#11
"Eric D" wrote in message om... What does the manufacture have to say on this matter. They write the maintenance manual. I'm checking the 350 manuals but nothing so far. The running 315/3180 without blades was shown to us by the factory rep when we first bought it. Slatts Factory rep or not, if it isn't in one of the maintenance manuals as one of the proceedures, you would be wise not to do it. One of the concerns I would have is the affect on other components without the inertia of the main rotors in the system. Could you unknowingly damage something in the driveline? The manufacture is the best source for figuring this type of thing out. Yes, there is nothing in either manual. I've checked with a couple of engineers who worked on Alouettes they all ran them without blades. It's a standard procedure. (How else are you going to change a servo in the field?) Slatts |
"Sla#s" wrote in message ...
Slatts Factory rep or not, if it isn't in one of the maintenance manuals as one of the proceedures, you would be wise not to do it. One of the concerns I would have is the affect on other components without the inertia of the main rotors in the system. Could you unknowingly damage something in the driveline? The manufacture is the best source for figuring this type of thing out. Yes, there is nothing in either manual. I've checked with a couple of engineers who worked on Alouettes they all ran them without blades. It's a standard procedure. (How else are you going to change a servo in the field?) Slatts Slatts, From your last posting see UK in the link above. I had thought you were located here in the US. Sorry. In the US, to be a standard maintenance procedure it better be in the current maintenance manual. Short of that, it needs to be in a, Service Bulletin, Advisory Directive or some type of written process from the manufacture in order to be acceptable to the FAA. Performing any maintenance without something acceptable to the FAA and you are setting yourself up for loss of license and possible legal liability. Sorry to say I have no suggestion to help you find what you are looking for. Eric D |
"Eric D" wrote in message om... SNIP In the US, to be a standard maintenance procedure it better be in the current maintenance manual. Short of that, it needs to be in a, Service Bulletin, Advisory Directive or some type of written process from the manufacture in order to be acceptable to the FAA. Performing any maintenance without something acceptable to the FAA and you are setting yourself up for loss of license and possible legal liability. That is unfortunately is what is starting to happen here. In the past when one signed on one's licence you took the responsibility for what you did. Nowadays when one signs on a company approval as you say if it is not in the book somewhere it can't be done. I guess with old fashioned machines that was not a problem but now they are too complicated for one person to use his judgement :-) I'm talking about machines where the M&O manual was less an inch thick as opposed to some today where they take up six feet of shelf space! Slatts |
| Thread Tools | |
| Display Modes | |
| Best dogfight gun? | Bjørnar Bolsøy | Military Aviation | 317 | January 24th 04 07:24 PM |
| Tactical Air Control Party Airmen Help Ground Forces | Otis Willie | Military Aviation | 0 | January 22nd 04 03:20 AM |
| Wing in Ground Effect? | BllFs6 | Home Built | 10 | December 18th 03 06:11 AM |
| USAF = US Amphetamine Fools | RT | Military Aviation | 104 | September 25th 03 04:17 PM |
| Antenna Ground Plane Grounding | Fastglasair | Home Built | 1 | July 8th 03 06:21 PM |
