Feet Per Minute Conversion Question
Old August 24th 03, 07:45 AM
John H. Campbell
How do you convert Kts per Sec / Meters per sec / Kilometers etc... to
Feet per minute
Look at a Winter brand vario. Full scale = 1,000fpm, 10 kt, or 5 m/s, as
the customer prefers. Only the face-plate is changed, it's the same unit
otherwise.
Old August 24th 03, 03:30 PM
JJ Sinclair
Navigational question for the day;
One minute of latitude = 1 nautical mile. At what point on the earth does 1
minute of longatude = 1 nautical mile?
JJ Sinclair
Old August 24th 03, 03:38 PM
W.J. \(Bill\) Dean \(U.K.\).
On the Equator.
W.J. (Bill) Dean (U.K.).
Remove "ic" to reply.
"JJ Sinclair" wrote in message
At what point on the earth does 1 minute of longitude = 1 nautical mile?
JJ Sinclair.
Old August 24th 03, 04:25 PM
Gene Nygaard
"Pete S" wrote in message ...
Looks like they made the mistake of assuming that a nautical mile was 6000
feet when it's actually 6080 ft
No, it's actually 1852 m in today's world. Your 6080 ft is 1853.184
m, all around the world since an international agreement on the
definition of the yard (and thus feet, inches, etc.) over 40 years
ago.
Gene Nygaard
http://ourworld.compuserve.com/homepages/Gene_Nygaard/
Old August 24th 03, 06:17 PM
Gene Nygaard
On Sun, 24 Aug 2003 14:38:07 +0100, "W.J. \(Bill\) Dean \(U.K.\)."
On the Equator.
Wrong.
There have been some geographical miles based on the equatorial
circumference, but I've never seen them called nautical miles. There
was one geographical mile equal to 4 minutes of arc on the equator, or
about 7.421 km; I have a copy of a map using these units.
Nautical miles have normally been defined to be some midrange,
midlatitude value for a minute of arc as you travel north-south along
a meridian.
At the equator, 1 minute of longitude is 1.001795 nmi.
But 1 minute of latitude (geodetic latitude, the kind normally used)
at the Equator is only about 0.9950 nmi.
JJ Sinclair.
It is at some place close to the equator, where the circumference of
the earth at that latitude is 40.0032 Mm, rather than the 40.007495 Mm
at the Equator (WGS-84 ellipsoid). A latitude close to the arccosine
of 40.0032/40.007495, or about 3½ degrees from the Equator either
north or south (a more exact value depends on which type of latitude
you use, as well as which ellipsoid you use to approximate this).
To help see this better, your "minute of longitude" at a latitude of
60 degrees would be about 0.50 nmi, and at the poles a
"minute of longitude" is 0 nmi. It is actually the minute of latitude
as you travel along a meridian (constant longitude) that most people
consider in evaluating the fit of a nautical mile to the Earth.
Now, at what point is one centigrade of latitude equal to one
kilometer?
Gene Nygaard
Old August 25th 03, 02:13 AM
Doug Hoffman
Iwrote:
I have two "older" gliders, each with 2 varios (4 varios total). 1
vario reads in feet per second, another in meters per second, another
in knots, and the last one in 100's of feet per second...
Pardon me, that should read "100's of feet per *minute*..."
-Doug
Landing and T/O distances (Was Cold War ALternate Basing) Guy Alcala Military Aviation 3 August 13th 04 01:18 PM
Hiroshima/Nagasaki vs conventional B-17 bombing zxcv Military Aviation 55 April 4th 04 08:05 AM
Looking for Cessna Caravan pilots [email protected] Owning 9 April 1st 04 03:54 AM
Question about Question 4488 [email protected] Instrument Flight Rules 3 October 27th 03 02:26 AM
got this from a friend JD Naval Aviation 7 August 31st 03 04:21 AM
