#11
Several years ago, I saw a c-frame tool set up with a laser shining on
the skin at the location of the center of the bottom die. This simplified aiming for a hole when the die was covered by the skin. He also rigged up a sledge hammer with a system of ropes and pulleys so that he could raise the hammer by pressing a lever with his foot, then let it drop on the punch. This allowed him to have both hands free for handling a large sheet. We called it a laser guided sledge hammer. It was not an elegant arrangement, a duct tape and bailing wire affair, but it worked. Del Rawlins wrote: On Sat, 16 Oct 2004 11:52:02 +0000, Scott wrote: I need to make a specialized tool and am looking for a way to drill a 1/16" hole EXACTLY in the center of the end of a piece of say 1/2" of 3/4" solid aluminum rod. In other words, I am trying to make something similar to a screwdriver using solid aluminum rod for the handle and 1/16" brass rod as the blade. I dunno how exact you mean when you say exact, but this summer I built a "C-Frame" riveting/dimpling tool and had to drill a 3/16" hole in the "exact" center of a 5/8" rod. I accomplished this by finding a piece of 1" or so round steel, clamping it in my drill press vise and then clamping the vise to the drill press table. I first drilled a 3/16" hole completely through the 1" round steel (approx 2.5" long) as close to centered as I could (non critical), and then chucked a 5/8" bit in my drill press. Taking care to keep the alignment the same, I then drilled about halfway down the first hole with the 5/8" bit to make a drill guide. I clamped the 5/8" rod in a vise, and placed the guide over it. Then took the 3/16" bit in a hand drill and drilled into the rod using the guide to center it. It isn't as exact as using a lathe would have gotten, but it is more than good enough for the task at hand especially considering that I dont *have* a lathe. A picture of the C-frame tool (before paint and sandblast) can be found he http://www.rawlinsbrothers.org/bhfaq/imptool.html It didn't occur to me to take a picture of the drilling guide but it should be fairly self explanatory. ================================================== == Del Rawlins-- Unofficial Bearhawk FAQ website: http://www.rawlinsbrothers.org/bhfaq/ Remove _kills_spammers_ to reply -- John Kimmel I think it will be quiet around here now. So long. |
![]() "guynoir" wrote in message ink.net... Several years ago, I saw a c-frame tool set up with a laser shining on the skin at the location of the center of the bottom die. This simplified aiming for a hole when the die was covered by the skin. He also rigged up a sledge hammer with a system of ropes and pulleys so that he could raise the hammer by pressing a lever with his foot, then let it drop on the punch. This allowed him to have both hands free for handling a large sheet. We called it a laser guided sledge hammer. It was not an elegant arrangement, a duct tape and bailing wire affair, but it worked. I like that! |
![]() Is there a vo tech high school or perhaps a technical college near you? I should think any vo tech oriented school that has a manuacturing shop would be glad to help out. I know that I certainly would. For that matter if you can't get it done local let me know and I will have one of my students do it up and will mail it to you. I have .500 and .750 AL on hand, 6061 I believe although it might be 7075, I will have to look and see. Errol Groff EAA 60159 Instructor, Machine Tool Department H.H. Ellis Regional Technical School Danielson, CT 06239 860 774 8511 x1811 On Sat, 16 Oct 2004 11:52:02 +0000, Scott wrote: I need to make a specialized tool and am looking for a way to drill a 1/16" hole EXACTLY in the center of the end of a piece of say 1/2" of 3/4" solid aluminum rod. In other words, I am trying to make something similar to a screwdriver using solid aluminum rod for the handle and 1/16" brass rod as the blade. |
On Sun, 17 Oct 2004 16:58:34 GMT, guynoir
wrote: Several years ago, I saw a c-frame tool set up with a laser shining on the skin at the location of the center of the bottom die. This simplified aiming for a hole when the die was covered by the skin. He also rigged up a sledge hammer with a system of ropes and pulleys so that he could raise the hammer by pressing a lever with his foot, then let it drop on the punch. This allowed him to have both hands free for handling a large sheet. We called it a laser guided sledge hammer. It was not an elegant arrangement, a duct tape and bailing wire affair, but it worked. Sounds like something my dad would have rigged up. I thought I was gonna die after I actually cleaned the shop and either re-sharpened or disposed of all the mangled screwdrivers I found stuck in a drawer. How was I supposed to know that each of them was a special tool? ================================================== == Del Rawlins-- Unofficial Bearhawk FAQ website: http://www.rawlinsbrothers.org/bhfaq/ Remove _kills_spammers_ to reply |
Earlier, Scott wrote:
I need to make a specialized tool and am looking for a way to drill a 1/16" hole EXACTLY in the center of the end of a piece of say 1/2" of 3/4" solid aluminum rod. I've done something like that, using this general procedure to center-drill a 1/2" rod with a 3/16" bo 1. I put a saw slot most of the way across a pice of scrap aluminum block. 2. I lightly clamped the block in the drill press vise, and clamped the vise onto the drill press table so that the drill axis hit the slot. 3. I drilled a 3/16" hole through the block somewhere along the slot. 4. Without moving the block, vise, or table, I unchucked the 3/16" drill bit, stuck it shank-first in the hole in the block, and then tightened the drill press vise so the block clamped down on the drill bit. 5. I chucked my 1/2" rod in the drill press chuck. 6. I started the drill press, and then cranked the rotating 1/2" rod down onto the stationary 3/16" drill bit. Some variation on that theme might work out for you. Most of the time, I just use my little 9x20 lathe... Thanks, and best regards to all Bob K. http://www.hpaircraft.com/hp-24 |
Hey, that sounds like it could work also! Thanks for the idea...
