Something nice on a cold day
Old December 4th 05, 10:08 PM posted to rec.aviation.soaring
Default Something nice on a cold day
Greg Arnold wrote:
So the batteries must be inboard on the wing, close to the fuselage.
Where else would you expect them? Handling would not be improved by
moving them outboard and there would be increased wiring losses in the
power system.
martin@ | Martin Gregorie
gregorie. |
org | Zappa fan & glider pilot
Old December 5th 05, 01:08 AM posted to rec.aviation.soaring
Huh ? Bending moment ? Minimize losses by using high voltage/low
amperage ?
Anyway, handles great, and easy to assemble.
Best Regards, Dave
Old December 5th 05, 01:30 AM posted to rec.aviation.soaring
power system.
Well, there must be a reason that some gliders require you to use the
outboard tanks when you are flying with partial water.
Old December 5th 05, 06:27 PM posted to rec.aviation.soaring
Hi,
You can see more Antares images and videos he
http://www.lange-flugzeugbau.com/eng...u/menu-akt.htm
I hope to be able to afford one some day...
Paul Remde
Andor,
In a perfect world...I win the lottery and have one parked in the
hanger next to my brand new Extra 300.
Gus
Andor Holtsmark wrote:
Something nice to get through a cold winter day..
Note that the link requires Flash 6 installed and a
broadband connection.
http://tinyurl.com/95pnn
Old December 21st 05, 08:14 PM posted to rec.aviation.soaring
Hello everybody,
I apoligize for not answering your questions earlier,
life is rather busy here.
The movies:
They are very much a one man production by our engineer,
test-pilot, camera man, movie director and musician
Ola Roer Thorsen. Copyrighted music could not be utilized,
but we still think the result is acceptable
Charging:
A full charge takes 9 hours, using the integrated charger.
A full charge costs less than 2 euro, and gives you
more than 3000m
climb (depending on aircraft weight). Partial charges
and discharges are no problem, as the batteries have
no memory-effect.
Rigging:
The batteries are positioned in front of the wing spar,
filling the volume from the wing root and approximately
3.2 m outwards.
This minimizes negative effects on aircraft inertia.
Add to this the novel control system used in the Antares,
and the result is a surprisingly agile glider, with
handling close to that of a 15m glider. Based on this,
I am curious as to how the 18m Antares will handle
when carrying no water.
Each wing of the Anmtares 20E weighs approximately
120 kg including batteries. In order to get the wing
out of the trailer and into the rigging aid, the pilot
handles the wingtip, lifting maximally 30 kg, and usually
only for 20-30 seconds.
The rigging aid grips the wing at its cg, and uses
a gas-spring to ballance the wing vertically. This
makes it possible to rig the Antares 20E single handedly
without breaking a sweath.
Actually it surprices me how much work it is rig a
'normal' glider..
I guess I am a bit spoiled
Speaking of batteries..
In order to create volume for the batteries in the
20E, the spar is positioned markedly rearward of its
normal position. This feature also pays off in the
18m glider, resulting in a marked increase in water
ballast capacity, which is one of the reasons why we
expect it to become a very fast glider. The coming
season will be very interresting indeed.
Ok. I hope that that answered some of your questions.
I wish you all very politically correct happy holidays.
Andor
Hard Starting Cold Continental Engines M.E. Borner Owning 16 December 6th 05 05:13 AM
Soviet Spy Planes over the West during the Cold War Rusty B Military Aviation 6 February 19th 04 05:53 PM
Battery Replacement and Cold Cranking Amps O. Sami Saydjari Owning 27 February 2nd 04 03:38 PM
Wet, Bumpy, and Cold Andrew Gideon Instrument Flight Rules 11 October 9th 03 02:45 AM
How I got to Oshkosh (long) Doug Owning 2 August 18th 03 01:05 AM
