"Steven P. McNicoll" wrote: wrote in message ... You are correct. There is no end to what some flight instructors will dream up or invent. Everything the FAA does in the world of charting is predicated on IAS. Not quite everything. The approach timing table uses ground speed. More correctly, the Jeppesen timing table states ground speed. NACO does not. |
"Steven P. McNicoll" wrote: wrote in message ... You are correct. There is no end to what some flight instructors will dream up or invent. Everything the FAA does in the world of charting is predicated on IAS. Not quite everything. The approach timing table uses ground speed. More correctly, the Jeppesen timing table states ground speed. NACO does not. Whether they state it or not, there's nothing but ground speed that they *could* be using to calculate the time to traverse the stated distance. --Gary |
Gary Drescher wrote: wrote in message ... "Steven P. McNicoll" wrote: wrote in message ... You are correct. There is no end to what some flight instructors will dream up or invent. Everything the FAA does in the world of charting is predicated on IAS. Not quite everything. The approach timing table uses ground speed. More correctly, the Jeppesen timing table states ground speed. NACO does not. Whether they state it or not, there's nothing but ground speed that they *could* be using to calculate the time to traverse the stated distance. --Gary For the best accuracy, it obviously has to be ground speed. But, there is no requirement to make the necessary calculations to arrive at ground speed. A lot of folks over many years have simply treated the timing table values as indicated airspace, on the premise there are a lot more important things to do in the final approach segment than attempt to make conversions. In recent years, RNAV has all-but-eliminated any need to use the timing table in any case. |
wrote in message ... More correctly, the Jeppesen timing table states ground speed. NACO does not. The speeds on NACO timing tables are ground speed. |
wrote in message ... More correctly, the Jeppesen timing table states ground speed. NACO does not. Do the timing tables on the NACO plates have different values than the Jeppesen plates? |
"Steven P. McNicoll" wrote: wrote in message ... More correctly, the Jeppesen timing table states ground speed. NACO does not. Do the timing tables on the NACO plates have different values than the Jeppesen plates? The values are there to be used as IAS or ground speed; it is pilot option. Jeppesen is making an assumption that is not a regulatory charting value. |
Mark,
It's pretty clear that your instructor is mistaken, as you have cited chapter and verse of the pertinent regulatory article. This also agrees with the FAA's Instrument Flying Handbook, publication faa-h-8083, pages 8-23 and 8-24, in which the approach category speeds are based on being 1.3 times the stall speed of the aircraft in the landing configuration at gross weight. Stall speeds are never predicated on ground speed. The error in doing so should be readily apparent. If your instructor is basing his instruction and recommendation on "ground speed" then challenge him to show you chapter and verse where ground speed is the acceptable determining factor. Your ground speed comes into play on instrument approaces in timing the approach and in determining your rate of descent for a given glidepath angle. Your instructor, while well intentioned appears to be "reading too much into the situation". Using a lower category than authorized can result in a bust of minimums. Using a higher category than required can result in not being able to take full advantage of lower minimums. It would behoove you at this point to also read and know not only the instrument PTS, but also the FAA Instrument Flying handbook as well as whatever texts your instructor is using for your ground based instruction. Good Luck Dave Mark Hansen wrote: I'm an Instrument Airplane student, and am having a disagreement with my instructor on one topic - that of Aircraft Approach Categories. According to 14 CFR Part 97.3 (b), it provides the speed ranges for the different aircraft categories (A-E). In all the documentation I've read, this "speed" is the IAS of the airplane. However, my CFI says that this is based on the Ground Speed. When we are flying an approach with a tail wind and can see that, although we are remaining below 90kts IAS, our Ground Speed (shown by the GPS unit) is just over 90kts, he said I must use the category B minimums. I understand his reasoning (in that the faster we're moving across the ground, the faster we'll move out of the protection zone, etc.), but from what I can find, the FAR doesn't mention ground speed at all. If I use the minimums associated with the higher of the IAS or Ground Speed, would I get dinged during a proficiency check? The reason I ask is that I've been asked questions before where the examiner was trying to make sure that I completely understood the rule, and I'm worried that selecting minimums that are higher than necessary will show that I don't really understand it. Thanks, |
On 7/15/2005 11:10, Dave S wrote:
