Screw hold repair in fabric?
Old May 25th 04, 01:14 AM
Brian Huffaker
Default Screw hold repair in fabric?
It's annual time on the starduster, and several of the screw holds
to hold on the inspection plates have been enlarged over the years to
the point where a screw won't stay in the whole. Around each inspection
hole, there is a thickened area in the fabric that has been drilled
or punched to recieve the screws. We are using sheet metal screws.
I don't know what covering system was used, but could probably find
out (it was recovered several years before I bought into the
partnetship). Is there some kind of filler that could be placed in
these holes and then drilled out back to a smaller size so that the
screws would stay in?
Thanks in advance for any ideas.
Brian Huffaker, DSWL )
RV-8A 80091 Riviting foward lower fuseage skin
1/4 Starduster Too N23UT flying.
Old May 25th 04, 04:27 AM
Ernest Christley
A toothpick dipped in your favorite glue. Several toothpicks if the
hole is large.
http://www.ernest.isa-geek.org/
"Ignorance is mankinds normal state,
alleviated by information and experience."
Veeduber
Old May 25th 04, 04:40 AM
Jim Weir
Tinnermans?
-Brian Huffaker wrote:
- It's annual time on the starduster, and several of the screw holds
- to hold on the inspection plates have been enlarged over the years to
- the point where a screw won't stay in the whole. Around each inspection
- hole, there is a thickened area in the fabric that has been drilled
- or punched to recieve the screws. We are using sheet metal screws.
- I don't know what covering system was used, but could probably find
- out (it was recovered several years before I bought into the
- partnetship). Is there some kind of filler that could be placed in
- these holes and then drilled out back to a smaller size so that the
- screws would stay in?
http://www.rst-engr.com
Old May 25th 04, 04:32 AM
Morgans
"Brian Huffaker" wrote in message
Brian Huffaker,
I am no help for the fabric repair, but repairing the wood is right up my
alley. Drill the wood just enough to clean out the hole and make it a size
slightly larger than a hardwood dowel. Use the smallest possible. Inject
some epoxy into the hole, and onto the dowel, then tap it into the hole.
Re-drill the correct size hole for the screw, and that part is done.
If you ever recover, make sure the area that the inspection hole is in can
take it, and use a blind wood nut and machine screw. IMHO, that is what
should have been used in the first place. It might be possible to use one
right now, depending on the location, and material the screw was in, and
what the structural loads are in that area.
Outgoing mail is certified Virus Free.
Checked by AVG anti-virus system (http://www.grisoft.com).
Version: 6.0.688 / Virus Database: 449 - Release Date: 5/18/2004
Old May 25th 04, 03:46 PM
coustanis
Fill the hole with epoxy and redrill.
Works a champ.
Old May 26th 04, 03:32 PM
jls
The round inspection hole reinforcements I have seen are made of plastic and
they do get old and brittle and screw holes get elongated. They are
usually thin plastic rings that have been sandwiched between the wing's
fabric and a pinked-edge patch. Inspection covers best for these are round
aluminum plates which have attached clips 180 deg. apart which you push over
the reinforced hole and then line up the inspection plate so that it is
centered over the hole. The clips holding the cover to the fabric are
hidden inside the wing. On the faster fabric-covered airplanes like a
Pitts or Starduster the inspection cover has an inner concavity which
centers the cover and keeps it from slipping off or off-center. I have
seen some builders drill through the clips and use screws to make them hold
more tightly.
Where I have inspection plates attached to the fabric with screws, I bond a
narrow strip or plate of 016 or 020 aluminum inside the perimeter of the
hole and then use a fabric patch doubler and fold and glue it on securely
with Poly-Tak so that the aluminum reinforcement is encapsulated in fabric.
Then I drill through for the inspection cover screws and VOILA!, the
inspection cover hides the patching and the fabric doubler and lasts
forever.
Old May 26th 04, 08:47 PM
Brian Huffaker
Thanks for the ideas. Most won't work tho. These are rectangular
inspection holes with screws holding the cover plates on. The enlarged
holes are in the thickened fabric sections (there may be some plastic
embedded in there, but it doesn't look like it) The holes that go into
wood are fine. I was hoping that somebody would have experience with
a glue/epoxy something that could be used to fill in the old holes
without harming the fabric.
Sorry I can't take a picture, I'm on call this week and can't get up
to the airport.
Brian Huffaker )
RV-8A #80091 Riviting lower fuse subfloor
Old May 27th 04, 03:47 AM
Richard Lamb
to the airport.
Brian Huffaker )
Someone already suggested making backing plates from thin aluminum
sheet metal. Personally, that's the way I think I'd go about it.
Use clear shoe-goo to install the backing plates inside the fabric?
That should hold it in place when all the screws are removed.
It sounds like you are just screwing to the fabric in places...
Best of luck,
Richard Lamb
Old May 29th 04, 03:07 AM
Brian Whatcott
On Mon, 24 May 2004 23:14:10 +0000 (UTC), Brian Huffaker
Rivnuts (aluminum expanding shank), or
Rawlnuts (rubber expanding shank) are possibilities, I suppose?
Brian W
Double covering fabric covered wings [email protected] Home Built 9 May 9th 04 09:39 PM
Fabric repair D.A.L Home Built 0 April 27th 04 08:17 PM
Fabric covering processes Jerry Guy Home Built 2 January 29th 04 07:49 PM
Fabric Work Doug Home Built 9 January 26th 04 04:31 AM
Bothersome Phillips Head Screws Larry Smith Home Built 48 January 10th 04 05:26 AM
