The ring gear has gotten chewed up over time, and now
will sometimes not disengage while the starter is rolling it over. The Lycoming starter drive is supposed to lock in the engaged position until the engine starts and the RPM comes up somewhat. There are centrifugally-released locks in the drive itself. Some pilots get all concerned about the drive "sticking" in the engaged position, which can cause grinding and ratcheting noises when the prop is moved, but it's normal. Anytime a start has been attempted without the engine catching will result in this engagement. The chewed-up gear teeth often coincide with the prop's stopping position. Check and see if the teeth in the two prop-stop places are the worn ones. Moving the prop a little (backwards!) before startup will place less-worn ones in the engaging position. Dan |
| Thread Tools | |
| Display Modes | |
| Saratoga Gear Retract Problem | Yahoo! News | Owning | 16 | November 30th 05 12:17 AM |
| Jet engines vs. leaf blowers | 01-- Zero One | Soaring | 6 | September 8th 05 02:59 AM |
| A&P heroics | Jim | Piloting | 31 | July 18th 05 08:26 PM |
| Aluminum vs Fiberglass landing gear - Pro's and cons. | Bart Hull | Home Built | 1 | November 24th 03 03:46 PM |
| Aluminum vs Fiberglass landing gear - Pro's and cons. | Bart D. Hull | Home Built | 0 | November 22nd 03 07:24 AM |
