"Aluminum Overcast" damaged by gear collapse
Old May 7th 04, 04:49 PM
G.R. Patterson III
Pat wrote:
James Robinson wrote in message ...
The B-17 bomber owned by the Experimental Aircraft Assn. was damaged
yesterday at Van Nuys airport when its main gear collaped.
Am I the only one who finds it a bit "suspicious" that both main gear
collapsed on this bird? If I recall correctly, they are two
independant systems. The common link would be in the cockpit... right
next to the flaps switch.
According to the Pilot Training Manual, the gear activation switch is located between
the recognition light switches and the landing light switches. It is not particularly
close to the flap switch. The flap switch is isolated, is not part of a row of
switches (as is the gear switch), and it has side guards to make it easy to
differentiate between it and other controls. Personally, I think the LG switch should
be the one that's isolated and guarded, but ....
Anyone else think that perhaps the gear
were inadvertantly retracted (pilot attempting to retract flaps)
rather than a mechanical failure...???
I doubt it. I think an electrical problem is much more likely on a 60 year old plane.
George Patterson
If you don't tell lies, you never have to remember what you said.
Old May 7th 04, 05:13 PM
Dale
between
particularly
of
switch should
Both the gear and flap switches are toggle switches, they are within a
couple inches of each other on the center console. On the B-17 I flew
the gear switch had a cover that had to be lifted to activate the
rectraction. Even so our procedure was for the NFP to touch the flap
switch and say "Confirm flaps?"..the FP then would check to be sure the
flap switch was selected and reply "Flaps confirmed"...then and only
then would the flaps be retracted.
old plane.
The gear on the -17 are electrical. Each gear has it's own
motor...nothing ties the left side to the right side. The only common
item is the gear switch. The only failure I can think of that would
cause the gear to retract would be a failure in the switch that closed
the switch. The most likely failure would be human.
Dale L. Falk
There is nothing - absolutely nothing - half so much worth doing
as simply messing around with airplanes.
http://home.gci.net/~sncdfalk/flying.html
Old May 8th 04, 04:37 AM
Buff5200
I watched the crash video frame-by-frame. The right main wheel appeared to
separate from the gear 1/10 second before the right main gear collapsed.
Then the left main gear collapsed, a few tenths after the right main.
Looks to me as if the right gear wheel axle may have failed.
George Patterson
Old May 8th 04, 05:36 AM
G.R. Patterson III
Got a URL?
If the gear collapsed suddenly, then it was not inadvertently raised on the ground.
Retraction is by a screw mechanism and takes a few seconds.
George Patterson
Old May 8th 04, 02:01 PM
Kyle Boatright
"G.R. Patterson III" wrote in message
Got a URL?
the ground.
George Patterson
I don't know how the retraction system works, so I 'm asking..
1) Isn't the screw jack "sized" for air loads, with some sort of over
center mechanism to handle the ground loads?
2) If that's the case, does the gear retraction mechanism have enough power
to pull the gear back "under center" (?) while the aircraft is on the
ground?
3) Would the screw jacks fail in this case?
What I'm getting at is if someone flipped the wrong switch, could that
explain the collapse of both mains, and explain why there are apparently
broken screw jacks on both mains? Otherwise, I find it extremely unlikely
that both gear systems (they are independant, right?) would have a similar
mechanical failure at the same time...
KB
Old May 9th 04, 01:51 AM
G. Burkhart
Got a URL?
Try this...
http://kcbs.dayport.com/launcher/2643/
It was listed on here...
http://cbs2.com/video/
Old May 9th 04, 05:43 PM
Buff5200
Got a URL?
Sorry, no URL, just TiVo.
Old May 9th 04, 09:53 PM
Rick Durden
George,
CAF is already saying the copilot pulled the gear up when he went for
the flaps, despite being told to keep his hands off the flap switch
until off the runway. On that B-17 the switches are within inches of
each other and the gear switch is not guarded.
Shades of the old Bonanzas.
sigh
All the best,
Rick
"G.R. Patterson III" wrote in message ...
George Patterson
Old May 10th 04, 02:13 AM
Ben Jackson
I just went through some mail and realized that on the day of the gear
collapse I got two fliers for this summer's Aluminum Overcast tour. I
guess I don't need to add those dates to my calendar.
Ben Jackson
http://www.ben.com/
Old May 11th 04, 03:37 PM
G.R. Patterson III
Rick Durden wrote:
George,
It's interesting then that as of this morning, the EAA's position is still "We are
using that new video to help us understand exactly what happened. Our emphasis,
naturally, is on the landing gear and discovering why it malfunctioned".
They seem to be a little slow getting the word.
George Patterson
EAA's B-17 "Aluminum Overcast" Gear collapse at Van Nuys airport BlakeleyTB Home Built 4 May 8th 04 07:15 AM
Aluminum vs Fiberglass landing gear - Pro's and cons. Bart Hull Home Built 1 November 24th 03 03:46 PM
Aluminum vs Fiberglass landing gear - Pro's and cons. Bart Hull Home Built 2 November 24th 03 06:23 AM
Aluminum vs Fiberglass landing gear - Pro's and cons. Bart Hull Home Built 0 November 24th 03 04:52 AM
Aluminum vs Fiberglass landing gear - Pro's and cons. Bart D. Hull Home Built 0 November 22nd 03 07:24 AM
