#11
I use the marine mount which I think is more secure. At my club all the
gliders are equipped with a drilled piece of metal to attach such device with screw and bolt . The marine mount has a lock mechanism to lock the gps in the mount so it is fairly secure, you can fly in turbulent air (which we like!) without risking to get the gps stuck in the commands after a "bump". Gilles "Waduino" a écrit dans le message de .. . I recommend the Ram Mounts and especially the suction cup for use in different ships or driving for that matter. Curious. I have a GPS76S and plan to use it on club ships this season. I wasn't sure about trying a mount. Does the suction cup thing work all right? I wouldn't want it to come loose during flight. For this season it would mostly be on a 2-33, 1-26, 1-34 etc. Wad. "DGRTEK" wrote in message ... Gilles, You made a great choice. I use the 76S in my 1-26 and bring it with me for use in club ships. I recommend the Ram Mounts and especially the suction cup for use in different ships or driving for that matter. The glide ratio is a bit twitchy, but if you are on a straight run it gives you a basic idea. I find I use the ground speed alot to judge the winds. The simple arrow to home or your next waypoint is a great indicator If you fly in two seaters, and the back seat is lacking instruments, it's a great back up. Lastly, I've had some contact with Garmins tech supports, and there were hints of more soaring/hang gliding software updates to come. Douglas |
Wad,
I've used it in all three ships. I don't know if this matters, but I've always had it on the left side of the canopy. In the rear seat of the 2-33 it's great on the left window. I've used it in a cherokee, but had to wet the cup to get it to stick to the surface. Just make sure the "glass" is clean and that you push the cup on securely. I've never had it pop off, but it doesn't hurt to check it now and then. Douglas |
| Thread Tools | |
| Display Modes | |
| Amateur Review of the Garmin GPSMAP 296 GPS | Rhett | Piloting | 10 | March 23rd 05 02:16 AM |
| Pirep: Garmin GPSMAP 296 versus 295. (very long) | Jon Woellhaf | Piloting | 12 | September 5th 04 12:55 AM |
| Amateur Review of the Garmin GPSMAP 296 GPS | Rhett | Products | 10 | April 29th 04 07:57 AM |
| Newbie question | Bill Gribble | Soaring | 6 | November 6th 03 08:57 PM |
| USAF = US Amphetamine Fools | RT | Military Aviation | 104 | September 25th 03 04:17 PM |
