#11
Montblack wrote:
Has this one been around the block a few times? It was an interesting read. http://www.pureenergysystems.com/new...00069_Acetone/ Acetone In Fuel Said to Increase Mileage "Readily-available chemical added to gas tank in small proportion improves the fuel's ability to vaporize completely by reducing the surface tension that inhibits vaporization of some fuel droplets." http://toyotaownersclub.com/forums/i...howtopic=44575 Chat room chat about acetone - mostly diesel cars. This is for diesels mostly ...and mogas WITHOUT alcohol in it. A few ounces/10 gallons is all you use. Montblack go ahead try it. see how long your seals last. Acetone is in the same family as Methyl Ethyl Ketone (MEK). Michelle |
family as Methyl Ethyl Ketone (MEK). Michelle So Michelle, are you out west, yet? We want to hear Michelle's Montanna Maule Mountain Flying Reports! |
![]() Capt. Geoffrey Thorpe wrote: "Montblack" wrote in message ... Has this one been around the block a few times? It was an interesting read. http://www.pureenergysystems.com/new...00069_Acetone/ Acetone In Fuel Said to Increase Mileage "Readily-available chemical added to gas tank in small proportion improves the fuel's ability to vaporize completely by reducing the surface tension that inhibits vaporization of some fuel droplets." http://toyotaownersclub.com/forums/i...howtopic=44575 Chat room chat about acetone - mostly diesel cars. This is for diesels mostly ...and mogas WITHOUT alcohol in it. A few ounces/10 gallons is all you use. In gasoline engines, unburned Hydrocarbons amount to about 1% of the total fuel, and most of those come from crevices such as the gap around the piston above the top ring, and around the spark plug - the compression and pressure rise pushes the mixture into these spots where the flame front is quenched. The next largest source is a thin layer that is quenched at the cylinder walls from the heat loss to the metal. I don't have the numbers handy for diesels, but I'm reasonably confidant that the percentage isn't a lot different even if the sources are different (over rich areas in the fuel spray generate soot due to inadequate air and some of the mixture around the fringe of the spray is too lean to burn). The fact of the matter is that the moon landings are fake, the alien autopsies are real, and the thousands of engineers that work for all the auto companies all around the world (that look at fuel sprays and combustions with lasers, high speed cameras, optically transparent engines of all types, computer modeling, etc.) are completely unaware of potential fuel consumption improvements like this one. -- Geoff The Sea Hawk at Wow Way d0t Com remove spaces and make the obvious substitutions to reply by mail When immigration is outlawed, only outlaws will immigrate. It does work or at least helps. I tried to use it after adding magnets, the little carburetor mini turbos, water injection etc. but when I found that every time I drove the car, the gas tank was overflowing I had to quit. Harry K |
john smith wrote:
go ahead try it. see how long your seals last. Acetone is in the same family as Methyl Ethyl Ketone (MEK). Michelle So Michelle, are you out west, yet? We want to hear Michelle's Montanna Maule Mountain Flying Reports! John, I am on my way west right now. I officially started west Thursday. I am making several stops in Ohio. Including the factory that built my travel trailer. Next stop after that will be Jay and Mary's. Looks like that will be Wednesday night or more. Next planned stop Mount Rushmore. Maybe Devil's tower and then into Montana. Then onto Missoula. My airplane is at my old boss getting an annual. It will probably be done in mid to late may.... Michelle |
Including the factory that built my travel trailer. If you are near Columbus, OH, email me privately. The BARNSTORMER is closed, perhaps we can sit down for coffee or something. eroodATrrohio.com make the necessary substitution |
Time, running out of fuel and fuel gauges | Dylan Smith | Piloting | 29 | February 3rd 08 07:04 PM |
spaceship one | Pianome | Home Built | 169 | June 30th 04 05:47 AM |
"Tanks on both" checklist item | Koopas Ly | Piloting | 46 | December 12th 03 03:42 PM |
Real stats on engine failures? | Captain Wubba | Piloting | 127 | December 8th 03 04:09 PM |
Long-range Spitfires and daylight Bomber Command raids (was: #1 Jet of World War II) | The Revolution Will Not Be Televised | Military Aviation | 20 | August 27th 03 09:14 AM |
