Toasted my engine
Old September 20th 05, 08:26 PM
Larry Dighera
On Tue, 20 Sep 2005 17:48:13 GMT, "Mortimer Schnerd, RN"
wrote in
I've had the pleasure of a catastrophic engine failure in a single... and it
really ain't.
It must not have occurred on take off.
Old September 20th 05, 09:44 PM
nrp
"Yes, but that wouldn't have sheared the bolt at..."
I agree not sheared but it would have looked like that to the OP. I
would guess a tensile fatigue (probably initiated by bending) with the
crack starting on the side closest to the cyl centerline for cyl 3.
Assuming it is truly one of the bottom studs - they would not be
thru-studs but short ones instead. My guess is a partial loss of
preload of the #3 cyl assy initiated by the failure of the thru stud
between 2 & 3, then causing a progressive failure at the bottom of
three. There probably are also some cracks around the base of #2 also
I can't explain the crack at 4.
If the cyls are reused the flanges around the bottom should be subject
to very careful magnaflux inspection. Maybe on general principle they
should be junked.
Torque to loosen will be less than torque to tighten, and less
indicative. The engine history would be interesting. It certainly
would have failed in a few minutes rather than hours - and it would
have been a massive noisy failure too.
A Bonanza friend found one of those short studs laying in the cowl
while preflighting his airplane in the Bahamas. He put the family on
commercial airlines & flew home on minimum power - with a life jacket
on!
Kobra
It could be undertorqued too. In that case there would be a lot of
fretting under the base flange of the cylinder, and probably on the
main bearing webs too.
Flyers,
Here is a post I found about a Cardinal RG with a similar problem.
This was an interesting situation FWIW. I have pictures if you want
to see them. Can they be posted here?
Kobra
snip
You can tell from the type of cylinders, in this case the angle valve
cylinders, that this is a Cardinal RG. I'll confess that I'm not certain
that you can tell this from the base of the cylinders.. I think I cropped
the picture some since I first asked that question.
Visibly wrong in the picture are the two missing hold-down nuts and
sheared stud and through-bolt. There are two more you can't see on the other
side. Also visible is a long crack running down from the center of the
cylinder base. This can be more clearly seen in the picture to the right.
So, two items visibly wrong.
What could cause this? Usually detonation causes broken pistons. This
is more about looseness in the cylinder base. How could it get loose after a
reputable shop worked on it?
The best guess at this point is that the cylinder base or case may
have been painted, or had a little bit of paint slide into the mating
surface somehow. Over time this gets beaten down or squeezed out and a
little looseness develops.
Once loose, the power pulses at 50 HP per pulse work on the hold-down
studs and bolts, eventually fatiguing them to failure. Then it's just the
case and lower bolts doing their best to keep the cylinder on.
This problem was first observed as a substantial oil leak enough to
make oil visible outside the cowl. There was no perceptible difference in
engine operation or smoothness. The pilot simply arrived at his destination
and the people he was meeting commented on the oil on the cowl.
With the cowl top off the pilot and a mechanic stared at the engine
for about 15 minutes before one of them noticed the missing nuts. In fact
one of the nuts (seen to the right) lying between the cylinders, was found
and a search for where it came from ultimately led to the discovery.
Before you judge these people harshly let me assure you that it was
not obvious. The studs sheared off so smoothly that it looked like it was
suppose to be that way. And the crack where the oil was coming from was
buried behind the air filter baffling.
What's the lesson here? When you have a cylinder off make sure it is
reinstalled properly, with no paint in bad places, and consider talking to
the shop about retourqing after a while. We're not sure what the ideal
answer is, or a single thing that resolves this, but it's a possibility that
should be kept in mind during cylinder work. An interesting point for
discussion with your mechanic.
The final result for this pilot was a series of logistics: first, a
call to a friend (who happened to be me in this case) for a ride home. Next
research on engine rebuilders and the selection of the best one. A fair
amount of research on case half options and purchase of suitable parts to
make a compete case, major overhaul, re-installation of the engine and an
uneventful flight home.
In all, 4 weeks and about $20,000. At least he got a freshly
overhauled engine for that price.
Old September 20th 05, 10:19 PM
If the airplane was going through an annual inspection, the IA should
have generated a list of discrepancies of what didn't pass and given
that to the owner. At that point the annual was complete.
An ordinary A&P could then bring the aircraft back to airworthinness
condition without the need for the IA.
I don't believe that there is anywhere where the FSDO could have
demanded anything except to do a ramp inspection after the aircraft had
been flying.
Denny wrote:
Oh, and BTW, mechanics cannot ground airplanes
Yup, true fact...
Though one local recently got into a ****ing match with his API over
some annual inspection issues on a well worn TriPacer (couple of 3
year olds in adult bodies)-
including the CAR 23 original equipment single mag switch that has only
two positions - off and on -
and the fabric passing the punch test though at the lowest allowable
reading, and the mechanic refused to sign it off..
The owner (an AP but not an I) demanded the mechanic turn the plane
back to him now, or else... The mechanic did, but he put an entry in
the log book that the airplane was unairworthy and called the FSDO and
faxed them a copy of the log entry... It took a ferry permit to get it
off the field...
