I remember that glider on the beach posting shortly after it happened..
I do have some very limited time in the 2-32... the one I flew I felt it was very honest.. giving plenty of warning before the stall with rumbling and stick shaking.. one report that came from our local witness.. that is not addressed in the preliminary report... and taken with a few grains of salt or sand...is that the passengers reported that the stick was full back the entire time when the spin started... no forward movement to stop the spin.. In less than one month.. this individual went from Student Pilot certificate issue.. to Private Pilot to Commercial Pilot... and crashed. No mention is made of his experience prior to receiving his student pilot certificate. But based on the documentation provided, one can expect that he had worked up to pre-solo before getting his student certificate and quickly completed two written exams and check rides. Not a good position to put an insurance company in. BT "F.L. Whiteley" wrote in message ... I don't disagree, but there are other possibilities. 2-32 gives zippo spin warning, it tends to flick over the top from a tight turn. I thought the local operators were a bit more discriminating, requiring some referral. However, as I told my young friend, break one and drop in the ocean, the next week it would be old news there and the rides would continue. Different operator, same location http://www.soarcsa.org/glider_on_the_beach.htm FWIW one suggestion was the 'extreme return'. Vertical speed limiting dive to the numbers, rotate to landing. My young friend thought this would be a big seller. But parachutes would cut down on useful load. Shoe-horning them in was the order of the day. Frank BTIZ wrote: based on a witness report.. that is now flying here... minimum experience.. lack of spin training... I'd go with the lack of Airmanship.. BT "F.L. Whiteley" wrote in message ... Ramy wrote: As usual, the NTSB report is useless. Doesn't even attempt to analyze the cause for the accident. One of my younger soaring friends hauled rides there for a couple of stints. He clocked over 100 hours a month in 2-32's which we reckoned may have 20,000 to 40,000 hours on them in all that salt air. Airmanship or lack of it may have had nothing to do with this sad incident. |
You gotta be kidding:
http://www.soarcsa.org/images/glider...ach%202-sm.jpg hauling the fuse through the sand and bushes with the tailplane on and the wings off? if that's how they run their operation a 48hr commercial ride driver doesn't look so surprising any more ... F.L. Whiteley wrote: I don't disagree, but there are other possibilities. 2-32 gives zippo spin warning, it tends to flick over the top from a tight turn. I thought the local operators were a bit more discriminating, requiring some referral. However, as I told my young friend, break one and drop in the ocean, the next week it would be old news there and the rides would continue. Different operator, same location http://www.soarcsa.org/glider_on_the_beach.htm FWIW one suggestion was the 'extreme return'. Vertical speed limiting dive to the numbers, rotate to landing. My young friend thought this would be a big seller. But parachutes would cut down on useful load. Shoe-horning them in was the order of the day. Frank BTIZ wrote: based on a witness report.. that is now flying here... minimum experience.. lack of spin training... I'd go with the lack of Airmanship.. BT "F.L. Whiteley" wrote in message ... Ramy wrote: As usual, the NTSB report is useless. Doesn't even attempt to analyze the cause for the accident. One of my younger soaring friends hauled rides there for a couple of stints. He clocked over 100 hours a month in 2-32's which we reckoned may have 20,000 to 40,000 hours on them in all that salt air. Airmanship or lack of it may have had nothing to do with this sad incident. |
When all else fails blame the pilot, especially a dead
one, he ain't going to argue is he. You may of course be right but just think about the assumption you have all made. Would you want someone to think that of you? I think you might have the common decency to wait for the result of the official enquiry before sentence. Shame on you all. At 18:00 21 April 2005, Ramy wrote: One word to describe this: ABSURD. Thinking of those unsuspecting passengers who put their lives in the hands of someone they believe is very experienced. Ramy ttaylor at cc.usu.edu wrote: The USA requirements are way too low. No real soaring experience required. I think that all ratings should be required to demonstrate real soaring skills, not just flying skills. This is about the third accident in Hawaii with similar stall spin characteristics into the trees. Commercial Pilot-Glider: FAR 61.121-61.141 Age requirement: at least 18 years of age. * Be able to read, speak, write, and understand English. * Hold at least a private pilot certificate (for heavier-than-air aircraft.) For initial certificate issuance, pass a knowledge test (FAR 61.125) and practical test (61.127). The launch method(s) endorsed in the pilot's logbook (61.31(j)) determines in which type of launch(s) the pilot has demonstrated proficiency. * There are two levels of experience required for issuance of a commercial certificate; 1.At least 25 hours as a pilot in gliders, including; 1. 100 flights in gliders as pilot in command; and, 2. 3 hours of flight training or 10 training flights in gliders; and, 3. 2 hours of solo flight to include not less than 10 solo flights; and, 4. 3 training flights in preparation for the flight test. |
