By the way, I have had ours out in -13 and the oil temp is pretty low,
even with the plate on. No battery boost was needed, even with the aging cable. With thermal underwear it was still too cool for my tastes. Is that -13 F? If so, I've flown at that temperature, and it's quite amazing. Everything creaks, and groans, and sounds different. Pre-flighting is an exercise in endurance, and your eyes water so badly you can't see a danged thing. Once everything is warmed up, however, the performance is spectacular! The heater does not keep the plane at any comfort level below 0F. Mike, I'd check to make sure the passenger compartment is relatively airtight. When we flew our Warrior at that temperature (I've not had the opportunity with the Pathfinder, yet), we were toasty warm in just a few minutes. That Cherokee heater kicks out a lot of BTUs, and should do the job, even when it's that cold -- unless the heat is being sucked out through a bad door seal. (Or under the back seat. Or due to leaky air vents.) I see what the other respondent was saying about the hangar woes. Here, they plow in front of the hangars and leave a nice 10-15 inch bump of snow that turns to solid ice when the sun bounces off the hangars and partially melts it during the day and it solidifies at night. Ours, too. We've taken to driving to the airport immediately after a snowstorm, just so we can clear the area in front of the hangar door. (Our first year here we didn't know to do that, and there were days when we literally had to use a hammer and chisel to chip away the ice, just so we could open the door. It was frozen to the ground!) -- Jay Honeck Iowa City, IA Pathfinder N56993 www.AlexisParkInn.com "Your Aviation Destination" |
" Ours, too. We've taken to driving to the airport immediately after a
snowstorm, just so we can clear the area in front of the hangar door. (Our first year here we didn't know to do that, and there were days when we literally had to use a hammer and chisel to chip away the ice, just so we could open the door. It was frozen to the ground!) Exactly. And when jumping into the plane after this workout exercise, the body sweat promptly converts to ice on the windows ;(. After two such experiences I started to change into a dry T-shirt and sweater before entering the airplane. No more problems with ice on the windows. One final admonition regarding cold weather flying. The weather can change pretty fast from sunny to low clouds with risk of icing. Be vigilant. I've twice run into sleet or freezing rain before even clearing the pattern, when the weather still looked OK on the apron. But as I said, on a clear day winter flying is a great experience. Nils Helsinki, Finland |
"Nils Rostedt" writes:
Exactly. And when jumping into the plane after this workout exercise, the body sweat promptly converts to ice on the windows ;(. Try leaving the storm window open at first, until the defroster is pumping out enough heat. That trick works to keep a car from frosting or fogging up as well (just open the windows a bit). All the best, David |
"David Megginson" wrote .. "Nils Rostedt" writes: Exactly. And when jumping into the plane after this workout exercise, the body sweat promptly converts to ice on the windows ;(. Try leaving the storm window open at first, until the defroster is pumping out enough heat. That trick works to keep a car from frosting or fogging up as well (just open the windows a bit). Right, that's standard practice here in winter. The problem is, that the defroster has very poor effect during the warm-up and slow taxi phase. Sufficient warm air only starts to flow during the take-off run when full power is applied. At least this is the case in the two-seaters I've flown. Maybe the bigger tin cans do better. Anyway I've found it's much more comfortable (and safe) to go inside, or to my car, and quickly switch into a dry shirt before boarding the cold airplane. Less frost on the canopy, and a much warmer feeling until the plane's heater finally kicks in. Hey, every bushpilot has a spare shirt anyway ;-) / Nils Helsinki, Finland |
In article GFThb.738459$uu5.125046@sccrnsc04, Jay Honeck wrote:
Mike, I'd check to make sure the passenger compartment is relatively airtight. When we flew our Warrior at that temperature (I've not had the Apparently the opposite can cause a problem as well. Somebody on the Short-Wing Piper list recently was complaining about having sealed up everything, and now it's cold in the winter. Apparently, if you seal too much, once the cabin gets 'pressurized', the heater isn't moving warm air into the cabin anymore. But that's just what I hear. Alternately, you could move to Houston, and then you'd never need your airplane heater again. Tina Marie -- http://www.tripacerdriver.com "...One of the main causes of the fall of the Roman Empire was that, lacking zero, they had no way to indicate successful termination of their C programs." (Robert Firth) |
the Short-Wing Piper list recently was complaining about having sealed up everything, and now it's cold in the winter. Apparently, if you seal too much, once the cabin gets 'pressurized', the heater isn't moving warm air into the cabin anymore. Well, I sealed up every air leak I could find in my old Warrior, and only made it warmer -- but I suppose you could reach a point of being TOO sealed. All I know is I've sure never seen a plane that was too tightly sealed. Most planes I've ridden in are at least 20 years old, and leak air like sieves. -- Jay Honeck Iowa City, IA Pathfinder N56993 www.AlexisParkInn.com "Your Aviation Destination" |
Jay Honeck wrote:
All I know is I've sure never seen a plane that was too tightly sealed. Most planes I've ridden in are at least 20 years old, and leak air like sieves. Hey let's not go giving sieves bad names. At least they stop *something*. :-) Russell Kent |
"Jay Honeck" wrote in message
news:qgijb.777606$YN5.761167@sccrnsc01... All I know is I've sure never seen a plane that was too tightly sealed. Most planes I've ridden in are at least 20 years old, and leak air like sieves. Mine doesn't help much by having a 1.5" gap between the back of the canopy and the fuselage. :-) The heater's quite good though, at least for temperatures I've flown in. Paul |
Thanks Mike. From your experience and other comments on this thread it
seems; this is a common problem that doesn't get worse, does not create irreparable damage and it can be fixed. At least it can be fixed so that the engine doesn't stumble start in mid-summer. The previous owner was convinced the solution was a geared starter, and he was probably right. Now, I'm starting to get the impression the problem could also be fixed with an overhaul of my existing starter. As I mentioned on a previous post I'll research and post. Cheers! Jose Vivanco C-GPYH "Mike Spera" wrote in message ... My 140 has required the initial "bump" you describe for the last ten years I owned it. Our positive braided battery strap has always been in marginal shape. I will probably replace it this fall. It is split at the battery post and does not offer the best connection. What is that hardened putty-like stuff that insulates it from the battery box? That looks like a really crude solution. Do they make some sort of (legal) rubber isolator as a replacement, or do I have to replace it with the same goop? By the way, I have had ours out in -13 and the oil temp is pretty low, even with the plate on. No battery boost was needed, even with the aging cable. With thermal underwear it was still too cool for my tastes. The heater does not keep the plane at any comfort level below 0F. Here in Illinois, +10-+15F is about the reasonable limit on a tiedown. Fortunately, daytime temps don't go lower than that very often. I see what the other respondent was saying about the hangar woes. Here, they plow in front of the hangars and leave a nice 10-15 inch bump of snow that turns to solid ice when the sun bounces off the hangars and partially melts it during the day and it solidifies at night. Mike Jose Vivanco wrote: I live in Ottawa, Canada and this is my first winter as a PA-28-140 owner. My airplane does have copper battery cables (cable ?) and an engine heater but the previous owner warned me; in really cold weather, below (-10C/-23 F) it won't start without a battery boost. The battery boost is in addition to plug-in the aircraft for about an hour before departure. The aircraft doesn't have an engine cover AND it does not have a geared starter. Are there any other PA-28-140s with a similar problem? I will be getting an engine cover, but I don't think this alone will eliminate the battery boost requirements. The battery is two years old. Normal summer start always looks like the battery is dead, i.e. one blade goes by and the prop stops turning, ignition back to off, then crank again and it fires up immediately. My plan this winter is to get a trickle charger for the battery, blanket battery warmer plus regular plug-in of the engine heater. Any other ideas would be greatly appreciated. Thanks in advance. Jose Vivanco C-GPYH. __________________________________________________ __________________________ ___ Posted Via Uncensored-News.Com - Accounts Starting At $6.95 - http://www.uncensored-news.com The Worlds Uncensored News Source |