So, the plane was shopped around to several API mechanics before he
found one that would touch it... 6 months later and it is still not
flying... The story I hear is that the FSDO inspector is demanding
documentation that they are having problems coming up with...
While an mechanic cannot "ground" an airplane he can do a fair
imitation if he is determined...
denny
Old September 20th 05, 10:22 PM
Mark Hansen
On 9/20/2005 12:44, nrp wrote:
[ snip ]
on!
Yea, 'cause sharks like life jackets ;-)
Mark Hansen, PP-ASEL, Instrument Airplane
Sacramento, CA
Old September 20th 05, 11:11 PM
Matt Whiting
RST Engineering wrote:
There aren't a lot of possibilities, are there?
1. The case crack set up a vibration or torque that overstressed the
bolt -- and since it happened on startup when things are running less than
smooth in a Lyc, I'd bet on this one.
2. The bolt was WWAAAYYY overtorqued on installation. You'll never know
about this one. However, a through bolt shearing and a case crack by
another through bolt leads me to check the calibration on somebody's torque
wrench.
3. Something else in the engine was vibrating ... not likely as the whole
AIRplane would have been vibrating to shear a through bolt.
4. Defective bolt ... not likely as throughbolts get magnafluxed or x-rayed
at overhaul.
5. (Add yours here)
I'd think 2 is most likely, but who knows?
Oh, and BTW, mechanics cannot ground airplanes. IAs cannot ground
airplanes. The FAA (unless they pull the airworthiness cert.) cannot ground
airplanes. I know it is a common phrase, but the mechanic simply suggested
that it would be less than wise to fly the airplane in its current
condition.
True, but once the pilot knows the airplane isn't airworthy, isn't
he/she obligated not to fly it? At least not without a ferry permit?
Matt
Old September 21st 05, 12:16 AM
wrote in
really ain't.
About five minutes later. It pretty much ruined my year.
VE
Old September 21st 05, 12:27 AM
RST Engineering
If the airplane was going through an annual inspection, the IA should have
generated a list of discrepancies of what didn't pass and given that to
I'm not sure what you are saying. That the airplane has a current valid
annual at this point? That isn't so. THe logbook should have contained
words to the effect that the aircraft was inspected on (date) and a list of
unairworthy items given to the owner or operator.
If the airplane is "ratty" but the mag switch(es) had been installed in
accordance with the type certificate in effect as of date of manufacture and
there were no subsequent ADs to change it, then the IA cannot on his own
hook declare them unairworthy.
Similarly, if the fabric punched "at the bottom of the airworthy scale" then
the fabric is airworthy. THe IA does not get to set a higher standard than
the FAA requires.
That's true, but the aircraft still does not have a current annual
inspection.
I don't believe that there is anywhere where the FSDO could have demanded
anything except to do a ramp inspection after the aircraft had been
flying.
They can demand green cheese. What they get or are entitled to get are two
separate matters.
Old September 21st 05, 12:36 AM
RST Engineering
"nrp" wrote in message
Hm. Most people can detect the crystallization of fatigue as opposed to the
clean cut of a shear. Perhaps not. However, the OP clearly stated that it
was a throughbolt, not a stud.
I agree with the centerline analysis ... those pistons are slapping up and
down a hell of a lot harder than left and right (we hope).
indicative.
Respectfully disagree. WIth torque values of these magnitudes, you will get
very little movement to find the point of actual torque by tightening.
However, just before the nut loosens you will generate very nearly the tight
torque. The problem is to have somebody reading the reverse torque very
carefully and noting the peak while you VERY SLOWLY bring the nut off.
It is, as they say, an interesting (and very expensive) problem in forensic
mechanics.
Old September 21st 05, 01:17 AM
Matt Barrow
"Kobra" wrote in message
Flyers,
The story goes on though. As he was taking the engine off he found one
other interesting item. One of the through-bolt nuts on the bottom of
cylinder number 3 was sheared off completely flush the cylinder base.
That's when the hair on the back of my neck stood up. I have to think
that
all this was related as the nut was still laying in the bottom of the
engine. This was recent!
Next I had a recollection of starting the engine before my flight to WWD
and
I remember that I heard a "snap!" just as the engine caught. It was loud
enough to make me say, "...what the %$#@ was that?!" and just soft enough
for me to dismiss it and ponder, "...did you really hear what you think
you
heard?"
I'm not that knowledgeable about the internal details of the engines, so
could you explain how that bolt could get sheared off?
Any speculations would be understood as being such.
Matt
Matthew W. Barrow
Site-Fill Homes, LLC.
Montrose, CO
Engine Balancing and Resonance Vibration Problem AllanFuller Owning 13 September 12th 05 01:51 AM
Proposals for air breathing hypersonic craft. I Robert Clark Military Aviation 2 May 26th 04 07:42 PM
Car engine FAA certified for airplane use Cy Galley Home Built 10 February 6th 04 04:03 PM
What if the germans... Charles Gray Military Aviation 119 January 27th 04 12:20 AM
Real stats on engine failures? Captain Wubba Piloting 127 December 8th 03 05:09 PM
