Cherokee 235 vs Trinidad vs Comanche
Old January 19th 07, 05:39 AM posted to rec.aviation.owning
Newps
Default Cherokee 235 vs Trinidad vs Comanche
Douglas Paterson wrote:
My S model has a book speed of 178 kts true. I get low 170's on an
everyday basis at your fuel flow example. With the $50K you won't have to
spend on the Trinidad you can really put in there what you like. Or enjoy
the extra $500-$1000 you won't be spending on hull insurance.
OK, you're giving me a faster number than I've read. +10kts is not earth
shattering, but certainly noteworthy.
And when it's time to overhaul, the IO-550 is an option for me. Due to
the fact the 550 was certified under newer and much more stringent rules
than the IO-520 I have you get much more than a 15 HP increase. Most
new 550's put out well north of 300 HP installed to be sure they meet
spec and no 520 puts out 285 HP as installed in the aircraft. The
difference is usually in the 40 HP range. The 550 guys are getting
190-195 kts true, so good in fact they can't use all their power in the
colder temps as they are way up in the yellow arc. Plus the 550 gives
you that speed at the same or less fuel flow as the 520, most guys seem
to report about a half gallon or so less fuel flow.
I still wonder about the apples-to-apples of the $50K savings you're talking
about--a few other posters have commented on comparing a 40 year old Bo to a
20 year old Trin.
That's a decision only you can make. I've owned three airplanes now and
I always want the lightest possible plane. The newer you get the more
amenities the manufacturer has added to the interior. Every one adds
weight. The newer interiors sure look like the inside of a car. If
that's what you have to have then you better buy newer. I personally
don't think there's any difference maintenence wise simply because a
plane is twenty years newer. The new one is still at least 20 years old
and the cost to maintain will still largely depend on how it has been
taken care of. Find a hangar queen that's newer and you couldn't print
enough money to keep it airworthy.
I am trying to be neutral on the subject--I know there
are plenty of '60s airplanes flying, but I also have to believe there's some
intrinsic value to being newer (all things being equal). What would your
airplane go for if it were, say, an '86 model?
A hell of a lot more. But what would be the point? I would have less
useful, go slower and it would cost a lot more to operate. Simply
because I insure it for more my premium goes way up. In terms of total
dollars spent the older airplane costs orders of magnitude less.
The insurance is a point well taken--I have NOT priced insurance on Bos.
May I ask what to expect on that?
A year and a half ago when I bought the Bo I had about 1050 hours TT,
almost all in my 182. No retract time at all. $90K hull and insured
for six seats. $2800 the first year. Dropped to $2300 for this year.
I completely forgot to ask to have it insured for four seats only, I'll
do that next renewal. I would expect the premium to be less than $2K
with six seats.
  #172
Old January 19th 07, 05:40 AM posted to rec.aviation.owning
Jay Honeck
However, I also know that I NEVER worry about weight & balance, which
is a wonderful thing. Four 200 pound guys, full fuel, 90 degrees?
Right -- let's go!
NEVER?
"...adding a touch of Paul-power."
Okay, okay...with a person of a certain...stature...positioned in
Atlas' copilot's seat, it is necessary to carry a *bit* more power in
the landing flare. However, we have NO problem taking off, even with
full tanks and three other people on board. Very few single engine
planes could do that.
Montblack
So far, Atlas gets 30 more lbs of useful load - and counting :-)
Way to go!
This winter, I'm kinda going the other way. I've "found" 10 of those
30 pounds you lost!
Jay Honeck
Iowa City, IA
Pathfinder N56993
www.AlexisParkInn.com
"Your Aviation Destination"
  #173
Old January 19th 07, 05:57 AM posted to rec.aviation.owning
Newps
"Newps" wrote in message
Does the FBO in Burnt Scrotum, Nevada
BTW, you owe me a new keyboard...!
Got that one from Al Bundy his own self.
  #174
Old January 19th 07, 06:00 AM posted to rec.aviation.owning
Newps
Jay Honeck wrote:
I taught myself the "short women landing a 182" trick and my instructor
wanted to throttle me. I trimmed it for the flare and pushed it forward
on short final. I didn't have the arm strength to yank it into the
flare if I was sitting close enough to reach the rudder. About a month
later Rod Machado wrote up pretty much what I had figured out.
That's awesome! I may just try that technique myself, just to see how
it works.
This I don't understand. With just myself in my old 182 the CG is
pretty far forward. Properly trimmed it's a two finger operation to
flare. If you have to yank it you're really doing something wrong.
  #175
Old January 19th 07, 09:29 AM posted to rec.aviation.owning
Thomas Borchert
Douglas,
In particular,
the design & ergonomics comment is on target.
Thanks. Just the visibility out of a modern design (Trinidad, even more
the Cirrus and WAY more the DA-40/42) blows you away.
Thomas Borchert (EDDH)
  #176
Old January 19th 07, 01:08 PM posted to rec.aviation.owning
Matt Whiting
it works.
That was my experience also. And I flew my 182 often alone with the cg
pretty far forward. If I trimmed for 80 MPH I found that after dropping
flaps 40, the force required to flare was not bad at all. Definitely
attainable with two fingers.
Matt
  #177
Old January 19th 07, 06:37 PM posted to rec.aviation.owning
dave
Sour grapes?
Dave
M35
Jay Honeck wrote:
Beech just announced they are lowering prices on the Bonanza and Baron.
Now a typically outfitted glass panel Bo has a suggested retail of
$574K down from $667K. The Baron goes from $1.186 million to $1.046
million.
That's absurd. What kind of a dolt would pay that kind of money for
what amounts to a brand-new antique? You can buy a perfectly good
used biz-jet for those prices!
It would certainly take an unusual combination of money and gullibility
-- which (I suppose) explains why Beech sells so few of them.
Jay Honeck
Iowa City, IA
Pathfinder N56993
  #178
Old January 19th 07, 10:02 PM posted to rec.aviation.owning
Matt Whiting
dave wrote:
Sour grapes?
Dave
M35
million.
Jay Honeck
Iowa City, IA
Pathfinder N56993
www.AlexisParkInn.com "Your Aviation Destination"
No, I'm guessing just a lack of money and gullibility. :-)
Matt
  #179
Old January 20th 07, 02:52 AM posted to rec.aviation.owning
Dave[_5_]
My experience as well - and I've been flying mine for 29 years now. I
have found, though, that it is easier to get a smooth landing if you
use only 30 degrees of flap. So I reserve 40 for when I really need it
(not often).
I'm wondering if there is a difference between older and newer 182s (I
fly a B model). I frankly don't know what
these guys are talking about.
David Johnson
  #180
Old January 20th 07, 03:43 AM posted to rec.aviation.owning
Matt Whiting
(not often).
I always used 40. The only time I ever landed with less than 40 was
during practice and the night I got iced up... :-)
That could be. I flew a K model, but I can't imagine the newer
airplanes being all that much different.
Matt
Narrowing it down... Comanche? Douglas Paterson Owning 18 February 26th 06 01:51 AM
Cherokee Pilots Association Fly-In Just Gets Better and Better Jay Honeck Piloting 7 August 8th 05 08:18 PM
Comanche accident averted last evening [email protected] Piloting 23 April 13th 05 11:02 AM
Cherokee National Fly-In & Convention Don Piloting 0 May 5th 04 09:14 PM
Cherokee National Fly-In & Convention Don General Aviation 0 March 20th 04 03:15 AM
