Peter Duniho wrote:
"Mike Rhodes" wrote in message ... [...] If the control inputs are controlled, as I believe Airbus is, then the pilot cannot be blamed for over-controlling; unless the manufacturer pointedly states not to do that. The manual for my airplane (and most, I believe) says nothing about not pulling too hard on the yoke when recovering from a dive in which the airspeed exceeds Vne. Does that mean that the manufacturer would be to blame if I caused the wings to fail by doing so? I don't think so. I'm curious why it appears that you would. The manual does likely say something about the definition of Vne, however. - Andrew |
On Tue, 26 Oct 2004 14:11:41 -0700, "Peter Duniho"
wrote: "Mike Rhodes" wrote in message .. . [...] If the control inputs are controlled, as I believe Airbus is, then the pilot cannot be blamed for over-controlling; unless the manufacturer pointedly states not to do that. The manual for my airplane (and most, I believe) says nothing about not pulling too hard on the yoke when recovering from a dive in which the airspeed exceeds Vne. Does that mean that the manufacturer would be to blame if I caused the wings to fail by doing so? I don't think so. I'm curious why it appears that you would. I'm guessing you're not really curious, for the general nature of you reply was not one intended to encourage discussion. As for the paragraph above I'm very surprised you think that makes any point at all, other than my own. Because it is rhetorical... --Mike |
On Tue, 26 Oct 2004 at 20:52:36 in message
, Mike Rhodes wrote: I recall some question concerning a weakness in the design of the rudder itself, in that the supports to the composite structure were too few. Not too long after the accident, I saw it was explained on TV that the manufacturer should have distributed the load over more points for the sake of the composite material. The known and understood weakness of composites, compared to metals, is their lesser ability to handle bearing stress. So Airbus should've known better, presumably. The original pictures seemed to show clearly that the root attachments failed at the attachment to the fuselage. How easy in turbulence is it to develop a pilot induced yaw oscillation? The fin might well withstand a full deflection but not a few reversals that built up the maximum yaw oscillation. Fins and rudders are as big as they are to deal with the engine out case at relatively low speed I understand. Isn't one of the functions of a yaw damper to restrict and damp a yaw oscillation? Do the reports give any indication of the amount of yaw excursion that took place? -- David CL Francis |
"David CL Francis" wrote in message ... On Tue, 26 Oct 2004 at 20:52:36 in message , Mike Rhodes wrote: I recall some question concerning a weakness in the design of the rudder itself, in that the supports to the composite structure were too few. Not too long after the accident, I saw it was explained on TV that the manufacturer should have distributed the load over more points for the sake of the composite material. The known and understood weakness of composites, compared to metals, is their lesser ability to handle bearing stress. So Airbus should've known better, presumably. The original pictures seemed to show clearly that the root attachments failed at the attachment to the fuselage. How easy in turbulence is it to develop a pilot induced yaw oscillation? The fin might well withstand a full deflection but not a few reversals that built up the maximum yaw oscillation. Fins and rudders are as big as they are to deal with the engine out case at relatively low speed I understand. Isn't one of the functions of a yaw damper to restrict and damp a yaw oscillation? Do the reports give any indication of the amount of yaw excursion that took place? -- David CL Francis correct me if i am wrong but wasnt it the ntsb that a few years before aa 587 critized a crew for not using full and complete control deflection for another accident? i do not remember which one it was but shortly after some of the airlines started going to those upset recovery courses. sounds like the ntsb wants it both ways. tony zambon grumman 9941L |
Could someone refresh my memory....
what is the definition of maneuvering speed again? |
PS2727 wrote:
Could someone refresh my memory.... what is the definition of maneuvering speed again? That you can fully deflect any control surface without structural damage. However, this does *not* necessairily imply that you can waggle from one extrem to the other! Actually, you can't do so with many airliners. Stefan |
Stefan wrote:
PS2727 wrote: Could someone refresh my memory.... what is the definition of maneuvering speed again? That you can fully deflect any control surface without structural damage. However, this does *not* necessairily imply that you can waggle from one extrem to the other! Actually, you can't do so with many airliners. I recently read an article on this subject; I just cannot recall where. It's not just "waggle from one extreme to another" that's not covered by Va, but also multiple inputs (ie. aeleron and rudder) in directions which cause opposing (or concurring?) forces. Anyone recall this article? Otherwise, I'll be digging through some magazines tonight. - Andrew |
PS2727 wrote:
Could someone refresh my memory.... what is the definition of maneuvering speed again? Design manouvering speed applies to pitch changes. |
Before or after the loss of this aircraft?
PS2727 wrote: Could someone refresh my memory.... what is the definition of maneuvering speed again? |
As a multiengine instructor who has witnessed students applying full rudder in
the wrong direction after a simulated engine failure then quickly apply full opposite rudder in the correct direction am I to understand that I was in mortal danger from the tail breaking off? Seems that is a little late in telling pilots how these things are designed....What next, we can't reverse ailerons when landing in gusty conditions without breaking something there as well? Also, maybe someone can explain why the rudder limiter on this Airbus didn't protect the structure when its sole purpose in life is to prevent damage to the structure by limiting rudder movement at higher speeds. |
| Thread Tools | |
| Display Modes | |
| AOPA Stall/Spin Study -- Stowell's Review (8,000 words) | Rich Stowell | Aerobatics | 28 | January 2nd 09 03:26 PM |
| Dover short pilots since vaccine order | Roman Bystrianyk | Naval Aviation | 0 | December 29th 04 01:47 AM |
| [OT] USA - TSA Obstructing Armed Pilots? | No Spam! | Military Aviation | 120 | January 27th 04 11:19 AM |
| [OT] USA - TSA Obstructing Armed Pilots? | No Spam! | General Aviation | 3 | December 23rd 03 09:53 PM |
| AOPA Stall/Spin Study -- Stowell's Review (8,000 words) | Rich Stowell | Piloting | 25 | September 11th 03 02:27 PM |