I have an E3D also. I noticed another fellow suggested field wiring open
circuits that cause this problem. Well, the problem has persisted through 2 different starters (the second one a fresh overhaul when we swapped out the engine). So, I tend to rule out the starter being the problem. Check your cable connections at the battery. They may be starting to deteriorate. Good Luck, Mike Jose Vivanco wrote: Thanks Mike. From your experience and other comments on this thread it seems; this is a common problem that doesn't get worse, does not create irreparable damage and it can be fixed. At least it can be fixed so that the engine doesn't stumble start in mid-summer. The previous owner was convinced the solution was a geared starter, and he was probably right. Now, I'm starting to get the impression the problem could also be fixed with an overhaul of my existing starter. As I mentioned on a previous post I'll research and post. Cheers! Jose Vivanco C-GPYH "Mike Spera" wrote in message ... My 140 has required the initial "bump" you describe for the last ten years I owned it. Our positive braided battery strap has always been in marginal shape. I will probably replace it this fall. It is split at the battery post and does not offer the best connection. What is that hardened putty-like stuff that insulates it from the battery box? That looks like a really crude solution. Do they make some sort of (legal) rubber isolator as a replacement, or do I have to replace it with the same goop? By the way, I have had ours out in -13 and the oil temp is pretty low, even with the plate on. No battery boost was needed, even with the aging cable. With thermal underwear it was still too cool for my tastes. The heater does not keep the plane at any comfort level below 0F. Here in Illinois, +10-+15F is about the reasonable limit on a tiedown. Fortunately, daytime temps don't go lower than that very often. I see what the other respondent was saying about the hangar woes. Here, they plow in front of the hangars and leave a nice 10-15 inch bump of snow that turns to solid ice when the sun bounces off the hangars and partially melts it during the day and it solidifies at night. Mike Jose Vivanco wrote: I live in Ottawa, Canada and this is my first winter as a PA-28-140 owner. My airplane does have copper battery cables (cable ?) and an engine heater but the previous owner warned me; in really cold weather, below (-10C/-23 F) it won't start without a battery boost. The battery boost is in addition to plug-in the aircraft for about an hour before departure. The aircraft doesn't have an engine cover AND it does not have a geared starter. Are there any other PA-28-140s with a similar problem? I will be getting an engine cover, but I don't think this alone will eliminate the battery boost requirements. The battery is two years old. Normal summer start always looks like the battery is dead, i.e. one blade goes by and the prop stops turning, ignition back to off, then crank again and it fires up immediately. My plan this winter is to get a trickle charger for the battery, blanket battery warmer plus regular plug-in of the engine heater. Any other ideas would be greatly appreciated. Thanks in advance. Jose Vivanco C-GPYH. __________________________________________________ __________________________ ___ Posted Via Uncensored-News.Com - Accounts Starting At $6.95 - http://www.uncensored-news.com The Worlds Uncensored News Source __________________________________________________ _____________________________ Posted Via Uncensored-News.Com - Accounts Starting At $6.95 - http://www.uncensored-news.com The Worlds Uncensored News Source |
| Thread Tools | |
| Display Modes | |
| Ultralight Club Bylaws - Warning Long Post | MrHabilis | Home Built | 0 | June 11th 04 06:07 PM |
| Mountain flying instruction: McCall, Idaho, Colorado too! | [email protected] | General Aviation | 0 | March 27th 04 12:24 AM |
| Ice meteors, climate, sceptics | Brian Sandle | General Aviation | 43 | February 24th 04 01:27 AM |
| FA: WEATHER FLYING: A PRACTICAL BOOK ON FLYING | The Ink Company | Aviation Marketplace | 0 | November 5th 03 01:07 AM |
| Eurofighter - useless in cold weather and fog? | Peter Kemp | Military Aviation | 9 | September 13th 03 05:37 AM |
