I've long thought an experimental category A/C dedicated only to towing
would be a good alternative to the Pawnee. The correct design would get better fuel efficiency, be quieter, have longer TBO and probably be liquid cooled so thermal shock is not such a problem on let down. Two questions, though: who wants to design a specialized airplane with such limited market potential, and what would the insurance companies say about towing with an A/C in the experimental category? Otherwise, bring it on! Fred |
John,
This PIK 27 design looks like a very good candidate for the US LSA category. I like the liquid cooled engine and the dive brakes on the empennage. Jeff |
Having owned an aircraft with a Rotax 914 (turbocharged & intercooled), Except for the liquid cooled heads, I wouldn't thing this engine is all that well suited for a tow plane. Not that it isn't a good engine, it's just that it seems to require more maintenance than the less sophisticated Lycoming or Continental. Check the Rotax SB's and AD's to see what I mean: http://www.rotax-owner.com/ For a motor glider like the Stemme, which spends much of it's time soaring and puts little time on the engine, this isn't so much an issue. And the reliable starting and smooth running of the 4-stroke Rotax is a real plus. But for a hard working tug, the maintenance demands may be less inviting. The 912 / 914 will burn 100 LL, but they don't like it as much as premium mogas. 100LL use can result in early overhaul due to clogged oil passageways and sticking rings and valves. The new diesel engines might be better suited for tug duty? bumper "Jeffrey Banks" wrote in message ... John, This PIK 27 design looks like a very good candidate for the US LSA category. I like the liquid cooled engine and the dive brakes on the empennage. Jeff |
| Thread Tools | |
| Display Modes | |
| Most reliable homebuilt helicopter? | tom pettit | Home Built | 35 | September 29th 05 03:24 PM |
| Mini-500 Accident Analysis | Dennis Fetters | Rotorcraft | 16 | September 3rd 05 12:35 PM |
| changing operating limitations | pittss1c | Home Built | 46 | August 22nd 05 05:28 AM |
| Homebuilt Aircraft Frequently Asked Questions (FAQ) | Ron Wanttaja | Home Built | 4 | August 7th 03 06:12 AM |
| Homebuilt Aircraft Frequently-Asked Questions (FAQ) | Ron Wanttaja | Home Built | 0 | July 4th 03 05:50 PM |
