Flying to Arlington, VA
Old February 19th 04, 04:09 PM
Michelle P
John,
Yes, is some instances you can start over.
I believe unless it is criminal, you can start over if you wish.
In one case a flight instructor did not enter the last digit in the
Garmin 327 Transponder since it was already the octet they wanted.
Apparently, the the 327 stops squawking your code while you are entering
it. Makes sense, you do not want to be sending several different codes
while you are changing it. Just make sure you enter all four octets when
changing codes.
Michelle
John Clonts wrote:
"Michelle P" wrote in message
link.net...
Sami,
Rick has a good point. Do a little more than read up on the ADIZ, give
Leesburg AFSS a call directly and ask about the operations into and out
of the ADIZ. Their direct phone number is 703-777-2856 .I also have a
toll free number but I am not sure if it will work from your area.
866-228-7410
If you bust it you WILL loose your license. The marshalist TSA has
mandated that any pilot who violates the ADIZ must loose their license.
I know of two pilots who have had to start over because they
un-intentional wandered into the ADIZ without following the procedures.
Make sure you ask about entry points from the west. There are common
points that the controllers expect.
Hi Michelle,
What do you mean, "...had to start over..."? Did they have their
certificates taken away, but they can some how earn them back? Wow, that IS
nuts!
Cheers,
John Clonts
Temple, Texas
N7NZ
Michelle P ATP-ASEL, CP-AMEL, and AMT-A&P
"Elisabeth" a Maule M-7-235B (no two are alike)
Volunteer Pilot, Angel Flight Mid-Atlantic
Volunteer Builder, Habitat for Humanity
Ultralight Club Bylaws - Warning Long Post MrHabilis Home Built 0 June 11th 04 06:07 PM
Mountain flying instruction: McCall, Idaho, Colorado too! [email protected] General Aviation 0 March 27th 04 12:24 AM
Progress on Flying Car Steve Dufour General Aviation 5 December 19th 03 04:48 PM
FA: WEATHER FLYING: A PRACTICAL BOOK ON FLYING The Ink Company Aviation Marketplace 0 November 5th 03 01:07 AM
How I got to Oshkosh (long) Doug Owning 2 August 18th 03 01:05 AM
