Can anyone ID this engine?
Old March 12th 06, 07:12 PM posted to rec.aviation.homebuilt,rec.aviation.piloting
Default Can anyone ID this engine?
Montblack wrote:
("JP" wrote)
What you have in the picture, seems to be a French Lorraine 12 Ed
aircraft
engine, circa year 1922. It is a liquid-cooled W-type engine (yes,
60+60=120 degrees most probably), but instead of 6-cylinder
configuration,
it's a 12-cylinder layout (believe or not). Capacity 24,4 litres, dry
weight 425 kg. Power output 450 hp.
Check out this link. It has a picture of the engine.
http://www.planes-and-tanks.com/EngineShop/lorraine.htm
Thanks for the link!
About the web page:
When you click on "Aircraft Engines" to see more engines - that link
doesn't
work.
Simply turn the capital "E", in the web address, into a lower case "e" for
the "Aircraft Engines" link on the Lorraine page to work. (IE 6.0 and
Firefox/Mozilla)
http://i2.tinypic.com/r7pq4z.jpg
1922 (French) Lorraine aircraft engine in Cambodia
940 lbs
450 hp
12 cylinder
Montblack
Thanks Monty. Looks like I'm not the only one who does that.
Got a short giggle at the Allison 1710 - in metric???
Old March 17th 06, 05:35 AM posted to rec.aviation.homebuilt,rec.aviation.piloting
Yes I reckon I can , it's a Soc Nationale de Construction de Moteurs
(Lorraine-Dietrich) see the V12 version Page 95 World Encyclopaedia of Aero
Engines by Bill Gunston ISBN 1-85260-163-9
Ian Kentish in Bendigo AU
36:46:13 S ---- 144:15:466
Few things are harder to put up with than the annoyance of a good example.
The secret of life is honesty and fair dealing. If you can fake that ,
you,ve got it made !
And a fine beer can be judged by one sip but it's better to be sure !!!
"Montblack" wrote in message
("Flyingmonk" wrote)
From a down aircraft in Cambodia?
2 + 2 + 2 cylinder engine?
45 degree + 45 degree + 45 degree?
What is it?
Montblack
Monk posted this engine link over in RAP.
Air Force One Had to Intercept Some Inadvertent Flyers / How? Rick Umali Piloting 29 February 15th 06 05:40 AM
Engine Balancing and Resonance Vibration Problem AllanFuller Owning 13 September 12th 05 01:51 AM
Proposals for air breathing hypersonic craft. I Robert Clark Military Aviation 2 May 26th 04 07:42 PM
What if the germans... Charles Gray Military Aviation 119 January 27th 04 12:20 AM
Real stats on engine failures? Captain Wubba Piloting 127 December 8th 03 05:09 PM
