Użytkownik Janusz Kesik w wiadomości do grup dyskusyjnych ... Also gaining height (in order to shorten the tow) by a towplane with glider behind is much, really much easier and less stressing when using a short 20-30m rope. I meant gaining height in a towplane with a glider behind, by using the thermal to support the tug's climb rate. Regards, JK |
"Janusz Kesik" wrote: Użytkownik Janusz Kesik w wiadomości do grup dyskusyjnych ... Also gaining height (in order to shorten the tow) by a towplane with glider behind is much, really much easier and less stressing when using a short 20-30m rope. I meant gaining height in a towplane with a glider behind, by using the thermal to support the tug's climb rate. If the combo has found a thermal, why wouldn't the glider just release and save money? Therre have been plenty of times that I've intended to tow to 2000 or 2500 ft but then released in a thermal at 1000 - 1500 ft. -- Bruce |
Użytkownik Bruce Hoult w wiadomości do grup
dyskusyjnych ... In article , If the combo has found a thermal, why wouldn't the glider just release and save money? When the combo (now I know the word for it starts the first circle at70m, it's too low I think... ) Few circles can be useful.JK |
To keep the reply short, I'll only say what I was taught when practising
the "wave tow". First, fly low, well below the propwash. Second: be on the ball all the time - just "show" the spoilers. Not open them, but just show an inch of them (unless the the line is slack much which needs opening them fully to avoid collision with the towplane) and when the line is about to get straight, close them. Finally, you can always use some sideslip (yaw?) to keep the line straight. This works, and we were doing things when my hairs went straight up. [for ones who know how effective are the Junior's airbrakes, I'll say only that full brakes in a sideslip with controls fully moved were often not enough to manage all the situations that the Yak pilot had shown us that day.] ![]() Regards, -- Janusz Kesik visit www.leszno.pl - home of the www.css-leszno.it.pl |
At 15:06 05 December 2003, Hank Nixon wrote:
Myth: you can get too low and pull tug tail down stalling him- We tried and found we could actually go slower in control towing with Super Cub with glider hanging way low than we could with glider off. Myth: Rope wil tie itself around wing and disble controls if released at front. Show me a rope that can go upwind in a 60 mph headind. Neither of these are myths, it actually happened two years ago at the Cambridge Gliding Club though not as a result of using low tow. The tug was flying too slow and the Puchacz on the back got gradually lower, ending up pulling the tugs tail down as he applied more and more power, eventually the tuggie released and the rope wrapped itself around the puch wing (fortunately not fouling any controls in this case). Both aircraft subsequently landed safely with no damage. Although I was present on the airfield I didn't witness the incident, I did speak to the P1 shortly afterwards, I'm sure someone from the Cambridge club could give you more detail. |
A lot of different techniques - little consensus
Bruce - Hi to slow and get slack out, then match speeds by diving Brian - Yaw to reduce snappiness when line comes taut Janusz - Shorter rope so tug and glider are in the same air Michel - Low tow and avoid slack line Although Bruce's approach is most elegant, I think it also requires the most skill and best timing. Matching airspeeds is challenging. Brian's approach is pretty standard, but also requires a little bit of timing. I'd also be surprised if he isn't subtly using a little bit of dive at the end to help match airspeeds. Janusz and his 20 meter rope leaves me speechless. I'd have to try it to have any real opinion. Michel's low tow seems like a low-skill winner. As long as you don't get too low and scare the towpilot into releasing it seems you'll do ok. Not mentioned is the use of spoilers. I've noticed one ranked pilot who flies a slick glider sometimes with ballast uses slight spoiler adjustment to regulate slack line. Any rotor towpilots have any further opinions? |
Użytkownik Mark James Boyd w wiadomości do grup
dyskusyjnych napisał:3fd0d41d$1@darkstar... A lot of different techniques - little consensus Although Bruce's approach is most elegant, I think it also requires the most skill and best timing. Matching airspeeds is challenging. For me it looks for a great way to break the rope, but I migth be wrong of course. Janusz and his 20 meter rope leaves me speechless. I'd have to try it to have any real opinion. 30m rope is a standard, but when switching for a 20m, it seems a bit scary for the first time when You can see if the ring at the end of the rope is properly connected to the Wilga's (towplane) towhook. I'mjoking of course, but for the first time it can look strange. Usually one gets used to it very quickly. Michel's low tow seems like a low-skill winner. As long as you don't get too low and scare the towpilot into releasing it seems you'll do ok. You can always fly just_in_the_propwash (wake?) as it also helps to keep controls crisp at low speeds. Not mentioned is the use of spoilers. I've noticed one ranked pilot who flies a slick glider sometimes with ballast uses slight spoiler adjustment to regulate slack line. It can be used, but very carefully. Don't do this in Pirat, especially if You're a tiny person. I had some problems with closing the Pirat's brakes on tow, know at least one girl who wasn't able to close the brakes, landing at the beginning of the afld. There was at least one accident of another girl in Pirat caused by large force at the airbrake handle when towed. But also... wise use of airbrakes in gliders like the Junior or Puchacz (from my experience) can in most cases solve the problem. Regards, -- Janusz Kesik visit www.leszno.pl - home of the www.css-leszno.it.pl |
| Thread Tools | |
| Display Modes | |
| Fwd: [BD4] Source of HIGH CHTs on O-320 and O-360 FOUND! | Bruce A. Frank | Home Built | 1 | July 4th 04 08:28 PM |
| (PIREP, long) Cherokee 180 from Bay Area to Bishop, CA | Dave Jacobowitz | Piloting | 15 | June 24th 04 01:11 AM |
| Flight test update - long | nauga | Home Built | 1 | June 5th 04 04:09 AM |
| SWRFI Pirep.. (long) | Dave S | Home Built | 20 | May 21st 04 04:02 PM |
| MT. DIABLO HIGH SCHOOL CONCORD, CA PHOTOS | MT. DIABLO HIGH SCHOOL PHOTOS | Home Built | 1 | October 13th 03 04:35 AM |
