#11
In article , Steve Waltner
wrote: I'm to the point of installing the fuel fittings on the fuel tanks on my RV-8A project. I'm a little confused about what torque to set my wrench at when installing the fitting. The fitting that goes through the tank rib and 3/16" reinforcement plate is an AN833-6D elbow with an AN924-6D nut on the outside. There are also a pair of -4D fittings for the vent line which will soon be mounted as well. The only torque chart that I'm ever able to find is one for AN bolts/nuts. Since these are aluminum fittings, I don't dare torque them to the same values. Any assistance would be greatly appreciated. Steve Thanks for the responses. I ended up and called Van's yesterday. The response was that there is no official torque value for the nut that attaches the fitting to the rib. The sealant apparently provides a fair amount of the support on holding the fitting in place instead of the nut. This confirms what I was told by some others that I had asked this same question which was, tighten it down to where the nut bottoms out and go on to the next task. I sealed the various fitings onto the inboard ribs last night. Steve |
| Thread Tools | |
| Display Modes | |
| Torque values for oil screen | John Clonts | Owning | 2 | January 25th 05 01:01 AM |
| Fuel pump fittings | Evan Carew | Home Built | 15 | October 3rd 04 04:13 AM |