Scott Bob Kuykendall wrote: Earlier, Scott wrote: I need to make a specialized tool and am looking for a way to drill a 1/16" hole EXACTLY in the center of the end of a piece of say 1/2" of 3/4" solid aluminum rod. I've done something like that, using this general procedure to center-drill a 1/2" rod with a 3/16" bo 1. I put a saw slot most of the way across a pice of scrap aluminum block. 2. I lightly clamped the block in the drill press vise, and clamped the vise onto the drill press table so that the drill axis hit the slot. 3. I drilled a 3/16" hole through the block somewhere along the slot. 4. Without moving the block, vise, or table, I unchucked the 3/16" drill bit, stuck it shank-first in the hole in the block, and then tightened the drill press vise so the block clamped down on the drill bit. 5. I chucked my 1/2" rod in the drill press chuck. 6. I started the drill press, and then cranked the rotating 1/2" rod down onto the stationary 3/16" drill bit. Some variation on that theme might work out for you. Most of the time, I just use my little 9x20 lathe... Thanks, and best regards to all Bob K. http://www.hpaircraft.com/hp-24 -- Scott http://corbenflyer.tripod.com/ Building RV-4 Gotta Fly or Gonna Die |
Scott wrote:
I need to make a specialized tool and am looking for a way to drill a 1/16" hole EXACTLY in the center of the end of a piece of say 1/2" of 3/4" solid aluminum rod. In other words, I am trying to make something similar to a screwdriver using solid aluminum rod for the handle and 1/16" brass rod as the blade. Put the 1/2" round in your drill press chuck. Clamp a small table top clamp to the end of the round sticking out of the drill chuck. Carefully lower the spindle till the clamp is on the drill press table. Carefully clamp the table top clamp to the drill press table. Now release the chuck raise the spindle, put in the 1/16' drill bit and drill the hole. I've never tired it but it should work pretty well. -- Chris W Not getting the gifts you want? The Wish Zone can help. http://thewishzone.com "They that can give up essential liberty to obtain a little temporary safety deserve neither liberty nor safety." -- Benjamin Franklin, 1759 Historical Review of Pennsylvania |
B2431 wrote:
I used to do gunsmithing. Your father's collection of "mangled" screwdrivers sounds like mine. It is truely amazing how many of those beasties one needs. The one thing I wish I had done was label what each was for. About 20 years ago I was going to make an inletted box for them all. It still isn't made. No need to rush these things, y'know. Dan, U.S. Air Force, retired Take a short length of scrap 2x4. Drill one side full of holes. Go about halfway through with the holes. Line up all the long slender tools like little army men. Labels? Use a pen, pencil, or crayon (purple if you have it). It's amazing how much a scrap of wood has cleaned up my bench 8*) -- http://www.ernest.isa-geek.org/ "This is by far the hardest lesson about freedom. It goes against instinct, and morality, to just sit back and watch people make mistakes. We want to help them, which means control them and their decisions, but in doing so we actually hurt them (and ourselves)." |
Fairing question... | Tina Marie | Home Built | 5 | July 16th 03 12:18 AM |
