdown, you have not stalled
the airplane. The stall horn sounds well before you reach the stalling
angle of attack.
True, but only a few knots above in the Cessna's I've flown 150 - 182.
If you keep smoothly pulling back the yoke, the airspeed will bleed into
stall territory very shortly after you get a full stall horn.
Matt
  #153
Old July 3rd 05, 08:16 PM
Matt Whiting
wing without hitting the tail.
I get enough angle of attack that the wing will no longer support the
weight of the aircraft even with full up elevator. I'm not sure your
definition of stall, but this one works for me.
Yes, I'm using the elevator to bleed off airspeed until the wing will no
longer support the airplane. That isn't quite the same as using power
and pitch when "flying onto" the runway. The wing will still support
the weight of the airplane in that approach so you are flying it onto
the ground.
they were actually doing.
How many of your instructors have been appeared in AOPA Pilot's Pilot
feature?
Matt
  #154
Old July 3rd 05, 09:06 PM
Peter Duniho
Per certification rules, the stall warning must occur AT LEAST 5 knots prior
to stall. In my experience, it commonly occurs with an even greater margin.
No, it won't. The airplane will settle onto the runway before you stall.
You have to move the yoke pretty sharply to keep lift equal to weight at
that airspeed.
Pete
  #155
Old July 3rd 05, 09:10 PM
Peter Duniho
Any angle of attack may be insufficient to support the weight of the
airplane. All you need is a low enough airspeed.
I'm not sure your definition of stall, but this one works for me.
The definition of stall is quite different, and has already been discussed
in detail in this thread. Bottom line: you don't define stall based on the
lift the wing is generating. You *may* relate stall to (but not definite it
based on) the coefficient of lift, but to figure out actual lift you need to
account for airspeed, and stall has nothing to do with airspeed, not from a
definition point of view.
That does not mean you are stalling the airplane. It just means your angle
of attack is insufficient to generate lift equal to the weight of the
airplane at your current airspeed.
Pete
  #156
Old July 3rd 05, 10:41 PM
Matt Whiting
I think 5 is considered "a few" by most, even hair-splitters such as
yourself.
that airspeed.
Yes, it does require that you accelerate the rearward movement of the
yoke as the plane begins to settle in order to hit the stop at or slight
before the tires touch.
Again, I guess it depends on how you define stall. To me, a stall has
occurred when I can't maintain altitude with the elevator full-up. That
is the condition in which I attempt to land in normal conditions (light
crosswind and lack of significant wind gusts). I've never flown a
Cessna with an AOA indicator so I can't say if I've achieved the
critical angle of attack prior to touchdown, but these have been called
"full stall landings" since before I was born so that is good enough for me.
Matt
  #157
Old July 4th 05, 01:04 AM
Peter Duniho
yourself.
Each person has their own definition. If you want to split hairs, you need
to use a more precise term. To me, "a few" is generally three, while I'd
use "several" for five or more.
In any case, the real question is how much before you stall will the horn go
off. It goes off much longer than a second before you stall the wing.
[...] but these have been called "full stall landings" since before I was
As long as you understand that you are not actually stalling the airplane,
that's fine. Use whatever inaccurate terminology you like.
Pete
  #158
Old July 4th 05, 03:26 AM
Matt Whiting
yourself.
If you check Websters it says a small number of units. Five is a small
number.
I understand that I'm stalling the wing, not the airplane.
Matt
  #159
Old July 4th 05, 03:50 AM
Peter Duniho
number.
My point is that "a few" is undefined with respect to a real number. If you
want someone to interpret your statement of "a few" with other than THEIR
definition, you need to be more specific. It is useless to come back later
and redefine it for them.
airplane, that's fine. Use whatever inaccurate terminology you like.
Now you're just being an ass; "stalling the airplane" is the same as
"stalling the wing". In any case, you are not stalling the wing either.
Pete
RAF Blind/Beam Approach Training flights Geoffrey Sinclair Military Aviation 3 September 4th 09 07:31 PM
Flight Simulator 2004 pro 4CDs, Eurowings 2004, Sea Plane Adventures, Concorde, HONG KONG 2004, World Airlines, other Addons, Sky Ranch, Jumbo 747, Greece 2000 [include El.Venizelos], Polynesia 2000, Real Airports, Private Wings, FLITESTAR V8.5 - JEP vvcd Piloting 0 September 22nd 04 08:13 PM
WINGS: When do the clocks start ticking? Andrew Gideon Piloting 6 February 3rd 04 04:01 PM
Flight instructors as Charter Pilots C J Campbell Piloting 6 January 24th 04 08:51 AM