Don Johnstone wrote:
Would you want someone to think that of you? If I had made a fatal error: Yes. Yes, I would want people to not only think, but talk about my error and learn something. But I agree, by now it's only speculation. However, spinning into the ground smells like pilot error. Stefan |
Who blames the pilot? The FAA or the commercial opperation is to be
blamed! Do you think the passengers would have take the ride if they knew their pilot soloed just 3 weeks ago? Would you send a loved one to take a ride with a pilot who just soloed? And which other official inquiry you expect to get? The NTSB report *is* the official inquiry. My condolences to the pilot's family and friends. Ramy |
The first paragraph of the NTSB statement:
-- This is preliminary information, subject to change, and may contain errors. Any errors in this report will be corrected when the final report has been completed. -- It will be weeks or months before they produce conclusions. The report we are seeing is a summary of the facts as they know them at the time of initial investigation. Unfortunately, the NTSB generaly only puts out two reports. The original, usually very sketchy, and the final, factual one. In between, we just wait. -Tom |
"Ramy" wrote:
Do you think the passengers would have take the ride if they knew their pilot soloed just 3 weeks ago? Would you send a loved one to take a ride with a pilot who just soloed? This issue that was touched on slightly in another thread asking if we've ever refused to fly with someone we felt was not entire safe. Having worked at an airplane flight school, I am *still* surprised that NO ONE coming in for a Discovery Flight ever asked about the credentials of the pilots. They likely wonder, but they don't ask. There *is* an IMPLIED ASSUMPTION (accurate or not, obviously) that if he/she is working there and you are offering the service, the pilot is experienced, qualified and competent to handle routine flights and possible emergencies; there is also the obvious *implied risk*, but neither side talks about either of these implications. If/When you went for a Discovery or demo flight, would you, or *did* you, ask about the qualifications and experience of your pilot? Would you have gone for the ride if the establishment informed you that their pilot soloed, got his license and his commercial rating in less than one month just over a week ago? If you owned the establishment, would you hire someone who was *legally* qualified for the job but who had almost *no* experience? Doesn't the insurance for such an operation require a certain amount of experience *in addition to the required ratings* for pilots providing rides, or for giving rides in various aircraft? |
I shocked, truly SHOCKED, to read such rampant speculation. I have
never before heard of such an untoward thing on RAS! In deed, we should all wait 1-2 years for the OFFICIAL NTSB proclamation that this accident was caused by pilot error (low PIC time a contributing factor). Tom |
Tom, You either completly missed the point or just ignore it. Unless
you consider the pilot experience detailed in the NTSB report as speculation. This poor fellow just soloed 3 weeks ago and was allowed to take paid passengers for a ridge soaring ride for god's sake. Don't you see what's wrong with this picture? The purpose of discussions like this is to prevent similar things from hapenning again. Waiting 1-2 years for official NTSB report which will most likely be identical is a waste of time. It will be old news by then. I rather wait for the accident report in Soaring magazine. But again, this is not the point of this discussion. |
Ramy,
Look up the word "Satire". |
| Thread Tools | |
| Display Modes | |
| AOPA Stall/Spin Study -- Stowell's Review (8,000 words) | Rich Stowell | Aerobatics | 28 | January 2nd 09 03:26 PM |
| millionaire on the Internet... in weeks! | Malcolm Austin | Soaring | 0 | November 6th 04 12:14 AM |
| "I Want To FLY!"-(Youth) My store to raise funds for flying lessons | Curtl33 | General Aviation | 7 | January 10th 04 12:35 AM |
| AmeriFlight Crash | C J Campbell | Piloting | 5 | December 1st 03 03:13 PM |
| AOPA Stall/Spin Study -- Stowell's Review (8,000 words) | Rich Stowell | Piloting | 25 | September 11th 03 02:27 PM |
