"Montblack" wrote in message ... ("Dave S" wrote) Just one of the quirks of pushers without a bubble canopy.. hard to tell if you are on fire.. hard to tell if you are streaming anything... and hard to tell if the prop is turning. Speaking of cams ....how 'bout a nanny-cam? Montblack My old SeaBee, which IS a pusher, merely mounted a convex mirror out on the wingtip float. A glance at the mirror and you could check the prop, the engine compartment drain ( for streaming oil, etc. ) and most of the tailfeathers. Most of what you saw was water draining off the airframe after takeoff! :-) After landing you could see the water on the windshield and didn't need the mirror! :-) Highflyer Highflight Aviation Services Pinckneyville Airport ( PJY ) |
"Highflyer" wrote in message
... "Montblack" wrote in message ... ("Dave S" wrote) Just one of the quirks of pushers without a bubble canopy.. hard to tell if you are on fire.. hard to tell if you are streaming anything... and hard to tell if the prop is turning. Speaking of cams ....how 'bout a nanny-cam? Montblack My old SeaBee, which IS a pusher, merely mounted a convex mirror out on the wingtip float. A glance at the mirror and you could check the prop, the engine compartment drain ( for streaming oil, etc. ) and most of the tailfeathers. Most of what you saw was water draining off the airframe after takeoff! :-) After landing you could see the water on the windshield and didn't need the mirror! :-) Highflyer Highflight Aviation Services Pinckneyville Airport ( PJY ) Come to think of it, I've seen similar mirors on twins, I think Cessna, as an added verification of the undercarriage. Nice, simple, low tech, reliable solution. :-) Peter |
| Thread Tools | |
| Display Modes | |
| Whats the deal with counter-rotating props? | Dico | Owning | 38 | February 2nd 06 10:04 PM |
| Pusher props for WW I fighters | John Bailey | Military Aviation | 3 | September 11th 04 11:18 AM |
| Mil Monitoring in Florida | AllanStern | Military Aviation | 0 | April 1st 04 07:18 PM |
| Props and Wing Warping... was soaring vs. flaping | Wright1902Glider | Home Built | 0 | September 29th 03 04:40 PM |
| Help needed - fs2004 zaps fs2002 props | Ian D | Simulators | 1 | September 11th 03 11:20 PM |