Mark, It's pretty clear that your instructor is mistaken, as you have cited chapter and verse of the pertinent regulatory article. This also agrees with the FAA's Instrument Flying Handbook, publication faa-h-8083, pages 8-23 and 8-24, in which the approach category speeds are based on being 1.3 times the stall speed of the aircraft in the landing configuration at gross weight. Stall speeds are never predicated on ground speed. The error in doing so should be readily apparent. If your instructor is basing his instruction and recommendation on "ground speed" then challenge him to show you chapter and verse where ground speed is the acceptable determining factor. Your ground speed comes into play on instrument approaces in timing the approach and in determining your rate of descent for a given glidepath angle. Your instructor, while well intentioned appears to be "reading too much into the situation". Using a lower category than authorized can result in a bust of minimums. Using a higher category than required can result in not being able to take full advantage of lower minimums. It would behoove you at this point to also read and know not only the instrument PTS, but also the FAA Instrument Flying handbook as well as whatever texts your instructor is using for your ground based instruction. Thank you. I have gone through the Instrument Flying Handbook (as well as the Instrument Procedures Handbook, and others...). Although I haven't yet gone through the PTS, it is on my list of things to get to. Good Luck Dave |
the different aircraft categories (A-E). In all the documentation I've read, this "speed" is the IAS of the airplane. And so it is (almost - I seem to recall it's really CAS, but that wouldn't make much difference). That's the regulation. However, my CFI says that this is based on the Ground Speed. It's hard to prove a negative, so I can't say there is NO regulatory support for what he says, but I've certainly never seen it. Have you asked him to show you where he read this? Further, without RNAV that works at low altitudes or DME on the approach (which isn't rare but is far from universal), ground speed is an estimate - and these rules are a lot older than widespread use of RNAV that works at low altitudes. In other words - I think your CFI is totally wrong on this one. The reason I ask is that I've been asked questions before where the examiner was trying to make sure that I completely understood the rule, and I'm worried that selecting minimums that are higher than necessary will show that I don't really understand it. Well, yes, it will. Only I think you understand it fine; it's your instructor who is steering you wrong. There are situations where it makes sense to select higher minimums on an approach (especially a circling approach) where the higher speed makes remaining within the protected area for the lower mins problematic. I certainly don't think it would be wrong to say "Yes, I know that technically cat A mins apply, but I am going to use Cat B mins because the wind conditions make remaining within the Cat A protected area problematic." If the situation is a circling approach with restrictions imposed and very high winds that would require an excessive bank angle to remain within the protected area, he would probably consider that a sign of good judgment. But you should be clear that this is something you are choosing to do because it makes sense, and that the regulations do permit lower mins. Michael |
On 7/15/2005 11:12, Michael wrote:
According to 14 CFR Part 97.3 (b), it provides the speed ranges for the different aircraft categories (A-E). In all the documentation I've read, this "speed" is the IAS of the airplane. And so it is (almost - I seem to recall it's really CAS, but that wouldn't make much difference). That's the regulation. However, my CFI says that this is based on the Ground Speed. It's hard to prove a negative, so I can't say there is NO regulatory support for what he says, but I've certainly never seen it. Have you asked him to show you where he read this? Further, without RNAV that works at low altitudes or DME on the approach (which isn't rare but is far from universal), ground speed is an estimate - and these rules are a lot older than widespread use of RNAV that works at low altitudes. In other words - I think your CFI is totally wrong on this one. The reason I ask is that I've been asked questions before where the examiner was trying to make sure that I completely understood the rule, and I'm worried that selecting minimums that are higher than necessary will show that I don't really understand it. Well, yes, it will. Only I think you understand it fine; it's your instructor who is steering you wrong. There are situations where it makes sense to select higher minimums on an approach (especially a circling approach) where the higher speed makes remaining within the protected area for the lower mins problematic. I certainly don't think it would be wrong to say "Yes, I know that technically cat A mins apply, but I am going to use Cat B mins because the wind conditions make remaining within the Cat A protected area problematic." If the situation is a circling approach with restrictions imposed and very high winds that would require an excessive bank angle to remain within the protected area, he would probably consider that a sign of good judgment. But you should be clear that this is something you are choosing to do because it makes sense, and that the regulations do permit lower mins. Thank you Michael. This is how I've been looking at it (but I didn't express it very well). When I've asked my CFI to show me the regs, he basically says that it makes sense to use the higher mins, and I haven't pushed it. This isn't the first time we've disagreed on the Regs. In another case, he claimed that it was illegal to fly IFR without a flight plan and ATC clearance, but that rule applies only to Controlled airspace. I think I won't bother pushing it, as I'm clear on the concept, and don't really need to head-but the CFI over it ;-) Michael -- Mark Hansen, PP-ASEL, Instrument Student Sacramento, CA |
| Thread Tools | |
| Display Modes | |
| NTSB: USAF included? | Larry Dighera | Piloting | 10 | September 11th 05 11:33 AM |
| Homebuilt Aircraft Frequently Asked Questions (FAQ) | Ron Wanttaja | Home Built | 0 | October 2nd 03 04:07 AM |
| USAF = US Amphetamine Fools | RT | Military Aviation | 104 | September 25th 03 04:17 PM |
| Homebuilt Aircraft Frequently Asked Questions (FAQ) | Ron Wanttaja | Home Built | 4 | August 7th 03 06:12 AM |
| Homebuilt Aircraft Frequently-Asked Questions (FAQ) | Ron Wanttaja | Home Built | 0 | July 4th 03 05:50 PM |
