#11
Mike Noel wrote: I think alcohol is a polar-covalent solvent that tends to hold water in solution with gasoline. I suspect instead of getting the alchohol out, you would be suspending water in the fuel that you would not be able to drain. That doesn't sound likely. Otherwise the popular method of alcohol testing wouldn't work. You can test test the presence of alcohol in gasoline by mixing gasoline with some water in a test tube, agitate the tube, and check to see if the water level rises. On the other hand, if you have an engine that can burn alcohol, perhaps some amount of water in the alcohol could boost the performance of the engine ala water injection in old military aircraft. You could turn some of that wasted heat into steam before dumping it out the exhaust. I never quite understood why injecting water into engine will increase its performance. I have no doubt it's true that Boeing used to do that on their jet engines. Anyone here can provide a scientific answer? |
"M" wrote in message oups.com... steam before dumping it out the exhaust. I never quite understood why injecting water into engine will increase its performance. I have no doubt it's true that Boeing used to do that on their jet engines. Anyone here can provide a scientific answer? http://www.rfc.ca/NewSite/You_asked.htm Double whammy: 1. cools intake, makes an effect similar to octane increase 2. steam expansion in combustion chamber adds volume (ie: power). |
"M" wrote in message ups.com... Icebound wrote: http://www.rfc.ca/NewSite/You_asked.htm .... 2. steam expansion in combustion chamber adds volume (ie: power). This sounds dubious to me. It sounds like a violation of second law of thermodynamics. It takes energy to turn water into steam, and that steam gives that energy back by expansion, but not more than the energy it absorbs to vaporize in the first place. They could be arguing that the heat needed to vaporize the water would otherwise have been lost anyway.... into the exhaust gases, or into heating the metal of the engine, for example. |
The physical details of the process may be a bit murky, but the idea that
the temperature of the engine exhaust and the engine itself would be lower gives a bigger DeltaT that should be converted into mechanical energy to pull the plane. -- Best Regards, Mike http://photoshow.comcast.net/mikenoel "Icebound" wrote in message ... "M" wrote in message ups.com... Icebound wrote: http://www.rfc.ca/NewSite/You_asked.htm ... 2. steam expansion in combustion chamber adds volume (ie: power). This sounds dubious to me. It sounds like a violation of second law of thermodynamics. It takes energy to turn water into steam, and that steam gives that energy back by expansion, but not more than the energy it absorbs to vaporize in the first place. They could be arguing that the heat needed to vaporize the water would otherwise have been lost anyway.... into the exhaust gases, or into heating the metal of the engine, for example. |
I wonder if this is not done more in all the internal combustion
engines, if it can truely increase thermo efficiency? |
ups.com... Icebound wrote: http://www.rfc.ca/NewSite/You_asked.htm Double whammy: 1. cools intake, makes an effect similar to octane increase I found this http://www.rallycars.com/Cars/WaterInjection.html. So the benefit of #1 is obvious. 2. steam expansion in combustion chamber adds volume (ie: power). This sounds dubious to me. It sounds like a violation of second law of thermodynamics. It takes energy to turn water into steam, and that steam gives that energy back by expansion, but not more than the energy it absorbs to vaporize in the first place. The heat absorbed by the water reduces the peak temperatures and allows the engine to be run at a higher boost / spark advance / compression ratio without detonation. To take advantage of the water injection, you have to make actual changes to the engine - just adding water to an engine that is not being limited doesn't give much benifit. There are some efficiencies due to the specific heat of water and/or the ratio of specific heats at constant pressure vs constant volume - but I don't recall the details off the top of my head, and I'm too lazy to go look it up (reference books are at work, and I ain't). The downside, of course, is that if you _need_ the water to suppresss detonation and your water tank is empty or frozen you can kiss your pistons goodbye. -- Geoff The Sea Hawk at Wow Way d0t Com remove spaces and make the obvious substitutions to reply by mail When immigration is outlawed, only outlaws will immigrate. |
: I never quite understood why injecting water into engine will increase
: its performance. I have no doubt it's true that Boeing used to do that : on their jet engines. Anyone here can provide a scientific answer? As others have said, it's not that the water increases its performance. Rather, it's that the water allows operation under conditions that would otherwise destroy the engine (in particular, lots of turbo/supercharge boost). It's analogous to higher octane fuel. Higher octane fuel does not increase performance. Rather, it allows the engine to be tuned to a higher compression ratio without destroying itself from detonation. The higher CR is what increases performance. -Cory -- ************************************************** *********************** * Cory Papenfuss, Ph.D., PPSEL-IA * * Electrical Engineering * * Virginia Polytechnic Institute and State University * ************************************************** *********************** |
| Thread Tools | |
| Display Modes | |
| Ethanol Mandate for Iowa? | Jay Honeck | Piloting | 155 | October 4th 05 04:17 PM |
| MoGas Long Term Test: 5000 gallons and counting... | Jay Honeck | Home Built | 82 | May 19th 05 03:49 PM |
| MoGas Long Term Test: 5000 gallons and counting... | Jay Honeck | Owning | 87 | May 19th 05 03:49 PM |
| Ethanol Powered Airplane Certified In Brazil | Victor | Owning | 4 | March 30th 05 10:10 PM |
| Mogas and microbial growth | Economic Girly Man | Owning | 6 | November 13th 04 10:14 AM |
